Welcome, Guest. Please login or register.
Pages: [1]   Go Down
  Print
Author Topic: How-To: Cut and Loom Your Own Spark Plug Wires to the Perfect Length  (Read 2487 times)
0 Members and 1 Guest are viewing this topic.
timeNovember 30, 2008, 10:51 PM #0
Paul
Undersecretary for GoFuckYourself
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
Over the years I've made up lots of plug wire sets for myself and friends of mine. It can help give your motor that extra little attention to detail that can set it apart from everyone else, and give it a nice clean look.
In this article I'll show you step-by-step how to do this. It's pretty simple, and just takes a little time and patience. Of course, you'll need to go out and buy another special tool for this job. Here's what you'll need to pull this off:
  • A pair of medium-size wire cutters
  • A pair of pliers
  • A special spark plug terminal crimping tool
My crimping tool is from MSD - Part Number 3505.  This is available from lots of places on the internet; just type the PN into www.froogle.com and pick your merchant. cheesy This is a great professional-quality crimper. You can also buy all kinds of jaw inserts for many other types of crimping applications. The tool is shown below.
I used some FRPP wires because they were the right color, and the right price. cheesy I removed all the lettering on them with brake cleaner and a towel. These are great wires, but they come a bit long and I wasn't satisfied with the fitment. Since these wires already had ends on them, I had to cut them off and install some new ones I picked up from a local performance shop.
Lots of plug wires are available from manufacturers like MSD, Taylor, Moroso, LiveWires, etc. Many of these companies offer kits without the terminals installed so you can cut and crimp them to fit your motor perfectly. That's what we're going to do in this article.
So down to business... You need to mock up all your spark plug wires in their respective locations. Starting at the post marked #1 on the distributor cap and moving counter-clockwise, the order is 1-3-7-2-6-5-4-8. You can mark the cap with a sharpie or scratch the numbers in with an awl if it helps you.
Here are my passenger side wires loose.
...and the driver side wires just after I started looming them with zip ties.
Since I don't have tons of money for fancy billet plug wire separators, I just use zip ties. It may not be as fancy but it comes out looking pretty clean and it's a lot cheaper! Simply wrap a medium size zip tie around the plug wires, and then a smaller one goes around the medium one between each plug wire.
Starting from the spark plugs, carefully loom up the plug wires moving toward the distributor so they fit exactly how you like them.  You'll have a bunch of wire hanging over at the distributor cap, but that's okay - we'll fix that later.
Here's what mine looked like when I was done looming up the passenger side.
Now you need to starting cutting the plug wires to length and installing the new terminals. As I mentioned earlier, I used FRPP wires which already have ends installed. You can simply pull the rubber boot off the end that attaches to the distributor and it will look like this.
If you want, go ahead and snap it onto the distributor so you can see how they fit.
Here are the new terminals I picked up.  I think these are from MSD.  These are the correct ones for the distributor end of your 5.0 Ford. If you're making wires for a different kind of car, make sure that you get the correct terminals for your application.
Now that your plug wires are loomed up and you've got your terminals ready, you can mock up the wires on the distributor cap and cut them to length. In this picture, the left wire (which I'm holding) is going to the "bottom" exposed post, and the wire right next to it is going to the post above it. Use your wire cutters to cut the plug wire about 1/2" past the terminal.
Then put the cut wire in your crimping tool, and strip off the insulation with the cutting part of the tool with a hole in it.
Once the insulation is stripped, it will expose the actual wire that conducts spark to your spark plugs. It will look like this:
Now fold that wire over back onto the insulated part of the plug wire, and put the new terminal loosely on the end. I always "pinch" the new terminal a little bit with some pliers first - but only just enough so that it is snug and will hold itself onto the plug wire. Here's what it should look like:
Here's a somewhat blurry picture from the side:
You can re-check your fitment by mocking up the plug wire on your distributor, and make any adjustments as necessary.
Once you're satisfied with the fit, go ahead and put the end of the wire with the terminal on it into your crimping tool. The closed end is on the bottom of the tool with the round surface, and the open end goes up toward the part of the tool with the small point in the middle.
Now just squeeze the handle on the tool, and it will be crimped.
All you have to do now is put the rubber boot back on with the open end of the terminal pointed toward the open end of the boot. Make sure you get it lined up right before pushing it back into the boot. I usually use a quick spray of WD40 to make them go in easier.
Now just repeat that seven more times for the plug wires, and twice on the ignition coil wire (both ends) and you're done! Here's what my wires looked like all done:
You're done! Great job! Now you can charge your friends to do this for them to help pay for the cost of the crimping tool!! cheesy Plus you'll have the cleanest plug wire setup on the block.
