Welcome, Guest. Please login or register.
Pages: 1 [2] 3 4 5 6 7   Go Down
  Print
Author Topic: whats your exhaust?  (Read 9846 times)
0 Members and 1 Guest are viewing this topic.
timeOctober 10, 2007, 07:01 AM #35
javi
Your local Mexican
Global Moderator
Trade Count: (+31)
SN95 Veteran
Online Online
Mechanically challenged
current setup
bbk equal length shoties
jegs o/r x pipe
2 chamber flowmasters
the setup im gonna go to
longtubes
dr. gas x pipe
spintech prostreets or bassani mufflers
you mean this
Logged
timeOctober 10, 2007, 10:23 AM #36
fastgtfairlane
Trade Count: (+1)
SN95 Veteran
Offline Offline
yes that would be it. a drive by video at wot would do justice for that exhaust setup.
Logged
94 gt stock block, stock heads, typhoon upper lower, 65mm throttle body, 24lb inj, cai, c&l 76mm mass air, mac overdrives, msd 6a, bbk equal length shorties, off road x pipe, spintech prostreets mufflers. 98 cobra rims
timeOctober 27, 2007, 10:54 AM #37
916_5.0
Trade Count: (+1)
Speedo Pinned in 5th
Offline Offline
WWW
My set up is
BBk Equal length shorties 1 5/8
Bassani catted X 2.5 ( The cats are going bye bye they dont do anything anyways)
Flowmaster cat back 2.5 ( These are going bye bye to at some point either for bassani or Boral XR-1)
3 inch Folmaster tips
Logged
King Cobra Clutch - MAC C.A.I.- BBK Shorty equal length headers - Bassani X - Flowmaster catback - Ford Racing underdrive pullies-FRPP Hi-Volume Water Pump - Hurst shorty - Eibach Pro Kit - Steeda upper and lower control Arms-Tokico Shocks - STB - Ford Racing 9mm wires - prothane motor mounts -17' Cobras.
timeOctober 27, 2007, 11:07 AM #38
Stevo
SN95Forums Supporter
Trade Count: (0)
SN95 Veteran
Offline Offline
OGFMC member #3 Pt Pleasant NJ
Headers to prochamber 2 3/4 to Mac's. Settin off alarms FTW. Cats are for Camaro's.  :D
Logged
SmileyCentral.com" border="0
timeOctober 28, 2007, 02:22 AM #39
Slow5.0
Trade Count: (0)
sitting in the driveway
Offline Offline
WWW
MAC 1 5/8 LTs
MAC 2.5 O/R H-pipe
Flows American Thunder w/ SS tips
Logged
I'm from Bosnia / Europe ,now live in USA ,my English is sux ,so please don't critize me
Ernan
'94 GT Vert
12.76 @ 105 w/ bad clutch 4050lbs 1.8 60FT
TW heads,B-31 AFM cam.....   MORE
312HP / 340TQ with safe tune
"A few" pics of my car
My "Slow5.0 Compilation" video from the begining
My "Slow5.0 Dyno Compilation" video
timeOctober 29, 2007, 11:16 AM #40
scott5
Trade Count: (0)
Offline Offline
finally got my vid up.. here it is.. My setup is on the first page but i will throw it right here too
1 5/8s MAC lts
2 1/2 MAC prochamber
2 1/2 MAC cat back
Logged
95 Gt Vert
95 Gt Coupe
00 408 F1R
timeOctober 29, 2007, 11:21 AM #41
javi
Your local Mexican
Global Moderator
Trade Count: (+31)
SN95 Veteran
Online Online
1 5/8s MAC lts
2 1/2 MAC cat back
http://www.youtube.com/watch?v=gKDK9VncCHQ
nice,offroad prochamber?
Logged
timeOctober 29, 2007, 11:46 AM #42
scott5
Trade Count: (0)
Offline Offline
1 5/8s MAC lts
2 1/2 MAC cat back
Yes sir
Logged
95 Gt Vert
95 Gt Coupe
00 408 F1R
timeOctober 29, 2007, 11:52 AM #43
javi
Your local Mexican
Global Moderator
Trade Count: (+31)
SN95 Veteran
Online Online
1 5/8s MAC lts
2 1/2 MAC cat back
Yes sir
here slp's h pipe off road,i liked it but it was way too loud tho just got bassani mufflers and i love them
