Welcome, Guest. Please login or register.
Pages: [1] 2 3 4 5 ... 12   Go Down
  Print
Author Topic: 1966 Coup 4.6 4V Swap updated 8/22/10  (Read 8232 times)
0 Members and 1 Guest are viewing this topic.
timeDecember 09, 2008, 05:42 PM #0
uncltrvlnmatt
Sn95 Forums Mayor
SN95Forums Supporter
Trade Count: (+4)
SN95 Veteran
Offline Offline
Figured I would start a new thread since the old one was lost. For those of you who don't know I am installing a 2003 Maqch1 engine into my 1966 Mustang Coup. I will be useing the engine, trans, and rear. I will eventually be installing an Eaton on top.
This is what the car looked like before the restoration process began.
This is what the car looked like at the beginning of the 4.6 install.
Installing the Mustang 2 front end from Rod and Custom Motor Sports.
Shock towers removed.
New crossmember installed.
Upper and lower control arms, coil overs, and rack and pinion steering installed.
Rotors and steering shaft installed.
« Last Edit: August 22, 2010, 05:07 AM by uncltrvlnmatt » Logged
97 Cobra 715 of 6961 1of 815 Crystal White w/ Black Leather int. Born 10/3/96 MSD Blaster Coils King Cobra Clutch 3:73 gears 258RWHP 250RWT
1966 Coup 4.6DOHC swap under way
Undeniable Truth Of Life #29
Liberals measure compassion by how many people are given welfare. Conservatives measure compassion by how many people no longer need it. Rush Limbaugh
timeDecember 09, 2008, 05:49 PM #1
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
The Donor car.
Removing the monster.
Stripping the donor car.
Logged
timeDecember 09, 2008, 05:59 PM #2
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Fitting the Mach engine into the Coup.
Logged
timeDecember 09, 2008, 06:01 PM #3
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
The engine has now been pulled back out of the car and is on its stand. We have some minor repairs to do inside the engine bay with the frame rails. My welder has seen how it s going to sit and is ready to weld in the motor mounts when we get the minor repairs done.
Logged
timeDecember 09, 2008, 06:19 PM #4
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
Hurry up already! Jeez, I'm gonna die before you ever get done. lmao
Still one of the coolest projects on the site.
I love old cars.
Logged
timeDecember 10, 2008, 03:23 AM #5
CC'S95GT
Trade Count: (+2)
SN95 Veteran
Online Online
formerly known as DESERTCOX05
i was wondering about the progress. that car is going to be insane
Logged
95 GT. bright blue. eibach lowered, adj. upper rear control arms, sub frame connectors, 4:10\'s, alumnium drive shaft, bbk shorty headers, & off-road h-pipe, pypes violator cat back, smoked tails w/ 3rd bar illumninated. bone stock motor.(for now) wheels-anthracite bullets 275/40-17 rear, 245/45-17 front. 98 cobra hood
timeDecember 10, 2008, 04:26 AM #6
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I had to take a brake from doing anything due to buying a house and prepping my old house for a renter. I now have a tenant in the house and I am getting back into the groove of getting it done. It turned out to be about a 4 month layoff.
Logged
timeDecember 10, 2008, 01:27 PM #7
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
Something I've been wondering, are you gonna keep the shaker hood scoop?
Logged
timeDecember 10, 2008, 01:48 PM #8
BigJohnsonDOHC
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
same here
Logged
2003 Mach 1
- SLP LM1, KN intake, subframe connectors, UPR catted x pipe
timeDecember 10, 2008, 03:31 PM #9
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
That has been under discussion from the begining. We have talked about it(me and my dad). My dad wants to use it. I want the Eaton. It is my car and I will make the final choice. As of right now it is still up in the air. I don't want to cut the hood then go with the Eaton. But the Eaton will not be going on right away, I have about 80% of the parts for the Eaton install. But right now my main concern is getting it up and running.
But to answer the question, most likely yes.
Logged
timeDecember 10, 2008, 04:36 PM #10
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
Eaton > Hood scoop.
But I'm not gonna lie, a shaker scoop would be bad on that car.
Logged
timeDecember 10, 2008, 07:09 PM #11
BigJohnsonDOHC
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
alot of guys who run the eaton on machs will still have the scoop just non functional, so if you want you could have both?
Logged
2003 Mach 1
timeDecember 11, 2008, 04:19 AM #12
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
That would depend on how high the engine sits in the engine bay.
