Welcome, Guest. Please login or register.
Pages: [1]   Go Down
  Print
Author Topic: Setups for a drift mustang...  (Read 521 times)
0 Members and 1 Guest are viewing this topic.
timeJuly 31, 2007, 08:56 PM #0
TamaDrummer88
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
WWW
If you could, and you had the money, what would you put into a  SN95 to make it into a drift car?  5.0?  4.6?  IRS or solid axle?  Coilovers or strut and spring?  gutted interior or full interior?
Post up!
Logged
1993 LX.  Few bolt ons.....
timeJuly 31, 2007, 09:19 PM #1
5.0wned
Trade Count: (0)
SN95 Veteran
Offline Offline
A skyline engine duh!  :D Sorry I couldnt resist. My answer would be a good driver.
Logged
1994 GT
timeJuly 31, 2007, 09:48 PM #2
TamaDrummer88
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
WWW
Oh now THATS real original. lol
Logged
timeAugust 01, 2007, 02:27 AM #3
Paul
Chief Pencil Pusher
Global Moderator
Trade Count: (+21)
SN95 Veteran
Offline Offline
Shadetree Mechanic
If I could build a drift Mustang, I would drift it right over a cliff.
Drifting is like figure skating, only with cars.  All the figure skaing I've ever seen was gay too.
Logged
Spoken like a true ricer with a slow car:
when you drive a "Street Car", Its more fun Looking REALLY clean, Then driving REALLY fast.
timeAugust 01, 2007, 02:28 AM #4
phil_the_thrill
SN95Forums Supporter
Trade Count: (0)
Speedo Pinned in 5th
Offline Offline
Post up!
kenne bell
Logged
Now accepting donations!
If you do the speed limit get the f*** out of my way!
"America is all about speed.  Hot, nasty, badass speed." -Eleanor Roosevelt
Alcohol may be man's worst enemy, but the bible says love your enemy.
timeAugust 01, 2007, 03:33 AM #5
MrNiceGuy
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
i would supercharge the 4.6, some kind of posi, and a good set of coilovers.. then it's up to the driver where it goes.. but then again... i would never drift a mustang.. auto-x would be fun.. but definitely not drifting
Logged
timeAugust 01, 2007, 04:23 AM #6
ryclef331
If it don't make dollars, it don't make sense
Technical Moderator
Trade Count: (+2)
SN95 Veteran
Offline Offline
94-95 Tech Moderator
Mild twin turbo setup for quick spool and good low end.  4.10s and a tq arm suspension out back.  You don't want to run a blower on a drift car.  I would see an over the counter blower setup spitting belts off left and right from the constant rpm changes.
Logged
94 Mustang GT 10.88 @ 125mph (LSx Swap in Progress.  OH Noes!1!1!)
04 Ram 3500 Cummins Turbo Diesel 14.55 @ 101mph
timeAugust 01, 2007, 05:09 AM #7
MrNiceGuy
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
ahh i didnt even think about that.. i have seen a lot of supercharged drift cars though..  but drifting isnt my thing.. so i dont know all the pros and cons of different set ups..
Logged
timeAugust 01, 2007, 06:07 AM #8
scarface
Trade Count: (0)
is that what you guys do to pass time over there ???
Logged
timeAugust 01, 2007, 11:13 AM #9
TamaDrummer88
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
WWW
In hawaii, drifting is big, because we have such close ties with Japan.  But not once have i seen a mustang drift.  Ive seen an LT1  camaro do it, but never a mustang.
Logged
timeAugust 01, 2007, 11:31 AM #10
drifts14x
Trade Count: (0)
revving engine
Offline Offline
Solid axle would be a disadvantage, you'd probably want a cobra motor, blueprinted with some killer valvesprings, bull-nosed, knife-edged crank, the key is just to have tons of rev, because you need to stay mostly in one gear. I used to drift my 240SX, trust me, a Mustang is a little fat to be running that way, but if you insist that this is a fantasy setup, you'd have to put every piece from the steeda catalog in the rear end and tubular K-member, etc, shave 5-600lbs and get a great driver, I know they drive the 05 stang as a drifter, but it still is just to promote Americans getting into the sport, JDM cars are lighter and can do more with a lot less, leave drifting to them.