Paul.
« Last Edit: December 26, 2008, 05:06 PM by Paul » Logged
timeDecember 01, 2008, 03:14 AM #1
SN95Forums Supporter
Trade Count: (+2)
SN95 Veteran
Online Online
formerly known as DESERTCOX05
another great job.
Logged
95 GT. bright blue. eibach lowered, adj. upper rear control arms, sub frame connectors, 4:10\'s, alumnium drive shaft, bbk shorty headers, & off-road h-pipe, pypes violator cat back, smoked tails w/ 3rd bar illumninated. bone stock motor.(for now) wheels-anthracite bullets 275/40-17 rear, 245/45-17 front. 98 cobra hood
timeDecember 01, 2008, 09:49 AM #2
Dr Fildo
Trade Count: (0)
revving engine
Offline Offline
Didn't even think to do this, but it looks so easy.  And the zip tie tip is priceless!
Logged
-Fil
timeDecember 01, 2008, 10:15 AM #3
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
Zip ties rule! cheesy
Logged
timeDecember 01, 2008, 12:16 PM #4
fixthedoor
Trade Count: (0)
SN95 Veteran
Offline Offline
You are missing the proverbial disclaimer about doing this at your own risk, yada yada.
Good write up. The info on the zip tie wire looms and wire stripping was nice to see.
« Last Edit: December 01, 2008, 03:05 PM by fixthedoor » Logged
timeDecember 01, 2008, 12:26 PM #5
Dalamar
Handsome Man-about-town
Administrator
Trade Count: (+6)
SN95 Veteran
Offline Offline
Boom Baby!
Great write up Paul, with pics and helpful tips!
What's with that funny motor that's all gray and shiny?
do you know what the difference is, if any, on coil pack wires?
Logged
Donkeys kill more people annually than plane crashes or shark atacks, so watch your a*s!
timeDecember 01, 2008, 12:38 PM #6
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
It's mostly just a garage ornament.  Neato but useles..
Quote
Sorry Jeff, I have no idea how the coil pack stuff works.  I've never really worked on a modular in my whole life.  You need to get a 94-95 so I can be more helpful. cheesy
Paul.
Logged
timeDecember 01, 2008, 05:05 PM #7
Trade Count: (+2)
SN95 Veteran
Online Online
it sure is pretty but it doesn't go in a sn-95
Logged
timeDecember 01, 2008, 05:20 PM #8
idro
Trade Count: (0)
redlining 1st
Offline Offline
thanks for explaining the ziptie trick man, i will use it this week when i am putting my motor back together.  occasion14
Logged
timeDecember 01, 2008, 07:18 PM #9
94 DropTop
Trade Count: (0)
SN95 Veteran
Offline Offline
Forum Wookie
So why arent all your post stickey'd?
Logged
If you like it buy it, thats how i do it. I take what people say on the internet as valued opinions but if i want something i get it.
When Handz made a steering wheel out of pink dildos we were all like hey man if it feels good in your hand then go for it.
timeDecember 01, 2008, 07:24 PM #10
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
I'm eventually going to organize all of this stuff into a tech article section on the main page.  All of it will be in PDF format so people can print out the articles and use them in the garage.  I'm also working on getting the forums re-arranged a bit so stuff is easier to search and find for everyone.  I have lots of broken cars so there's plenty to do. LOL
Logged
timeDecember 01, 2008, 07:41 PM #11
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
That ziptie awesome is a helluva a lot cleaner looking than anything i've seen so far
Logged
timeDecember 01, 2008, 07:46 PM #12
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
Haha, I know right?  I can't tell you how many people how asked me how I did that.  They were pretty surprised when they found out it was fifty cents worth of zip ties. LOL
So now, I give my super mystery solution to all of you, my SN95 homies. cheesy
Paul.
Logged
timeDecember 01, 2008, 08:09 PM #13
BlkoutGT
Trade Count: (0)
Speedo Pinned in 5th
Offline Offline
Awsome write up man! the zip ties are just too easy  occasion14
Logged
timeDecember 02, 2008, 12:53 PM #14
Win
Hustling
Trade Count: (+20)
SN95 Veteran
Offline Offline
Formerly 95convGT
Great Writeup this should be a sticky
Logged
06 Mazdaspeed 6
03 Kawasaki ZR1000
Then the beast 94 GT
Win=Paul.
Quote from: The Stig
The Stig is worth 20+ hp easy.
Quote
life is much more manageable when thought of as a scavenger hunt as opposed to a surprise party.