Logged
timeDecember 21, 2008, 05:56 PM #13
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I spoke to my welder today. I have a tentative date of next sunday to start welding in the engine mounts. Todat I made the sway bar spacers and installed them. I also installed the right rear window track, window, window regulator and window fuzzies. It is not much but very time consuming, considering I had to figure out how it goes together because it was removed 20 years ago. But all forward progress is good.
Logged
timeDecember 29, 2008, 04:02 AM #14
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Yesturday I cut out the old frame rail pieces and fitted the new pieces into place. My welder is supposed to come on wednesday and weld them into place.
Here is a pic of the window installed from last week.
Frame repairs, we were originally going to just do a quick patch. But then I decided to replace the bad section. The rails were inexpensive at about $35.00 each so it was a better choice, it will look so much better.
I could not replace the complete frame rail due to having the sub frame connectors already welded into place. So I just cut out the bad section and fitted the new section into place. I left the good section of the old rail inplace so the car will have a double frame rail for about 4 inches where the unibody comes together.
The new section fitted into place on the left side.
Right side.
Logged
timeDecember 29, 2008, 02:22 PM #15
5.Woahhh
Trade Count: (+2)
SN95 Veteran
Offline Offline
I want this to be done ASAP!
Logged
Past Rides:
1992 Subaru Legacy (Ran into back of BMW)
1996 Laser Red Coupe (Shoved into median)
1995 Crystal White Vert(Rear eneded by someone on an iPhone)
1996 Bright Tangerine Coupe (SOLD)
Current Ride:
2002 Solar Yellow Nissan Xterra: The TONKA Truck
Future Ride:
87-93  Notchback with 4v swap.
timeDecember 29, 2008, 02:25 PM #16
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Hoping to be done in the late spring, early summer. The Pa. Mustang Club has a big show at the end of July. I want to be there.
Logged
timeDecember 30, 2008, 06:07 PM #17
LaserRedSVT96
Trade Count: (0)
sitting in the driveway
Offline Offline
nice job thus far! i cant wait to see it completed.
Logged
timeDecember 30, 2008, 06:51 PM #18
CC'S95GT
Trade Count: (+2)
SN95 Veteran
Online Online
hey i just noticed you have a gadsen flag on the wall in you garage. uber cool. i have the current navy jack
Logged
timeJanuary 05, 2009, 02:34 PM #19
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Did some fabricating yesturday, working on the trans mounts. It is not going to be the pain in the a*s I thought it was going to be. It will mount up right behind the original crossmember. We are going to weld in a 2x4 channel just behind the original. Here is what it will look like.
Here is the shifter mounted to the trans. In this pic the trans is in 3rd gear and I have about a quarter inch of clearance between the floor and the shifter. I can move the engine back atleast another inch for better clearance. But I will probably only move it back another quarter inch, if at all.
Logged
timeJanuary 07, 2009, 08:47 PM #20
BLCKSTNG96
Trade Count: (0)
redlining 1st
Offline Offline
sweet project.be careful with that eaton swap on that motor,the mach rods and pistons are not forged,just the crank seeing as is was a 5spd.
Logged
5.0 Stroker mod 950,fox lake stage 2+ heads,MPH blower cams,upr tubular frnt end,tremec 3550,quicktime bell,pypes lts,vrs xpipe,mac catback and a whole buncha other stuff
kenne bell 2.2 running 20psi currently being installed
timeJanuary 12, 2009, 08:08 AM #21
MikeF
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
man that is sweet you got me thinking of findind a 65-66 and swaping my 95 over to that car how much do you think your car will way
Logged
timeJanuary 13, 2009, 05:26 AM #22
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
We are not sure if we are going to install the Eaton yet. We are going to see what kind of traction issues we are going to have. I have a feeling this car is going to be plenty fast enough with out the Eaton. But if I do install the Eaton I have no intention of going over 8-9lbs of boost.
The 65-66 coupes weighed in at about 2800lbs. That is about 1000lbs lighter than the 03/04 Mach1. If I remember right they weighed in at about 3800lbs. That puts the car in mid 12 second range with basic bolt-ons.
« Last Edit: January 13, 2009, 05:28 AM by uncltrvlnmatt » Logged
timeJanuary 15, 2009, 09:15 PM #23
Mystikal
Trade Count: (0)
SN95 Veteran
Offline Offline
I was wondering how the progress was going on your project. Looks good man.
Logged
The artist formally known as 94darkhorse
timeJanuary 16, 2009, 05:20 PM #24
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Thanks, it is going to be way to cold to screw around in the garage this weekend.
