February 21, 2008, 10:32 AM | #0 |
Willis_98GT
who says ponys can't get sideways?
SN95Forums Supporter
Trade Count:
( +2)
SN95 Veteran
Offline
Down to smash new age mustangs into the ground
k.. have everything taken off except for coolant line..
i took the thermostat hosing off and drained out the coolant that goes across the line to the radiator..
just need the best idea of how to drain the coolant out of the manifold before i pop this ***** off. i'm excited!!
.. i'm on a laptop and literally next to my car.
« Last Edit: February 21, 2008, 10:34 AM by Willis_98GT »
Logged
 98 BAB Constructed Modular Madness Pi This, Pi that, Full intake, full exhaust, sitting on dd blackchrome and blinding ppl with 10k Hids.. the list goes on and when you launch like a mofo...just remember where you got all those goodies...asshat...
Mod time ;)
your gonna need more then one to make that sled fast... Will will still murder you
February 21, 2008, 10:50 AM | #1 |
DropTopPony
Just Enjoying The Ride...
Global Moderator
Trade Count:
( +2)
SN95 Veteran
Offline
I threw some kitty litter on the floor when i yanked my intake and heads off....your gonna have some coolant spill so just do it
Logged
Bob 96 GT VERT Want to CHANGE the Country? Beat up the nearest Lobbyist!
February 21, 2008, 11:04 AM | #2 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
alrite, goin for it
Logged
Mod time ;)
February 21, 2008, 11:22 AM | #3 |
reivaxtorres
Trade Count:
( +1)
SN95 Veteran
Offline
the way i did it, and also did it to my friends car, was unplug the lower radiator hose and let it drain from there into a bucket. when i took the manifold off, there was very little that spilled.
Logged
RIP Gloria A. Torres 4/26/61 - 10/30/07 The best Mom-lady I could have ever asked for
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
February 21, 2008, 11:53 AM | #4 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
Yeah... god dude the manifold sizes are so different. god.. can't wait. but. where am i putting the new coolant line? the line i see goes down into the tranny..
wheres the coolant return line??
Logged
Mod time ;)
February 21, 2008, 11:56 AM | #5 |
reivaxtorres
Trade Count:
( +1)
SN95 Veteran
Offline
it doesnt go into the trans. it goes to a bracket behind the drivers side head, and then from there it turns into a rubber hose that goes into the heater core. i think the metal tube you are talking about is the EGR tube, and that one goes into the manifold look at this pic of my car, its the shiney black tube with the ford inventory stickers on it: http://i13.photobucket.com/albums/a267/ender03/Re-sized%20Photos/Picture061.jpg
Logged
February 21, 2008, 11:57 AM | #6 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
well ok.. ok.
but why do you have to change that.. i don't understand why you have to change it. is their a problem with keeping that line on there.
Logged
Mod time ;)
February 21, 2008, 12:02 PM | #7 |
DropTopPony
Global Moderator
Trade Count:
( +2)
SN95 Veteran
Offline
well ok.. ok.
The PI Intake is much deeper so that line needs to be routed around the intake runners.
Logged
February 21, 2008, 12:07 PM | #8 |
reivaxtorres
Trade Count:
( +1)
SN95 Veteran
Offline
well ok.. ok.
The PI Intake is much deeper so that line needs to be routed around the intake runners. yup, what he said. the NPI line runs directly under the intake manifold. with bolt of them side by side, you can see how the PI one is much deeper than the NPI one (and thus will go deeper into the cylinder valley). the NPI coolant tube would stop it from going any deeper than the NPI manifold, so the coolant tube needs to be routed around the intake manifold rather than directly under
Logged
February 21, 2008, 12:11 PM | #9 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
well ok... heres the next quesiton. what the best way to pull that line off without taking the water pump off. if thats even possible...
Logged
Mod time ;)
February 21, 2008, 12:23 PM | #10 |
DropTopPony
Global Moderator
Trade Count:
( +2)
SN95 Veteran
Offline
Since you have a 98 you might not need to swap nipples on the water pump so that may save you some time. Did you buy a New PI nipple?
Logged
February 21, 2008, 12:29 PM | #11 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
no i sure didn't... i'm getting very aggrivated very fast.. but trying to stay calm.
were taking off the bracket for the metal line right now. and were going to try a hammer and crowbar meathod to get it of. otherwise i'm going to get a torch and cut it and put the new heater hose on.
trying to stay cool...
Logged
Mod time ;)
February 21, 2008, 12:32 PM | #12 |
reivaxtorres
Trade Count:
( +1)
SN95 Veteran
Offline
lol, dont use a hammer. there are 2 bolts (13mm if i remember right) that hold the bracket to the back of the head. with patience, you get these off. the new PI return tube only uses one of those 2 bolts, so be happy you dont have to install bolt the bolts back in. if you have one of those ratcheting wrenches, they work even better. once those 2 bolts are removed, the tube just slides out from behind the water pump.
Logged
February 21, 2008, 12:48 PM | #13 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
thanks for everyone's help so far...
revi - i don't have a pi return line. aaron told me a lil while back to get 5/8s heater hose. and jr also said that would work too. so thats the meathod i'm going to do... and i just snapped one of my coolant sensors. but luckilaly one of my friends has a 96 gt i'm going to take it off of that doens't run right now...
so i was just going to use the heater hose. and reroute it..
i'm just taking it slow trying not to get pissed off...
update <-- having trouble getting that bottom bolt on the bracket for the return line. one of my friends went to the store to get a 13mm rachet wrench..
