October 04, 2007, 11:11 AM | #0 |
Matt94GT
Administrator
Trade Count:
( +1)
SN95 Veteran
Offline
Go Canada @ Vancouver 2010
Im writing this in simple terms, for people who don't understand too much about stereos so if you have anything to add feel free.
Ok first off you have to tell your self what you want. The main question is do you want subs, they will add weight to your car, and in the long run make your stereo at least 2X as expensive as without them. Personally I love a sub.
NOTE: Prices I quote of internet prices, you can probaly find them slightly cheaper online or ebay but if you buy local expect to pay more.
Power Ratings Ignore WATTS...Read the RMS! RMS is "Root Mean Square". It is a measurement of AC Power. It is the effective power used by a device. In other words RMS is the watts rating that your speakers will output on a continuous basis. Basically you just want to do apples to apples. If your amp or stereo ouput is rated in RMS or Peak that is the measurement you would use to for the power that speaker will handle. I always go by RMS never wattage....why? All companys should rate their stuff in RMS and peak wattage. But some companys measure their RMS diffrent to make their stuff seem more powerful.
Example: Company a: Their subwoofer is 1000watts but only 200rms Company b: Their subwoofer is 500watts and 250rms Your going to think yeah, company A's is better but it really is not, chances are its a cheaper quality brand and they are measuing their rms diffrent to 'trick' you. It shoud roughly be around 50%.
So always go by RMS wattage when matching components!
Headunit I would spend at least $200. The key to your stereo. Now that everyone has a IPOD make sure its Ipod capable. I always recommend Alpine, pioneer premier & kenwood are nice as well. Now some people just think getting a cheap heaunit they can put more money towards speakers...this is right in a way but more expencive headunits have better components and features which will get the most out of which ever speakers you choose. The average quality headunit should produce 18rms x 4 (x4 means to four channels...will power 4 speakers)
Speakers I would spend at least $75 a pair. Good brands to look into are: JL, alpine, kenwood, boston acoustics, infinity, eclipse (in no particular order) The best speakers are 6.5" or 6.25" usually, why because there round, think about it! Your car might only take 5x7 or 6x9 but 6.25" will fit, you might have to make a simple adapter plate but its easy. 5x7 and 6x9 design's tend to produce more bass. Now your headunit lets say it supplys 18rms/50watts peak. Your not going to find speakers to match that, your best bet will be to try to find some in the 30-50rms range if you can, as you will get the most out of them for your money (higher wattage = more expencive = not nesscarly louder or better) if you bought some 200rms speakers and put your headunits 15rms to them not only would it probaly ruin your speakers but 25rms speakers will outperform them (this is of course within reason).
Getting a sub? +$300approx for speakers Now if your getting a sub I suggest to get a component set, that has 2 midrange (6.25 or 6.5") speakers, 2 crossovers and 2 tweeters (tweeters produce just highs). Reason I suggest this is your sub will produce lots of bass, it will be hard to hear vocals and some sound over it, but with a component set it will cut right thru that and you can really crank up your stereo. A component set expect to pay $150+, then you will need an amp for it id say at in the $150+ range. A 2 channel amp will work fine since you have the crossovers which split it up for the speakers and midrange and filters out power to the tweeters (of course a little tweeter cant take as much power as a full speaker).
Subwoofers Look for dual voicecoils (D2). Recommended brands...too hard to say, tell us what your looking for interms of sound! BTW: I love JL, best bang for the buck! Dual voice coils basically is two subs in one, you need 2 channels of power going to it, so a 2 channel amp is best. They sound better, and handle more power, make more bass. People get all attracted by looks or by big magnents, big surrounds etc. Ignore this, stick to the RMS rating. Now with subs are probably the hardest to purchase if you dont know what your doing. Feel free to ask in the forums and someone will help you. There are Sound Quality Subs, SPL (sound pressure level) subs. Then there are some that are a good mix. Personally one of my favorite subs is a JL. JLW3 is rated at 250rms, I only paid $75 for mine off ebay! IMO it sounds better and louder then lots of 500rms subs out there! Dont let small sizes or looks fool you on subwoofers. If you run one subwoofer you probaly want it to be D2. Dual 2ohm is what that means.