Logged
timeOctober 31, 2007, 06:48 AM #44
94IVGT
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
WWW
94 5.0l
BBK LTs
BBK O/R X-pipe
Flowmaster 40s
powered by Aeva
Logged
1994 GT 5sp.
Dart block 331 forged eagle rotating assembly w/8.2:1 probe pistons, Twisted wedge heads, PRW rrs, B451 cam, canton oil pan, vortech 18lbs, PMAS 95mm MAF, PMS tuner, ARP Studded block, Pioneer SFI dampner, zoom twin disc clutch and Billet steel flywheel, ASP smog delete, BBK long tube headers into x-pipe into flowmasters, Autometer gauges, BBK subframe connecters, billet timing gears and chain, 180 degree stat, MSD cap, rotor, wires, mallory ignition, viper spec 6sp, detroit locker, 373, moser axles, much much more. Full boost and full 7000rpm not avaliable until new fuel system gets installed. so im only seeing 12-13lbs of boost and 52-5300rpm
timeOctober 31, 2007, 07:01 AM #45
AaRoN
WildFire
Trade Count: (+1)
SN95 Veteran
Offline Offline
Knowledge does not cure opinion.
WWW
Stock Headers (from the 98 setup)
BBK o/r X
Factory cat-back
(01 P.I. motor)
don't mind my son talking to his little sister in the background
powered by Aeva
« Last Edit: November 10, 2007, 01:05 AM by SilverSol » Logged
timeNovember 02, 2007, 05:46 PM #46
thorco3
Trade Count: (+1)
SN95 Veteran
Offline Offline
it's not an obsession
BBK o/r X
Factory cat-back
(01 P.I. motor)
:rollinglaugh:
the kids in the background make that vid   O0
Logged
timeNovember 03, 2007, 08:26 AM #47
AaRoN
WildFire
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
thanks...  ;D
Logged
timeNovember 10, 2007, 12:58 AM #48
bikewiz
Trade Count: (0)
Offline Offline
WWW
HP Turbo 3.5" DP to y-pipe to SLP Loud Mouth II system.  No sound clips of the LMII mufflers, but I have vids on my myspace of the original Loud Mouth I mufflers.
http://www.myspace.com/bikewiz85
check the videos section
Logged
Matt - bikewiz @comcast.net
'95 GTS - 614 RWHP/657 RWTQ - DSS 347XR Big Bore, AFR 205s, Ed Curtis cam, HP Stage II turbo, Edelbrock RPM II, TKO-600, McLeod Twin Disc, SCT tuned by Bob Kurgan, 9" w/Tru-Trac, EVM Tri-Link, MM Panhard, Bilstein HDs, KB Street Cage, Brembos, Cobra R seats
timeNovember 10, 2007, 01:07 AM #49
AaRoN
WildFire
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
Logged
timeNovember 10, 2007, 02:15 AM #50
bikewiz
Trade Count: (0)
Offline Offline
WWW
BTW, I'd beware of the Dr. Gas X pipe.  I had 2 buddies who ordered them for their 94-95s and they did not fit, the collector flanges were at the wrong angle and leaked.  They both paid over $100 to have an exhaust shop cut and mod the pipe.
I have had VERY GOOD luck with the summit racing house brand h-pipes for a stock car.  I usually pick up a stainless band clamp and ditch the cheap u-bolt clamp that holds the two halves of the h-pipe together.
Logged
timeNovember 15, 2007, 12:01 PM #51
Kemble
Trade Count: (0)
engine running
Offline Offline
Mac Longtubes (1 5/8")
Mac Offroad Prochamber (2 1/2")
Original 40 series Flowmasters (2 1/2")
Have a video somewhere just gotta find it.
Logged
1995 Rio Red GT heads,cam and soon to be carbed.
timeNovember 15, 2007, 03:07 PM #52
snakesonastang
Trade Count: (0)
engine running
Offline Offline
I have a set of shorty mac headers, off road x-pipe, 2.5 inch cat back with magnaflow mufflers.  I will get a sound clip and post it soon.
Logged
timeNovember 25, 2007, 12:55 PM #53
snakesonastang
Trade Count: (0)
engine running
Offline Offline
Finally got my exhaust clip.  It really sounds mean >:D
http://s239.photobucket.com/albums/ff118/snakesonastang/?action=view&current=exhaustsoundclip.flvpowered by Aeva
Logged
timeNovember 25, 2007, 01:11 PM #54
94Pro-5.0
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
BBK shorties
BBK off road x-pipe
Flowmaster mufflers
F303 cam
This is the only video i have, and its from a camera phone, i'll get another clip soon
ignore my roomates comments lol
Logged
timeNovember 30, 2007, 03:34 PM #55
mich_666
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
Stock headers, straight H-pipe, borla mufflers=loud.
