Welcome, Guest. Please login or register.
Pages: 1 2 [3] 4 5 6 7 ... 12   Go Down
  Print
Author Topic: 1966 Coup 4.6 4V Swap updated 8/22/10  (Read 8222 times)
0 Members and 1 Guest are viewing this topic.
timeApril 09, 2009, 05:05 PM #70
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
Do it, and get a video.
Logged
timeApril 09, 2009, 05:10 PM #71
uncltrvlnmatt
Sn95 Forums Mayor
SN95Forums Supporter
Trade Count: (+4)
SN95 Veteran
Offline Offline
If I do, I will.
Logged
97 Cobra 715 of 6961 1of 815 Crystal White w/ Black Leather int. Born 10/3/96 MSD Blaster Coils King Cobra Clutch 3:73 gears 258RWHP 250RWT
1966 Coup 4.6DOHC swap under way
Undeniable Truth Of Life #29
Liberals measure compassion by how many people are given welfare. Conservatives measure compassion by how many people no longer need it. Rush Limbaugh
timeApril 09, 2009, 05:19 PM #72
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
When I do, I will.
fix'd
Logged
timeApril 27, 2009, 03:10 AM #73
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I now have the pedal assembly in place. It is temporarily bolted in. I was able to install it pretty close to the stock position. I had to move the wiper motor mounting bracket over to the right, and I will have to modify the mounts. Now the clutch quadrant is free and clear. I had to do a slight modification to the steering shaft casing so the brake pedal does not hit the shaft.
The Hydroboost will be in almost the stock position. It will clear the fender apron by about a quarter of an inch, so I will have to go with "plan B" for the hood hinges.
This is the template I made for the hydroboost and where it will go.
The bracket on the right  side is the Wiper motor bracket. It was held in place by 4 bolts, not tack welded like I originally thought. So for now I moved it over using just the 2 right side mounting bolts. Just above the end of the pedal bracket you can see where the left side mounting bolt is, for it's original position. As long as the wiring is tied up out of the way, the quadrant is free and clear.
Here are the pedals bolted into position.
Here are the pedals with the steering column, you can see how tight a fit it is.
To remedy this minor inconvenience, I am doing some grinding to the steering column. This part is not quite done yet, (I ran out of time) and I may have to cut away part of the steering column outer shell. It is barely touching, but I need a bit of clearance.
Logged
timeMay 01, 2009, 08:33 PM #74
Mystikal
Trade Count: (0)
SN95 Veteran
Offline Offline
I'd clearance the steering column as well. Rather be safe than sorry, cause you don't want the peddle getting stuck up on it.
Logged
The artist formally known as 94darkhorse
timeMay 03, 2009, 09:09 AM #75
98saleen88
Trade Count: (0)
sideways into 3rd
Offline Offline
WWW
this is an awesome project..one of my friends just recently finished a 04 cobra motor in his fox....but i think it ways cooler to hav a resto-mod...
Logged
If You Can Turn, Your Not Going Fast Enough........Unless You Have A Saleen..............
1998 Saleen *88* 5.4 S/C Lightning Swap in process...
1967 Mustang Coupe...Some tasty outschool tricks...
1970 Olds Cutlass Post car..455...1 out of 104..needs total resto and will still stomp on a mustang (sorry guys)
Newest Editon-1977 Harley-Davidson XLH Sportster 1100, S&S super E carb, redid barrels and heads...
timeMay 23, 2009, 03:52 AM #76
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
Sammich Club founder #1.. Down to smash a LS1
going good you have new updates on the build
Logged
Patrick...  Your March 10 ROTM
98 GT Pacific Green (PS/M6764)
I NEED A COBRA FRONT BUMPER
Dude you got a Cobra...
Yeah my dad made me get it...
Bro all Cobras have 32V's and are just bigger versions of the Vtec you really wanted...
Really? Thanks you are my bestest friend.
96_SVT_Cobra: cuz i got flashed by a 60 year old on a harley and was clinically dead for
timeMay 23, 2009, 07:11 PM #77
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Just did some work today.
The master cylinder is now fitted and bolted into place. It fits perfectly. Plenty of room to pull the spark plugs when needed. Plenty of room for the Brake lines to be mounted. Plenty of room for the hydraulic hoses for the brake booster. The pedals are in the exact position they need to be in. It went way better than I thought it was going to be.
I need to get some pictures, my wife stole the memory card from the camera.
Next up is making the reenforcing plate for the firewall, pulling the engine and trans back out. Cutting out the crappy fender aprons and having the new ones welded in. Painting the engine bay, and reinstalling the engine for the last time.