« Last Edit: February 21, 2008, 01:08 PM by Willis_98GT »
Logged
Mod time ;)
February 21, 2008, 02:21 PM | #14 |
Get Money
Trade Count:
( 0)
SN95 Veteran
Online
HighDefJunkies.com
i believe they both are not 13's... I'm pretty sure the other one is a 10..
Logged
February 21, 2008, 02:26 PM | #15 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
si vis pacem, para bellum
i wish i could remember but i cant, lmao.
Logged
46STANGS.COM Global Mod :TJ: 1997 Crystal White Cobra - few things 2004 Mach 1 - Totaled by an idiot 1998 Mustang GT RIP - scammed out of on 12/13/2008 1991 Mustang LX Notch - sold, wont be missed either
February 21, 2008, 02:28 PM | #16 |
Get Money
Trade Count:
( 0)
SN95 Veteran
Online
HighDefJunkies.com
i can almost guarantee it is a 10mm...
Logged
February 21, 2008, 02:30 PM | #17 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
i know one of em is a serious PITA to get too.
Logged
February 21, 2008, 02:43 PM | #18 |
February 21, 2008, 02:56 PM | #19 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
one was a 13 and one was a ten... i'm so excited guys... i just got the new manifold on and i'm starting to piece everything back together. :dancing6:
Logged
Mod time ;)
February 21, 2008, 02:59 PM | #20 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
make sure you didnt scrape the rtv when slidin the intake on. also give it plenty of time to cure...ill be fixin my mistake this weekend when i do my suspension
Logged
February 21, 2008, 03:14 PM | #21 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
About how long do you think i should let it sit or cure in terms of the silicon.
Logged
Mod time ;)
February 21, 2008, 03:16 PM | #22 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
at least a few hours(1-2) i think the reason i had problems is cuase when i put the intake on it scraped the rear port RTV and didnt get a good seal. some people have fired it right up and had no leaks, some people swear it takes 8 hours. 1-2 should work well
Logged
February 21, 2008, 04:00 PM | #23 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
its done.. !!!!!!!!!!!!!!!!!!!!!!!!!!
just put my cai back on and i'm fully done...
i just hope that everthing sealed correctly.
~Will
Logged
Mod time ;)
February 21, 2008, 04:02 PM | #24 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
congrats man! you will enjoy the extra bit of pull up top
Logged
February 21, 2008, 04:31 PM | #25 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
well. i did a very fast test fire.. just to make sure that it fired. and i immediately killed it. turns out that their was a louder then normal whistle. i mean i don't know if its bad or not. but i'm just sayin that i immediately noticed it...
so i'm happpppppppppppppppppppppppppppppppppy
Logged
Mod time ;)
February 21, 2008, 04:32 PM | #26 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
mine actually got a little quieter, but i dont have a CAI, just a K/N
Logged
February 21, 2008, 04:37 PM | #27 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
I got bbk intake.
Ok i think i just found the problem, 2 screws were just found lose on the manifold.
Logged
Mod time ;)
February 21, 2008, 04:45 PM | #28 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
the back 2 correct? lol. i left those loose at first too
Logged
February 21, 2008, 04:47 PM | #29 |
J.R.
The Postmaster General
SN95Forums Sponsor
Trade Count:
( 0)
SN95 Veteran
Offline
Forum Meanie Head
Get em tightened, then leave it be overnight. hopefully you don't have anywhere to go first thing in the morning? That way you can check it over and everything.
Logged
February 21, 2008, 04:48 PM | #30 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
or you can do like i do and have to refill the reservoir every week or so, lmao
Logged
February 21, 2008, 06:58 PM | #31 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
i got all the bolts tightened up. and did a quick test fire. and it sounded good. still a little whistle.. like a vaccume line. but i went over those like 3 or 4 times.. so i'm clueless... i didn't drive the car and it wasn't running for any longer then 3 seconds. and i only fired it 3 times. i left my car in my friend's garage to sit until i get off work tomorrow night. then i'll try to take it out. god damn i'm so excited.. the back 2 correct? lol. i left those loose at first too
lol yeah.. how ironic Get em tightened, then leave it be overnight. hopefully you don't have anywhere to go first thing in the morning? That way you can check it over and everything.
i'll just wait until i get off tomorrow night jr. gives it all the time it should need to cure right??
Logged
Mod time ;)
February 22, 2008, 03:02 AM | #32 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
should be good to go
Logged
February 22, 2008, 05:47 AM | #33 |
Willis_98GT
Trade Count:
( +2)
SN95 Veteran
Offline
well i'm going to drive it tonight when i get off of work. i'm so excited... guess we'll see how it holds up
Logged
Mod time ;)
February 22, 2008, 06:08 AM | #34 |
reivaxtorres
Trade Count:
( +1)
SN95 Veteran
Offline
i let the RTV cure for as long as it took me to get everything put back on, then fired it up for about 5 minutes, checked for leaks, drove it down the block slowly, checked for leaks, made a right turn to the stop sign, and then redlined 1st, 2nd, and 3rd gear, checked for leaks, then hopped onto the freeway and redlined 1-4th gears. no leaks :hammer:
Logged
