February 22, 2008, 09:39 AM | #0 |
1996mustangGT
SN95Forums Supporter
Trade Count:
( +6)
SN95 Veteran
Online
boost-bound
anyone have it? also whats the drop (if any) on it? thanks timothy
Logged
 1996 GT: 1 of a SH*T -ton of black GT's made. Built, Forged, Cammed, Ported etc 5.4L 1966 GT:4brrl holley carb, hi-po intake and cam 23K original miles -FOR SALE Build Thread: http://sn95forums.com/index.php/topic,42150.0.htmlif they did something wrong up north, i couldnt see it, as I was laying on my back with a tranny between my legs
February 22, 2008, 03:03 PM | #1 |
ryclef331
If it don't make dollars, it don't make sense
Technical Moderator
Trade Count:
( +2)
SN95 Veteran
Offline
94-95 Tech Moderator
I have it...
Little to no drop in the front. 1/2" in the back...
Logged
 94 Mustang GT 10.88 @ 125mph (LSx Swap in Progress. OH Noes!1!1!) 04 Ram 3500 Cummins Turbo Diesel 14.55 @ 101mph
February 22, 2008, 05:36 PM | #2 |
94 DropTop
Trade Count:
( 0)
SN95 Veteran
Offline
Forum Wookie
i just ordered my steeda kit today. WOOT
Logged
 If you like it buy it, thats how i do it. I take what people say on the internet as valued opinions but if i want something i get it.
When Handz made a steering wheel out of pink dildos we were all like hey man if it feels good in your hand then go for it.
February 23, 2008, 03:13 AM | #3 |
1996mustangGT
Trade Count:
( +6)
SN95 Veteran
Online
boost-bound
okay so i guess my underlying question is if i get the pro kit or H&R's are they going to negatively affect my ET later down the line ta all?
Logged
February 23, 2008, 06:09 AM | #4 |
94 DropTop
Trade Count:
( 0)
SN95 Veteran
Offline
Forum Wookie
will they do ya any good? NO any lowering spring except coilovers should hurt your et's. You want your front end to travel, when you put a shorter spring aka lowering spring on it shortens the amount it can travel.
Logged
February 25, 2008, 05:33 AM | #5 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
si vis pacem, para bellum
actually a stiffer spring in the rear can help launch by plantin the rears harder. to a point of course. lol. this only applies if you are runnin a slick tire.
Logged
46STANGS.COM Global Mod :TJ: 1997 Crystal White Cobra - few things 2004 Mach 1 - Totaled by an idiot 1998 Mustang GT RIP - scammed out of on 12/13/2008 1991 Mustang LX Notch - sold, wont be missed either
February 25, 2008, 06:47 AM | #6 |
Stangbangin
Trade Count:
( 0)
shiftin thru 4th
Offline
so he read on the internet
Logged
balanced/ blueprinted 306 all forged internals. Fully ported Alum. Trick Flow's. Mac cai, Trick Flow Upper and lower, MAC longtubes, MAC prochamber, flowmaster dump's. rebuilt t5,3.73 gears, Dynotune Nitrous 2 Stage kit 50 hp dry (launch), 200hp wet, KYB AGX adjustable struts, Tokico blues, MAC lower control arms, MM Subframe Connectors, BBK 1 1/2 lowering springs, MM stb, MEGASQUIRT ecu,
Future Mods: WELD PROSTARS, and new paint, 393 stroker with same heads and intake as current set up. Run at the track with new nitrous set up.
February 25, 2008, 08:24 AM | #7 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
^ lmao
Logged
February 25, 2008, 08:36 AM | #8 |
tRaV_19
Trade Count:
( 0)
SN95 Veteran
Offline
You gotta love the snake
from what i have been reading around on the net lowering springs in general do hurt your e.t. the drag bags and stuff can help by what southerngun said it wont compress the spring so much and helps to really plant that tire
Logged
~ tRaV Stangs: 99 cobra / 94 GT Coupe
February 25, 2008, 08:39 AM | #9 |
xsoutherngun89x
The Stigs evil twin
Trade Count:
( 0)
SN95 Veteran
Offline
i mean, yea 2 in drop spring will hurt your et cuase they arent designed to actually improve the suspension. the super race springs i ordered/installed only drop 1 1/4 in to 1 1/2 in. just right for looks and performance. its not a drag spring but the stiffer rate really helps the tire plant hard
Logged
February 25, 2008, 03:23 PM | #10 |
Stangbangin
Trade Count:
( 0)
shiftin thru 4th
Offline
well I've read alot that drop springs will hurt et's. I wasn't meaning to diss him but its a common misnomer. I guess in theory they hurt et's but every stang I've worked on or owned thats run without a drop then with a drop there was little to no loss in trap speed or et's. BUt then these were sane drops like 1 to 1.5". I think if you get dropzone 2 inch drop or more it probably would. As long as you have the ability for weight transfer. If you slammed so low your control arms are already articulated to the max then they can't do their job very well. In stock form they don't do it very well in the first place. So really theorical they hurt et's in reality they really don't.
Logged
February 25, 2008, 11:22 PM | #11 |
ryclef331
Technical Moderator
Trade Count:
( +2)
SN95 Veteran
Offline
If you are looking to gain good 60 ft times....save your money and hold off on the springs. Your money is spent bender else where. a mild drop isn't going to hurt too much on a bolt on car with good tires but eventually you're going to hit "the wall" where your drop springs DO start to hurt. Put it this way...I've had frinends with stock GT springs cut one coil cut 1.50 60 fters with drag radials. You CAN get the stance you want and cut good times...it IS a sacrifice BUT you CAN have your cake AND eat it too.
Logged
February 26, 2008, 06:50 PM | #12 |
94 DropTop
Trade Count:
( 0)
SN95 Veteran
Offline
Forum Wookie
sorry i wasnt clear i was refering to front springs.
Logged
February 26, 2008, 07:10 PM | #13 |
Paul
Undersecretary for GoFuckYourself
Global Moderator
Trade Count:
( +24)
SN95 Veteran
Offline
Shadetree Mechanic
I've seen 1.58 short times for Eibach Pro rear springs and coilovers up front.
Logged
February 27, 2008, 07:33 AM | #14 |
1996mustangGT
Trade Count:
( +6)
SN95 Veteran
Online
boost-bound
i dunno i just got ahold of some money and wanted to drop the car... so if a 1.5" drop isnt gonna hurt then its gonna happen
Logged
February 27, 2008, 10:16 AM | #15 |
Steven
The voice of the reason
Trade Count:
( 0)
SN95 Veteran
Offline
For the Pursuit of Speed
I have H&R Super sports.. stock swaybars, MM LCA's. Dead sit still and footbrake stall it, the car transfers very well.. much better then my eibachis
Logged