Logged
Sapphire Blue 95 GT: 18" Saleens, Cobra Hood, Cobra Front Bumper, BBK CAI, Magnaflow Magnapack Catback, Offroad H-Pipe, King Cobra Clutch, Pro 5.0 Short Shifter, FRPP 3.73, Subframe Connectors, Autometer Guages and Tach, Eibach Sportlines, Bilstein Cobra Shocks, Rebuilt T-5, Smog Delete, Poly Urethane Bushings in ALL REAR END CONTROL ARMS, POLY URETHANE MOTOR MOUNTS and TRANNY MOUNT, aireffects airfreshner, 3/8 of a tank of gas, hopefully i didnt miss anything...
timeNovember 30, 2007, 05:22 PM #56
94kingcbra
Trade Count: (+2)
sideways into 3rd
Offline Offline
BBK Shorty Headers, BBK X Pipe w/ High Flow Cats, Dynomax with side exit through body kit...
Logged
94 Cobra, Dynomax Side exhaust, Cobra r 2000 hood, Saleen Wheels 18x9, S281 Wing, 347 Forged stroker kit, balance + blueprint, Full MSD Ignition System, AFR 165 cc ported heads, Holley Systemax Upper And Lower Intake port Matched to Heads, E-303 Cam, MAC CAI, 70mm PP Throttle Body/Elbow Adapter, bbk shorty headers/X-Pipe w/ H-F Cats, Granatelli MAF sensor for 30lb injectors, Ford Racing 30 lb injectors, 3.73 gears w/ a Powertrax No-Slip Locker. Optima red under the hood & Optima Yellow in the trunk, 3 Farad capacitor, 2 12" Kickers, 1000w kicker amp, 400w Fosgate amp, Boston acoustic components, Pioneer DVD W/ Ipod hookup, Nav system, Full Autometer Gauge Cluster, MGW Shifter, Nitto NT-05's SOME PEOPLE SAY FORD CIRCLE THEIR MISTAKES, I SAY, "ITS NOT A CIRCLE DUMB a*s, IT'S AN OVAL
timeDecember 01, 2007, 01:33 PM #57
LAFENATU
One kewl vato
Trade Count: (0)
SN95 Veteran
Offline Offline
1995 Mustang GT Coupe
Headers:  Ford Racing Stainless Steel Shorty
Mid pipe: Mac Prochamber
Catback Flowmaster "original" 2 - Chamber Stainless Steel 2.5 with 3" tips.
Logged
Deep Forrest Green 1995 GT Coupe built on 12/14/1994, 1/226 made.
AFR 165/Crane 2031/Extrude Honed GT40 Intake/Built AODE
timeDecember 02, 2007, 05:38 AM #58
Slow5.0
Trade Count: (0)
Offline Offline
WWW
I found my exhaust videos  :banana:
MAC 1 5/8 LTs
MAC 2.5 O/R H-pipe
powered by Aeva
powered by Aeva
powered by Aeva
powered by Aeva
At WOT
powered by Aeva
powered by Aeva
powered by Aeva
94 Mustang GT 5.0 H/C/IMy BIGGEST burnout ever
« Last Edit: December 02, 2007, 05:40 AM by Slow5.0 » Logged
Ernan
'94 GT Vert
timeDecember 10, 2007, 01:19 PM #59
scott5
Trade Count: (0)
Offline Offline
anyone run a mac cat back with no tail pipes?
Logged
95 Gt Vert
95 Gt Coupe
00 408 F1R
timeDecember 10, 2007, 10:07 PM #60
5.0wned
Trade Count: (0)
SN95 Veteran
Offline Offline
BBK equal shortys
Bassani Offroad X
Bassani cat back.
Anyone know of a clip with offroad h and bassani catback on a 5.0? I really want to hear it.
Slo I know you have an H with bassani now, did you ever get a clip? Let me know when you do I really wanna hear it. Im thinking real hard about switching in March when smog comes and I have to put the stocker on anyway for a day.
Oh ill get a clip for you guys soon.