Logged
1995 Ford Mustang GT Black 5.0 w/ 5-SPD
Convertible with Tan Top/Interior, Black front seats
Pro 5.0 Short shifter w/ Steeda Tri-ax handle,
BBK Intake, 65mm TB, Shorty Headers, Flowmaster Exhaust,
Mach460 Sound System, Black Cobra Wheels, 275/40ZR17 tires, Aluminum rack bushings, Tokico HP Springs/Struts/Shocks, Prothane Sway bar bushings, and other stuff I'm probably forgetting
1995 Ford Mustang GT Vibrant Red, 5.0 w/ 5-SPD
*Deceased 10/16/2008* Female Drivers= No Survivors
timeAugust 04, 2007, 04:31 AM #11
94yellowgt
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
You mean like this.  Its not me but it just looks to me like just raw american horsepower and rear wheel drive and good driver.
Logged
1994 stock bottom end, equal length headers, UPR shifter, off-road x-pipe, Flowmasters with dumps, AFR 165, F303 cam, Tubular GT40 intake, D1SC Procharger (11.7 psi), 75mm throttle body and 4.10 gears.
SCT BA2800 MAF and SCT chip tuned at speedydyno.com in Owensboro, KY
506.5 rwhp
510.9 rwtq
timeOctober 05, 2007, 07:12 AM #12
cheddar
Trade Count: (0)
revving engine
Offline Offline
man a 4.6 with a KB blower with a solid axel rear end and one hell of a driver
Logged
1996 mustang GT
1957 Ford Ranchero
2001 Ford Escape
timeOctober 05, 2007, 07:23 AM #13
driftingmustang
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
i got my mustang in order to drift, slowly restoring and building up. if i had all the money i needed now, i would get IRS with new k member in front, correct the reverse ackerson principle in the front (to make positive ackerson), get a cobra block and turbo it, coilovers, roll cage, replace all available body parts with carbon fiber (and paint over it cause im not into the carbon fiber look), get 18 inch bullit tires, and put a 6 speed transmission, lower the gears in the rear a bit, (maybe), upgrade the brakes, tighten my ebrake, and keep the car at stock appearance on the outside and (except for the 4 point roll cage) stock in apearance. but the hieght would be what my stang currently is (realy low)
Logged
timeOctober 05, 2007, 07:57 AM #14
SRT Handz
I tripped & fell down and cut myself & got blood on my Abercrombie & Fitch shirt & tore my Abercrombie & Fitch shirt & now I can't wear my Abercrombie & Fitch shirt because I got blood on it. And it got torn, too.
Trade Count: (+9)
SN95 Veteran
Online Online
Mr. Popular
Seems to me like you dont know a thing about drifting...
...In drifting, a Solid Rear end is an ADVANTAGE....IRS is the DISADVANTAGE.....Solid rear Makes drifting a whole lot easier than IRS. Look at the car that started the drift craze...the AE86 "Hatchi-Roku" was solid rear...and thats why maybe people choose a AE86...because it is soild rear.
..In drifting you dont stay in 1 gear....You use many gears and many types of techniques to initiate the drift. Feint, Power over, Braking, Side, Shift lock...these are all elements you to creat a drift.
....Seems To Me Like You Need To Watch The Drift Bible Son
...and Steeda Parts Suck Donkey Balls....Maximum Motorsports or NOTHING!!!
Logged
98' Mustang GT - Suspiciously Stock.....
timeOctober 05, 2007, 08:53 AM #15
Matt94GT
Administrator
Trade Count: (+1)
SN95 Veteran
Offline Offline
Go Canada @ Vancouver 2010
WWW
I wouldnt say Steeda sucks, they make some good stuff but IMO MM makes higher quality suspension products.
Logged
timeOctober 05, 2007, 08:56 AM #16
Just Enjoying The Ride...
Global Moderator
Trade Count: (+2)
SN95 Veteran
Online Online
Why is it that every one of these threads turns into a pissing match of some sort...
Nothing wrong with Steeda Suspension Parts!
Logged
Bob
96 GT VERT
Want to CHANGE the Country? Beat up the nearest Lobbyist!
timeOctober 05, 2007, 08:58 AM #17
I was robbed on my 11!
Trade Count: (0)
SN95 Veteran
Offline Offline
2004 Lightning 2.3 Whipple Powered
yea and eat  :rice:
Logged
12.45@106  1.69 60ft time on Ported eaton
Dynojet 520rwhp/565rwtq 12.1 @ 114mph spinning like top
timeOctober 05, 2007, 09:09 AM #18
Matt94GT
Administrator
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
http://videos.streetfire.net/video/fbaded05-d47b-4fe0-8378-10edece95909.htm
yea that guy is a good driver, i know id put it up on one of those little curbs a few times if I were trying that lol.