Logged
timeFebruary 02, 2009, 04:19 PM #25
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I did some busy work yesturday. I finnished up cleaning the new rear crossmember area, and finnished up putting together my right side vent window. It is minor stuff, but it all adds up in the end.
Logged
timeFebruary 03, 2009, 07:11 PM #26
Mystikal
Trade Count: (0)
SN95 Veteran
Offline Offline
You gotta do it sometime, might as well be now.
Logged
timeFebruary 14, 2009, 08:46 PM #27
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
Sammich Club founder #1.. Down to smash a LS1
that my friend is f#cking sweet cant wait to see it done
Logged
Patrick...  Your March 10 ROTM
98 GT Pacific Green (PS/M6764)
I NEED A COBRA FRONT BUMPER
Dude you got a Cobra...
Yeah my dad made me get it...
Bro all Cobras have 32V's and are just bigger versions of the Vtec you really wanted...
Really? Thanks you are my bestest friend.
96_SVT_Cobra: cuz i got flashed by a 60 year old on a harley and was clinically dead for
timeFebruary 19, 2009, 08:17 PM #28
Mystikal
Trade Count: (0)
SN95 Veteran
Offline Offline
agreed! any new news on it?
Logged
timeFebruary 22, 2009, 09:12 AM #29
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I have not had much time to get work done lately. I am going to get down there next sunday (3/2) and get some work done. I will get with my welder to see if he can be there to start with the rear mounts.
It has been extremely busy since August with the new/old house stuff going on. I will be in Florida for work 3/9-3/13. Then in April I am going to Cancun 4/18-4/23. But I need to get cracking on this thing. My July deadline is fast approaching and at this point seems unatainable.
Logged
timeFebruary 23, 2009, 08:46 PM #30
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
you got this man. i would love to see that thing done by july kepp up the good work. hey how much did you pay for that mach i want the motor out of one for my next project
Logged
timeFebruary 24, 2009, 12:42 PM #31
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I paid 6k for it. That was last year at this time. The prices may have dropped a bit. I originally wanted a 03/04 Cobra, but they were asking 10k+ for them, and it would have eaten up to much of my budget.
Logged
timeFebruary 24, 2009, 08:41 PM #32
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
i here you on that the car looks good man. i want to put a DOHC in a 79-93 noch or a 94 - 98 cupe or vert
Logged
timeFebruary 24, 2009, 10:44 PM #33
Codycougar91
Trade Count: (0)
redlining 1st
Offline Offline
Cody
This car looks like a beast!
Logged
Mods: 18" Black FR500s, 10th Anniv. Cobra Brakes, Magnaflow Catback w/ MagnaPacks, Tokico Shocks and Struts, 2in. Drop, KN FIPK II CAI, Limo, MGW Short Throw Shifter, Smoked Headlights
timeMarch 16, 2009, 03:17 AM #34
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Finally got some work done yesturday. I pulled the rear end assembly out of the Mach. The car is pretty much completely striped of everything. Only the brake lines and fuel lines remain in the car, and I am going to yank them out to. Especially now that pops has a Mach, you never know what you might need.
Next time I go down we will give the car a once over, then make it go away. I forgot my camera, so no pics this time.
I talked to my welder. We have both been very busy lately and have had no time for welding in the mounts. But we are going to try in 2 weeks to get it done.
Logged
Pages: [1] 2 3 4 5 ... 12   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
My 1966 Coup
uncltrvlnmatt 12 614 Last post September 18, 2006, 09:11 PM
by DamieN
Just found This Pic Of My 1966 Coup
uncltrvlnmatt 3 284 Last post June 08, 2007, 01:59 PM
by uncltrvlnmatt
uncltrvlnmatt's Build Thread 1966 Coup 4.6 DOHC Build Up. Updated 10/19/08 Pics « 1 2 3 4 »
.:Build Up's & Projects:.
uncltrvlnmatt 125 2365 Last post August 25, 2008, 01:20 PM
by uncltrvlnmatt
Looking for a 96-98 GT coup.
WTB (Wanted)
nnforever 2 147 Last post June 15, 2009, 09:14 AM
by Willis_98GT
Updated pictures of the tail Swap.
Steven 6 243 Last post September 27, 2009, 06:20 PM
by MustangChris
1966 Coup Int Parts F/S
CLASSIFIEDS
uncltrvlnmatt 0 81 Last post January 09, 2010, 08:41 AM
by uncltrvlnmatt
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
