December 09, 2008, 05:42 PM | #0 |
uncltrvlnmatt
Sn95 Forums Mayor
SN95Forums Supporter
Trade Count:
( +3)
SN95 Veteran
Online
Now we can all nod our heads and make decisions
Figured I would start a new thread since the old one was lost. For those of you who don't know I am installing a 2003 Maqch1 engine into my 1966 Mustang Coup. I will be useing the engine, trans, and rear. I will eventually be installing an Eaton on top. This is what the car looked like before the restoration process began.  This is what the car looked like at the beginning of the 4.6 install.  Installing the Mustang 2 front end from Rod and Custom Motor Sports.  Shock towers removed.  New crossmember installed.  Upper and lower control arms, coil overs, and rack and pinion steering installed.  Rotors and steering shaft installed.
« Last Edit: March 14, 2010, 05:27 PM by uncltrvlnmatt »
Logged
 ] 97 Cobra 715 of 6961 1of 815 Crystal White w/ Black Leather int. Born 10/3/96 MSD Blaster Coils King Cobra Clutch 3:73 gears 258RWHP 250RWT 1966 Coup 4.6DOHC swap under way As Government Expands, Liberty Contracts. Ronald Reagan 12 Jan 1989
December 09, 2008, 05:49 PM | #1 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
Logged
December 09, 2008, 05:59 PM | #2 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
Logged
December 09, 2008, 06:01 PM | #3 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
The engine has now been pulled back out of the car and is on its stand. We have some minor repairs to do inside the engine bay with the frame rails. My welder has seen how it s going to sit and is ready to weld in the motor mounts when we get the minor repairs done.
Logged
December 09, 2008, 06:19 PM | #4 |
Trade Count:
( 0)
SN95 Veteran
Offline
Sammich Club #5
Hurry up already! Jeez, I'm gonna die before you ever get done. lmao
Still one of the coolest projects on the site. I love old cars.
Logged
 is the only wmm member to go from associate to full fledged bad a*s status
Beyotches don't know bout my White Mustang Mafia
December 10, 2008, 03:23 AM | #5 |
DESERTCOX05
Trade Count:
( +1)
SN95 Veteran
Offline
i was wondering about the progress. that car is going to be insane
Logged
95 GT. bright blue. eibach lowered, adj. upper rear control arms, sub frame connectors, 4:10\'s, alumnium drive shaft, bbk shorty headers, & off-road h-pipe, pypes violator cat back, smoked tails w/ 3rd bar illumninated. bone stock motor.(for now) wheels-anthracite bullets 275/40-17 rear, 245/45-17 front
December 10, 2008, 04:26 AM | #6 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
I had to take a brake from doing anything due to buying a house and prepping my old house for a renter. I now have a tenant in the house and I am getting back into the groove of getting it done. It turned out to be about a 4 month layoff.
Logged
December 10, 2008, 01:27 PM | #7 |
Trade Count:
( 0)
SN95 Veteran
Offline
Sammich Club #5
Something I've been wondering, are you gonna keep the shaker hood scoop?
Logged
December 10, 2008, 01:48 PM | #8 |
BigJohnsonDOHC
Trade Count:
( +1)
SN95 Veteran
Offline
same here
Logged
2003 Mach 1 - SLP LM1, KN intake, subframe connectors, UPR catted x pipe
December 10, 2008, 03:31 PM | #9 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
That has been under discussion from the begining. We have talked about it(me and my dad). My dad wants to use it. I want the Eaton. It is my car and I will make the final choice. As of right now it is still up in the air. I don't want to cut the hood then go with the Eaton. But the Eaton will not be going on right away, I have about 80% of the parts for the Eaton install. But right now my main concern is getting it up and running.
But to answer the question, most likely yes.
Logged
December 10, 2008, 04:36 PM | #10 |
Trade Count:
( 0)
SN95 Veteran
Offline
Sammich Club #5
Eaton > Hood scoop.
But I'm not gonna lie, a shaker scoop would be bad on that car.
Logged
December 10, 2008, 07:09 PM | #11 |
BigJohnsonDOHC
Trade Count:
( +1)
SN95 Veteran
Offline
alot of guys who run the eaton on machs will still have the scoop just non functional, so if you want you could have both?
Logged
December 11, 2008, 04:19 AM | #12 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
That would depend on how high the engine sits in the engine bay.
Logged
December 21, 2008, 05:56 PM | #13 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
I spoke to my welder today. I have a tentative date of next sunday to start welding in the engine mounts. Todat I made the sway bar spacers and installed them. I also installed the right rear window track, window, window regulator and window fuzzies. It is not much but very time consuming, considering I had to figure out how it goes together because it was removed 20 years ago. But all forward progress is good.
Logged
December 29, 2008, 04:02 AM | #14 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
Yesturday I cut out the old frame rail pieces and fitted the new pieces into place. My welder is supposed to come on wednesday and weld them into place. Here is a pic of the window installed from last week.  Frame repairs, we were originally going to just do a quick patch. But then I decided to replace the bad section. The rails were inexpensive at about $35.00 each so it was a better choice, it will look so much better.   I could not replace the complete frame rail due to having the sub frame connectors already welded into place. So I just cut out the bad section and fitted the new section into place. I left the good section of the old rail inplace so the car will have a double frame rail for about 4 inches where the unibody comes together.  The new section fitted into place on the left side.  Right side.
Logged
December 29, 2008, 02:22 PM | #15 |
5.Woahhh
Trade Count:
( +2)
SN95 Veteran
Offline
I want this to be done ASAP!
Logged
Bright Tangerine 96 GT Coupe: (Arielle) Steeda|Tokico|BBK|Flowmaster you could probably put hypercoated donuts on that car, and it would look good.