Amplifiers The most important part if your stereo interms of sound quality & performance. Reccomended brands: JL, Alpine, PPI, Orion, Kenwood. Im not going to get technical here. But the more you pay for an amp the better quality you will get. Find the most expensive amp in your price range with the lowest wattage and it is probably the best amp. What im trying to say is the internal components make a big diffrence. One amp might be twice as powerful as another and half the price, but the 'cleaness' of that power will suffer big time, expencive amps have expencive internal parts which diliver clean, crisp, undestorted power which will give you a clean crip undestorted sound. Please dont cheap out on an amplifer, headunits are the same way! Im not going to get too detailed but thought I would shoot out some examples.
What to look for? Keep your eye on the THD rating! What is THD? TOTAL HARMONIC DISTORTION. The amount of undesirable harmonics present in an output audio signal expressed as a precentage. The lower the percentage the better.
Here is an example:
JL Amp THD at Rated RMS Power: 0.03% Clarion Amp at Rated RMS Power: 0.2%THD
Not to pick on Clarion and im using extremes but the lower that THD %# the better! The JL amp is going to sound a hellofa lot better!
THD is a lot more important when running speakers with an amplifier rather then subs, please keep it in mind interms of subs try to get a low THD but its not as crucial as when selecting and amp for your speakers!
Wiring When installing new speakers in your car please buy new wiring and run new wiring to your speakers. You don't need anything too fancy you can spend anywhere from $10-100 for example. You get what you pay for? Not always, pick a happy medium in wiring. Subs?/Amps? If your running an amplifier you cant go TOO big of wire but you can go too small, if your running around 600-1000RMS total I would suggest at least 4ga wire. If your 200-600rms, 6ga will be fine. Go for good material on the connections when buying terminals etc. Oxygen free copper is fine, silver or gold if you want to spend more money.
Wooooooooooooooo im done here. :bunny3:
PS: If you have questions about what stereo is best for you, or want help choosing... Please start a new thread! O0
« Last Edit: October 04, 2007, 12:25 PM by Matt94GT »
Logged
October 04, 2007, 11:19 AM | #1 |
Red
Trade Count:
( 0)
SN95 Veteran
Offline
Nice thanks for the write-up! O0
Logged
October 04, 2007, 11:23 AM | #2 |
Matt94GT
Administrator
Trade Count:
( +1)
SN95 Veteran
Offline
no worries, thought its easier then explaining it each time for ppl. tell me if it doesn't make sense to you, since i just wrote it up off the top of my head, so i can edit things to make it more clear.
Logged
April 19, 2008, 11:01 AM | #3 |
mich_666
Trade Count:
( 0)
smoking 'em in 2nd
Offline
for someone thats "wire-stupid" like me, this is awesome! :dancing6: THANKS!
Logged
Sapphire Blue 95 GT: 18" Saleens, Cobra Hood, Cobra Front Bumper, BBK CAI, Magnaflow Magnapack Catback, Offroad H-Pipe, King Cobra Clutch, Pro 5.0 Short Shifter, FRPP 3.73, Subframe Connectors, Autometer Guages and Tach, Eibach Sportlines, Bilstein Cobra Shocks, Rebuilt T-5, Smog Delete, Poly Urethane Bushings in ALL REAR END CONTROL ARMS, POLY URETHANE MOTOR MOUNTS and TRANNY MOUNT, aireffects airfreshner, 3/8 of a tank of gas, hopefully i didnt miss anything...
November 12, 2008, 05:36 PM | #4 |
red94gt5.0
Trade Count:
( 0)
revving engine
Offline
nice write-up, i install car stereos for a living, BUT you are completely wrong about a dual voicecoil sub being louder than a single, the only difference between the 2 is wiring options aka impedance. if u have (2) single voice coil 4 ohm subs they can either be wired to 8 ohms or 2 ohms. If you have (2) dual voice coil 4 ohm subs, they can be wired to 1 ohm or 4 ohm
Logged
November 28, 2008, 05:01 PM | #5 |
Matt94GT
Administrator
Trade Count:
( +1)
SN95 Veteran
Offline
thanks, generally higher end subs come as DVC though, Ive been out of the game for like 5 years and I wrote this last year, now that you mention it your right...dunno what I was trying to say.