Jimmy Buffett
timeDecember 02, 2008, 03:13 PM #15
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
Paul.
Its nice that I have a giant can of them too. I've seriously been tryin to figure out what to replace my blue ford ones with since I'm about to get red wires and the blue would look weird... thats perfect... I'm either gonna do this or paint the ones I have glossy black.... who knows?
Logged
timeMay 18, 2009, 08:18 PM #16
fastgtfairlane
Trade Count: (+1)
SN95 Veteran
Offline Offline
ive custom cut many a set of plug wires. i dont have a crimp tool just not quite as easy to bend the terminals with out them. thats why ive never burned a set with my equal lengths. plus shorter wires equals less resistance to the spark plugs. also, i try to make every wire as close to the same length as possible to make every cylinder equal for maximum efficiency
Logged
94 gt stock block, stock heads, typhoon upper lower, 65mm throttle body, 24lb inj, cai, c&l 76mm mass air, mac overdrives, msd 6a, bbk equal length shorties, off road x pipe, spintech prostreets mufflers. 98 cobra rims
timeJune 17, 2009, 07:55 PM #17
5.Woahhh
Trade Count: (+2)
SN95 Veteran
Offline Offline
Though I am driving a Mod motor now, great write up Paul. That motor is sex.
Logged
Past Rides:
1992 Subaru Legacy (Ran into back of BMW)
1996 Laser Red Coupe (Shoved into median)
1995 Crystal White Vert(Rear eneded by someone on an iPhone)
1996 Bright Tangerine Coupe (SOLD)
Current Ride:
2002 Solar Yellow Nissan Xterra: The TONKA Truck
Future Ride:
87-93  Notchback with 4v swap.
timeJune 17, 2009, 09:46 PM #18
sxynerd
Trade Count: (+4)
SN95 Veteran
Offline Offline
SN95forums Rock!
Good write up.  I tried cutting up my stock wire but nothing good came of it. lol.  Stupid Modulars, lol.
Logged
Si Vis Pacem, ParaBellum
timeJune 26, 2009, 10:27 AM #19
Lwiss
Trade Count: (0)
revving engine
Offline Offline
WWW
the results are very nice! thanks for the how-to thread!
Logged
94 GT
timeJune 26, 2009, 02:31 PM #20
5litrarag
Trade Count: (+1)
shiftin thru 4th
Offline Offline
Thanks for that Paul... I just got all the supplies and did the wires on the Cobra last weekend.
They didn't come out quite perfect like yours and a couple of them I plan to trim again, but it looks better than it did before and definetly isn't bad for a first timer.
When I get ready to put the stroker motor back in the Oinker I'll be doing it again and expecting better results.
Logged
95 Gt Vert a.k.a "The Pig" N/A 342 stroker
95 Cobra coupe
Rotrex Supercharged
09 Pontiac G8 GT
The new victim....
http://socalhorsepower.com/
timeJune 26, 2009, 03:25 PM #21
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
Glad you tried it out man.  Sometimes it takes a couple of tries to get stuff perfect - I've done about a zillion sets of wires so I'm pretty good at it now.  After you've cut all your wires and loosely installed them, you can zip-tie them starting at the distributor and moving your way back to the headers.  That way, all the slack from cutting a bit too long or short will get soaked up by the bend in the plug wire just before the spark plug. grin
Paul.
Logged
timeJune 28, 2009, 09:14 PM #22
5litrarag
Trade Count: (+1)
shiftin thru 4th
Offline Offline
Here's a couple pics of my results...
Logged
95 Cobra coupe
Rotrex Supercharged
09 Pontiac G8 GT
The new victim....
Pages: [1]   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
Which spark plug wires?
96-04 - 2V Specific
blown97stanger 7 565 Last post March 06, 2007, 11:05 AM
by quickstang_1994
POLL - Spark Plug Wires
.:The Garage:.
GDawg 27 696 Last post August 17, 2009, 09:05 AM
by MikeF
Spark Plug Wire - VISION Motorworks 10.2mm Racing spark plug wires
96-04 - 2V Specific
Sir Charles 2 337 Last post August 02, 2007, 02:25 AM
by bert96
spark plug/ wires question
GENERAL TECH
1996mustangGT 12 302 Last post April 14, 2008, 07:41 AM
by Paul
When To Replace Spark Plug Wires?
GENERAL TECH
SRT Handz 2 157 Last post December 24, 2008, 07:20 AM
by GDTrumbo
sn95 & 5.0 parts (gauges, spark plug wires, tail light harnesses)
CLASSIFIEDS
sbr420a 11 548 Last post May 13, 2009, 09:11 PM
by Mustanger
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