Logged
timeMay 24, 2009, 12:18 AM #78
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
sounds like a lot to do still think you make you dead line? I might get a 66 Farlane. but i think im going to go with a 390 i want to make a GTA clone
Logged
timeMay 24, 2009, 08:30 AM #79
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
There is a ton of crap that needs to be done. Getting the engine in and fired up is only half the battle. I will still need to fit the rear. The major purchases I will need are a radiator, alluminum drive shaft, tune, dash pad, plus all the other little nit picky crap I need. Finish all the little B.S. stuff that needs to be done, which is alot considering the intirior needs to be finnished up.
I was really wanting to be done for the end of July for the big Mustang show in Quakertown Pa. But that is unrealistic. Now I am shooting for the big Ford show at Raceway Park in Englishtown N.J. at the end of October.
Logged
timeMay 24, 2009, 09:57 AM #80
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
Hope you get done in time Matt cant wait to see this thing done its going to be sick
Logged
timeMay 24, 2009, 10:16 AM #81
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I just want to be able to drive it atleast once before the world ends in 2012.
Logged
timeMay 24, 2009, 11:27 AM #82
MustangChris
Butt Plug
Trade Count: (+36)
SN95 Veteran
Offline Offline
Sammich Club Member #6.
WWW
i hear that. lol.
Logged
I'll pose with your car too....AFTER the termi sawp cheesy
Chris, you amaze me sometimes.
timeMay 25, 2009, 06:11 PM #83
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I am excited, I got to work on my car 2 days this week......WoooooHoooo!
Today I took the pictures I promised of the master cylinder installed. I also removed the master cylinder, clutch/brake pedal assembly, engine and trans, and steering column.
Now that the master cylinder, engine and trans are all mounted up, I was able to take final measurments for the steering column. The steering column is now all cut to length, and a couple parts need to be tack welded into place. Then it will be ready for the final install.
I also started cutting out the right side fender apron. I ran out of time about half way done, so that is where I will pick up next time down.
The master cylinder apears to be in perfect position.
I still have to make some minor adjustments to the steering column for the brake pedal clearance. Mostly for the switch clip.
Here is where I am with the fender apron.
Logged
timeMay 25, 2009, 08:13 PM #84
Handsome Man-about-town
Administrator
Trade Count: (+6)
SN95 Veteran
Offline Offline
Boom Baby!
looks good Matt!
even without the strut towers you're filling the bay up!
Logged
Donkeys kill more people annually than plane crashes or shark atacks, so watch your a*s!
timeMay 25, 2009, 11:29 PM #85
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
looks good matt your doing good work... you want to comw to IL when i get home and help me work on my 66 Fairlane.....LOL
Logged
timeMay 26, 2009, 03:08 AM #86
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
looks good Matt!
That engine bay filled up real quick with that monster.
Logged
timeMay 26, 2009, 03:10 AM #87
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I like the Fairlane. Eventhough they are a big car, they move pretty good with the right engine. What are your plans besides a 390?
Logged
timeMay 26, 2009, 03:24 AM #88
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
Well this is what my friend Kyel has done to the fairlane so far a slight built 306 4.56 gear, LT headers, B&M slap shifer and a B&M SH*T kit, fuel cell, and ET street rims. Dont qute me but i think that what they are called. This is what i want to do. I want to super charge the 390 but nuthing to big. Pluss parts for 390 are not to cheap I would like to make a show car out of it, and a all arownd good cruz car. I"m going to take out the 4.56 gears and put a 3.75 in it. For paint its going black pluss i want to lower like 2 inches. I should have some pics of her up tomarrow my dads going to e-mail them to me. No shots of the motor yet the car was locked and my dad forgot the keys. lol
Logged
timeMay 26, 2009, 04:48 PM #89
Mystikal
Trade Count: (0)
SN95 Veteran
Offline Offline
Nice work so far matt.
Logged
timeMay 26, 2009, 04:51 PM #90
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Thank you.
Logged
timeJuly 04, 2009, 05:59 PM #91
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
I finally got some work done today. It seems like forever since I was there. Made some big strides today. I removed both of the fender aprons and the remainder of the radiator support. Also fitted the replacement parts.
In unrelated worok I rebiult the door hinges, reinstalled the dash pad, and chrome window moldings on our 1965 Falcon.
I spoke with a guy that does rears. Talked about getting a 9 inch or useing the 8.8. He said I would be better off with the 8.8 which really suprised me, since I would have been buying an axle housing from him. So I will be going with my original plan of useing the 8.8 out of the Mach. We will have to cut the spring saddles off of my 8 inch rear that is in the car now and weld them onto the 8.8.
Here they are, kinda fitted into place. Still needs a bit of tweeking.
Pile of junk.
Logged
timeJuly 04, 2009, 09:09 PM #92
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
looking good matt.
do you have an eta for the car yet
Logged
timeJuly 05, 2009, 05:12 AM #93
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
looking good matt.