Logged
June 04, 2009, 06:11 PM | #6 |
z96cobra
Trade Count:
( 0)
sitting in the driveway
Offline
Currently own my first mustang- 96 SVT Cobra...
Looking at a few different decks to go in my 96 Cobra with Mach 460....
Kenwood - 50W x 4 MOSFET Apple? iPod?/Satellite/HD Radio-Ready In-Dash CD Deck Model: KDC-MP342U $139.99
Sony - 50W x 4 In-Dash CD Deck Model: MEXBT2700 $159.99
The RMS for the Sony is much higher than the Kenwood, (45 vs 22)...
OR would I be better off saving some money on this one
Sony - 52W x 4 Apple? iPod?/Satellite Radio/HD Radio-Ready CD Deck Model: CDX-GT330 $104.99
I am on a budget, so i'm probably looking at about 50 for installation.. and 200 is the most im willing to spend for it to be in my car and playing... Just wanted a little insight, I'm not very good with Audio, so all i have is my good experience with my last Sony Deck for my 92 towncar
Logged
June 16, 2009, 10:28 AM | #7 |
Matt94GT
Administrator
Trade Count:
( +1)
SN95 Veteran
Offline
dont go with sony, i've been out of the stereo game for a while but sony car stero stuff is not very good. alpine and kenwood make great headunits.
Logged
June 16, 2009, 03:11 PM | #8 |
Vermilion
ole dirty bastard
SN95Forums Supporter
Trade Count:
( +7)
SN95 Veteran
Offline
im cheaper. i have a pioneer premier with an ipod fm transmitter. my exhaust drowns everything.
Logged
a plethora of mods. NOT deployed and still supplying death from above.
June 16, 2009, 09:26 PM | #9 |
CanaryGT
Hewo Pwease
Trade Count:
( +6)
SN95 Veteran
Offline
I used to like Kenwood. Im more of an Alpine and Rockford Fan. I also enjoy the JL Audio stuff but for the money im not sure anymore.
Logged
 ENGINE: Trickflow TW Heads, Cobra Intake, TFS1 Cam,NOS 100 Shot, Mishimoto 3 Core Rad, BBK Cold Air Intake, ProM MAF, BBK 65mm TB, 24# Injectors , Underdrive Pullies, Optima YellowTop, MSD Igniton Setup, BBK Longtube Headers,BBK Offroad H Pipe, American Thunder Exhaust DRIVETRAIN: Pro 5.0 Power Tower, Custom Centerforce Clutch, Rebuilt T5 w/Astro Parts, Ford Aluminum DS, 4.10 Rear Gears SUSPENSION: Koni (Red)Coilovers(300# HyperCoils),Saleen Springs (Rear),Maximum MotorSports LCA's and SBC INTERIOR: Blue Glow Gauges, Blue Led Tri-Pillar Gauge (A/F, Water Temp, Oil Pressure) Blue HVAC w/Bullit Knobs., Raptor Blue Shiftlight, Cool White LED EXTERIOR: Cervini 3" Cobra R Hood, Kaenan S281 Wing, 17" White Cob
June 17, 2009, 07:38 AM | #10 |
Trade Count:
( 0)
SN95 Veteran
Offline
Sammich Club #5
I still like Kenwood. I LOVE my headunit. I'm up in the air on if I want to find a NIB one like the one I have (for the 67, its discontinued) or go double din, all out, navi, dvd touchscreen mofo.
Dunno yet.
Logged
 is the only wmm member to go from associate to full fledged bad a*s status
Beyotches don't know bout my White Mustang Mafia
June 17, 2009, 10:16 AM | #11 |
Matt94GT
Administrator
Trade Count:
( +1)
SN95 Veteran
Offline
my last 3 have been alpine, they make awesome head units, JL makes awesome subs, amps, speakers....imo.
Logged