Logged
timeOctober 05, 2007, 09:27 AM #19
Global Moderator
Trade Count: (+2)
SN95 Veteran
Online Online
yea and eat  :rice:
and chase around really hot hawaiian girls....soooo yummy cheesy
Logged
Bob
96 GT VERT
timeOctober 05, 2007, 09:45 AM #20
Trade Count: (0)
SN95 Veteran
Offline Offline
yea and eat  :rice:
I like Pineapples do you  ^-^
Logged
timeOctober 05, 2007, 10:47 AM #21
BadBlack95GT
Trade Count: (0)
SN95 Veteran
Offline Offline
My Son and his Bottle
WWW
I'm not a fan of drifting... i think it's kinda cool to watch, but i wouldn't build a car for it. I'm more interested in driving really fast for only 1320 Feet
Logged
http://www.myspace.com/insanemotorsportz
"Given the unlimited resources, a true hot rodder wouldn't be content until he had created a car so violent, so hairy, so totally sick, that the very act of pressing the throttle, would result in instant death"
timeOctober 05, 2007, 11:57 AM #22
reivaxtorres
Trade Count: (+1)
SN95 Veteran
Offline Offline
you guys really consider that drifting? thats just power sliding and doughnuts to me
EDIT:
drifting a mustang is not hard at all, its just harder to do it in a 3300+lb car than it is to do it in a 2700lb car.
SRA vs IRS. SRA is not always an advantage. yes, the ae86 has the SRA, but then again look at how much it weighs.
the BIGGEST factor in drifting is weight transfer and weight balance. yes, the SRA is about 70-80lbs lighter than the IRS in a mustang, but the SRA is about 125lbs HEAVIER than the IRS in regards to unsprung weight, which is pretty much the amount of weight you throw back and forth. the IRS also helps to even out the weight balance (weight distribution) of the front-heavy mustang.
what do you need to drift a mustang tho? prefessionally drift? look at the falken mustang and thats pretty much what you need. a build motor, supercharged to get about 500-600rwhp, gutted, cagged, massive amounts of suspension work, brake upgrades, and lots and lots of tires.
to just drift it on an amature level (and on a budget)? at the very least get lowering springs, a clutch that is going to withstand the abuse of constant high rpm drops/high rpm shifting, and at the very minimum a front strut tower brace. and lots and lots of patience and tires. if you want some more power out of it, just get some basic bolt ons like exhaust and intake, and a throttle body (improves throttle response).
what was i drifting with? a 98gt with no rear sway bar, hawk brake pads w/slotted rotors, steeda front strut brace, 2" lowering springs, and the rest of my suspension was stock. i was drifting on my stock 17" chrome rims. power mods were: intake, t/b, plennum, pullies, clutch, al. flywheel, catted x pipes and magnaflow catback. that was it for mods, and i was (after about a year of once-a-month practice) drifting as good as most the other amature drifters out there. had a professional drifter drive my car and i was amazed at how good he got it to drift, way better than i had ever done.
earlier this year i swapped the SRA for IRS and while i havent drifted on a drift course since ive had it, i have messed around and i have tested it, and it feels a lot better than the SRA. the car is a lot more predictable and you are in control of the car, you are no longer reacting to the car's movements.
« Last Edit: October 05, 2007, 12:13 PM by reivaxtorres » Logged
RIP Gloria A. Torres
4/26/61 - 10/30/07
The best Mom-lady I could have ever asked for
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
timeOctober 05, 2007, 06:13 PM #23
Matt94GT
Administrator
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
Well yah its not really 'drifting' I agree but its getting there, dont often see stangs drifting and I thought that was a pretty sweet vid.  Drifting I guess are the dudes in the nissans and toyotas consently sideways doing like 60mph.
I agree with you man, its all about the driver, I could drive a pro drift car and somebody that has good drifting skills could own me with my stang probaly lol.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
10 Rib Vs 8rib Setups
Tony Montana 2 159 Last post November 12, 2006, 08:17 AM
by TRUUBLE
Guys have pics of your sub/amp setups?
sʇǝɟ 31 815 Last post January 10, 2007, 06:34 AM
by MeanGrn Gt
Drift 5.0 Check it Out
(((Foster98GT))) 3 172 Last post August 31, 2007, 03:45 PM
by Maniak87
What shortblock setups are yall running? « 1 2 »
96-04 - 2V Specific
my96gtstang 57 615 Last post July 30, 2008, 08:08 AM
by lizzyfan
setups for 13's to low 14's
96-04 - 2V Specific
93PGT 30 415 Last post July 07, 2008, 07:02 AM
by Chris@MMR
Blow-Thru vs Draw-Thru MAF Setups
Forced Induction & Tuning
blown98gt 13 1402 Last post May 14, 2009, 01:30 AM
by blown98gt
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