Logged
1994 GT
timeDecember 11, 2007, 01:42 AM #61
javi
Your local Mexican
Global Moderator
Trade Count: (+31)
SN95 Veteran
Online Online
BBK equal shortys
Bassani Offroad X
Bassani cat back.
hey man,yes i have h pipe off road but im  been busy,if i get one now is going to be just start up and rev because ice storms  :'( here in Oklahoma
Logged
timeDecember 12, 2007, 04:09 PM #62
5.0wned
Trade Count: (0)
SN95 Veteran
Offline Offline
BBK equal shortys
Bassani Offroad X
Bassani cat back.
Its cool man, I have been pretty busy too. Just looking because it seems like NO ONE has an H pipe with Bassani only X pipes. Ill probably just take one off my friends cars and swap it one day.
Logged
1994 GT
timeDecember 19, 2007, 04:39 AM #63
scott5
Trade Count: (0)
Offline Offline
I had the bassani h-pipe with flows and flowtech shorties on my last car and it sound just like any other h-pipe. IMO
Logged
95 Gt Vert
95 Gt Coupe
00 408 F1R
timeDecember 19, 2007, 07:31 PM #64
sitzlac
Trade Count: (0)
Offline Offline
I have mac equal length shorties headers, off-road x pipe, 2 chamber flows,  with turn downs... Sounds good but it is not loud enough nor does it have a real deep rumble. I will be putting on long tube headers this spring and I might change to a h pipe but I do not know if that will help me get the sound I want. And if that is not loud enough then I will go with 1 chamber flows!  :santa_evil:
Logged
timeDecember 19, 2007, 11:03 PM #65
5.0wned
Trade Count: (0)
SN95 Veteran
Offline Offline
Bassani does not make an H pipe. They make x pipes for our cars. At least thats all they make now. I agree with most you h or x pipes all sound the same regardless of brand. I wanna know what my set up would sound like with an H instead of the X I have now.
Logged
1994 GT
timeDecember 19, 2007, 11:19 PM #66
javi
Your local Mexican
Global Moderator
Trade Count: (+31)
SN95 Veteran
Online Online
do you have a x pipe off road?
Logged
timeDecember 25, 2007, 10:22 AM #67
mustangspartan
Trade Count: (0)
redlining 1st
Offline Offline
Next time i go run my car in storage ill post my clip..
Mac O/R H
Mac catback with 3"
has a awsome sound and has a little rap to it also..
Not a big fan of the flowmaster..Sounds not enough for me. :xmassign:
Logged
timeDecember 25, 2007, 10:44 AM #68
no_pistons7
Trade Count: (0)
revving engine
Offline Offline
b303 cam
bbk headers
H-pipe
Flowmaster 40's
still not loud enough for me it seems pretty quiet actually, im gonna be putting some borlas on there soon hopefully :santa_grin:
Logged
90mustang coupe=black on black, bbk headers,o/r h-pipe, flowie catback, b&m ripper, king cobra clutch,mac 70mm tb/spacer,mac cai,3.55 gears,tokico hp shocks and struts,2"suspension techniques springs,5lug conversion with 18'' saleens, clear headlights.=CURRENT
90mustang gt=SOLD
95mustang gt/fobra=SOLD
92gti16v=SOLD
88rx7=SOLD
67mustang=SOLD
timeDecember 25, 2007, 11:13 AM #69
no_pistons7
Trade Count: (0)
revving engine
Offline Offline
found a clip
Logged
90mustang gt=SOLD
92gti16v=SOLD
88rx7=SOLD
67mustang=SOLD
Pages: 1 [2] 3 4 5 6 7   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
Whats up with all of the red X's?
.:Lounge:.
95 Sleeper 13 286 Last post February 02, 2007, 06:43 PM
by Matt94GT
Exhaust ShowCase- Official Exhaust Videos Thread
Twista 29 1079 Last post October 25, 2007, 11:00 AM
by WyoTechMSA
Shelby GT 500 Exhaust Video: 44RWHP with just exhaust?
powerjon 8 396 Last post July 18, 2007, 11:48 AM
by Red
Whats the Loudest Exhaust to get for a 94-98 Cobra
SVT Corner
CobraSnake 22 449 Last post September 11, 2008, 06:49 PM
by 98COBRA_MIKE
Whats a good Asking price for my Exhaust???
.:The Garage:.
330CubeGt 12 215 Last post July 01, 2009, 08:17 AM
by project94
Spintech Side Exhaust Kit exhaust clip
.:The Garage:.
NmcgrawJ 15 251 Last post October 10, 2009, 03:35 AM
by javi
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