I was hoping to have it up and running for the Fords at Englishtown show at the end of October. But since I lost the month of June I don't know if that is realistic any more.
Logged
timeJuly 05, 2009, 05:37 AM #94
Venomous96Cobra
Trade Count: (+4)
SN95 Veteran
Online Online
wow! regardless of whether that goal is met or not! please be sure to keep us updated... I like the way this car is coming together!
Logged
1996 Svt Mustang Cobra 1852 of 7496
2001 Mustang Convertible 1 of many wink
timeJuly 05, 2009, 05:57 AM #95
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Thanks. Pops and I are having alot of fun with it. My dad is actually thinking of doing this swap in our 1965 Falcon if this turns out good. I think I would rather do it to a Maverick or a Pinto.
Logged
timeJuly 05, 2009, 06:45 PM #96
BigJohnsonDOHC
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
Good progress matt, did you pick a color for it yet? also are you going to be pushing alot of power out of it or just leave it be?
Logged
2003 Mach 1
- SLP LM1, KN intake, subframe connectors, UPR catted x pipe
timeJuly 05, 2009, 06:52 PM #97
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
If yall want to do it again, I have a 67 :D
Logged
timeJuly 06, 2009, 03:00 AM #98
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
The engine bay will be black and the car is Antique Bronze. It is very close to Aztec Gold. It is just going to have the basic bolt-ons for now, but my plan is eventually to have boost. I have 3/4's of the parts for the Eaton swap. Once it is moving we are going to have to tackle some traction issues.
Logged
timeJuly 06, 2009, 03:03 AM #99
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
If you want to pay, but we have to finish this one first.
Logged
timeJuly 08, 2009, 09:42 AM #100
US Soldier
Javi's secret lover
Trade Count: (+6)
SN95 Veteran
Offline Offline
Matt the car is going to be bad a*s when it done. cant wait to see it. i might just have to drive out there to see it in person when i get home. my old man thinks your build is the coolest thing in the world, and he would love to see the car in parson too. keep up the good work man
Logged
timeJuly 08, 2009, 11:08 AM #101
Trade Count: (0)
SN95 Veteran
Online Online
Sammich Club #5
haha. I'm a broke soon-to-be college student. I couldn't afford anything like this.
But its always nice to dream. I excited to see thiss thing running.
Logged
timeJuly 08, 2009, 12:32 PM #102
Steven
The voice of the reason
Trade Count: (0)
SN95 Veteran
Offline Offline
For the Pursuit of Speed
Yall do good work. Reminds me alot of me and my dad.
Logged
timeJuly 08, 2009, 04:21 PM #103
uncltrvlnmatt
Sn95 Forums Mayor
Trade Count: (+4)
SN95 Veteran
Offline Offline
Not a problem. You deservse some down time when you get back.
This is a build on budget. Save your pennies. The only way to do this sort of thing is with a parts car. Once you have that the rest is easy. Other than the parts car the only major expence is the front end swap. It helps if you can weld so you don't have to pay someone to do it.
Thanks Steven, we are having fun with it. I just wish my kids were into it enough to want to be involved. They could cae less.
Logged
timeJuly 08, 2009, 05:26 PM #104
Steven
Trade Count: (0)
SN95 Veteran
Offline Offline
It's really odd how genetics works, if that is the case. My dads a chevy man, and I bleed ford Blue. Then I know alot of guys my age who are huge into cars and trucks, and there dads can't even change their oil. Kind of funny how things work. Me and my Pops are a pair though, Had a big problem with the vintage venom kit on the 65 last night and he didn't want to mess with it, so I jumped in there and knocked it out for him. It's like tag team mustangism lol
Logged
Pages: 1 2 [3] 4 5 6 7 ... 12   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
My 1966 Coup
uncltrvlnmatt 12 614 Last post September 18, 2006, 09:11 PM
by DamieN
Just found This Pic Of My 1966 Coup
uncltrvlnmatt 3 284 Last post June 08, 2007, 01:59 PM
by uncltrvlnmatt
uncltrvlnmatt's Build Thread 1966 Coup 4.6 DOHC Build Up. Updated 10/19/08 Pics « 1 2 3 4 »
.:Build Up's & Projects:.
uncltrvlnmatt 125 2365 Last post August 25, 2008, 01:20 PM
by uncltrvlnmatt
Looking for a 96-98 GT coup.
WTB (Wanted)
nnforever 2 147 Last post June 15, 2009, 09:14 AM
by Willis_98GT
Updated pictures of the tail Swap.
Steven 6 243 Last post September 27, 2009, 06:20 PM
by MustangChris
1966 Coup Int Parts F/S
CLASSIFIEDS
uncltrvlnmatt 0 81 Last post January 09, 2010, 08:41 AM
by uncltrvlnmatt
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