That looks 13% faster than the old setup.  Learned how to drive in MT winters, snow tires are for pussys.
December 29, 2008, 02:25 PM | #16 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
Hoping to be done in the late spring, early summer. The Pa. Mustang Club has a big show at the end of July. I want to be there.
Logged
December 30, 2008, 06:07 PM | #17 |
LaserRedSVT96
Trade Count:
( 0)
sitting in the driveway
Offline
nice job thus far! i cant wait to see it completed.
Logged
December 30, 2008, 06:51 PM | #18 |
DESERTCOX05
Trade Count:
( +1)
SN95 Veteran
Offline
hey i just noticed you have a gadsen flag on the wall in you garage. uber cool. i have the current navy jack
Logged
January 05, 2009, 02:34 PM | #19 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
Logged
January 07, 2009, 08:47 PM | #20 |
BLCKSTNG96
Trade Count:
( 0)
revving engine
Offline
sweet project.be careful with that eaton swap on that motor,the mach rods and pistons are not forged,just the crank seeing as is was a 5spd.
Logged
January 12, 2009, 08:08 AM | #21 |
MikeF
Trade Count:
( 0)
smoking 'em in 2nd
Offline
man that is sweet you got me thinking of findind a 65-66 and swaping my 95 over to that car how much do you think your car will way
Logged
January 13, 2009, 05:26 AM | #22 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
We are not sure if we are going to install the Eaton yet. We are going to see what kind of traction issues we are going to have. I have a feeling this car is going to be plenty fast enough with out the Eaton. But if I do install the Eaton I have no intention of going over 8-9lbs of boost. man that is sweet you got me thinking of findind a 65-66 and swaping my 95 over to that car how much do you think your car will way
The 65-66 coupes weighed in at about 2800lbs. That is about 1000lbs lighter than the 03/04 Mach1. If I remember right they weighed in at about 3800lbs. That puts the car in mid 12 second range with basic bolt-ons.
« Last Edit: January 13, 2009, 05:28 AM by uncltrvlnmatt »
Logged
January 15, 2009, 09:15 PM | #23 |
Mystikal
Trade Count:
( 0)
SN95 Veteran
Offline
I was wondering how the progress was going on your project. Looks good man.
Logged
January 16, 2009, 05:20 PM | #24 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
Thanks, it is going to be way to cold to screw around in the garage this weekend.
Logged
February 02, 2009, 04:19 PM | #25 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
I did some busy work yesturday. I finnished up cleaning the new rear crossmember area, and finnished up putting together my right side vent window. It is minor stuff, but it all adds up in the end.
Logged
February 03, 2009, 07:11 PM | #26 |
Mystikal
Trade Count:
( 0)
SN95 Veteran
Offline
You gotta do it sometime, might as well be now.
Logged
February 14, 2009, 08:46 PM | #27 |
US Soldier
Trade Count:
( +6)
SN95 Veteran
Offline
Sammich Club founder #1.. Down to smash a LS1
that my friend is f#cking sweet cant wait to see it done
Logged
Patrick... Your March 10 ROTM BAMF Mstang Mafia The WMM's Hitman www.sn95haven.com Febuary Stang of the month 98 GT Pacific Green (PS/M6764)  patrick's stang ftw! even if it's doodoo brown
what???!?!?! yes i can... you've never cleaned the cob-webs out of an old lady's basement? once you go gray, you never stray.... (Mustang Chris)
February 19, 2009, 08:17 PM | #28 |
Mystikal
Trade Count:
( 0)
SN95 Veteran
Offline
agreed! any new news on it?
Logged
February 22, 2009, 09:12 AM | #29 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
I have not had much time to get work done lately. I am going to get down there next sunday (3/2) and get some work done. I will get with my welder to see if he can be there to start with the rear mounts.
It has been extremely busy since August with the new/old house stuff going on. I will be in Florida for work 3/9-3/13. Then in April I am going to Cancun 4/18-4/23. But I need to get cracking on this thing. My July deadline is fast approaching and at this point seems unatainable.
Logged
February 23, 2009, 08:46 PM | #30 |
US Soldier
Trade Count:
( +6)
SN95 Veteran
Offline
you got this man. i would love to see that thing done by july kepp up the good work. hey how much did you pay for that mach i want the motor out of one for my next project
Logged
February 24, 2009, 12:42 PM | #31 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
I paid 6k for it. That was last year at this time. The prices may have dropped a bit. I originally wanted a 03/04 Cobra, but they were asking 10k+ for them, and it would have eaten up to much of my budget.
Logged
February 24, 2009, 08:41 PM | #32 |
US Soldier
Trade Count:
( +6)
SN95 Veteran
Offline
i here you on that the car looks good man. i want to put a DOHC in a 79-93 noch or a 94 - 98 cupe or vert
Logged
February 24, 2009, 10:44 PM | #33 |
Codycougar91
Trade Count:
( 0)
redlining 1st
Offline
Cody
This car looks like a beast!
Logged
 Mods: 18" Black FR500s, 10th Anniv. Cobra Brakes, Magnaflow Catback w/ MagnaPacks, Tokico Shocks and Struts, 2in. Drop, KN FIPK II CAI, Limo, MGW Short Throw Shifter, Smoked Headlights
March 16, 2009, 03:17 AM | #34 |
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count:
( +3)
SN95 Veteran
Online
Finally got some work done yesturday. I pulled the rear end assembly out of the Mach. The car is pretty much completely striped of everything. Only the brake lines and fuel lines remain in the car, and I am going to yank them out to. Especially now that pops has a Mach, you never know what you might need.
Next time I go down we will give the car a once over, then make it go away. I forgot my camera, so no pics this time.
I talked to my welder. We have both been very busy lately and have had no time for welding in the mounts. But we are going to try in 2 weeks to get it done.
Logged
