August 27, 2009, 06:31 AM | #0 |
GUIL-BOT
SN95Forums Supporter
Trade Count:
( 0)
revving engine
Offline
I drove my car for approximately two hours yesterday (first time out in a month) I beat it a bit lol.. And I could smell my clutch burning at times? I thought it could be happening as I was flooring. But, when I went in a parking lot to try a burn the REAL trouble starting happening. I started to rev the engine at 3000rmp then release the clutch and press on the break to make it spin. After approx. 5 seconds, I decided to see if it could take 2nd gear.
I was in second gear and it seemed to give a lot of power! I thought "WOW, let's give 3rd a try"..... I was like wtf is that possible?..I stopped pressing on the gas pedal and saw A LOT of smoke popping of my hood + I was not able to move forward. I was able to rev the engine, but not accelerate. I turned off the car in a panic, obviously. I waited about 20 min for the smoke to stop coming out from behind the engine. After that, I tried to start the car. I could hear it turning, but it sounded really bad and then unfortunately, there was smoke again!! I went to see the marks of the burn: there was freaking nothing? then where did all that smoke come from??!! I have obviously screwed something up and don?t know what f**k it is . So I had to call for a tow to get it home -.- I am hoping you guys have an idea of what could of caused this.
All help will be appreciated.
Thank you so much!
Logged
 95 Mustang GTS -BBK Aluminum Pulleys - Need to be install Ford Racing 3.73 SPEC Stage 2 Clutch Magnaflow Catback Magnaflow Tru-X X-Pipe/catted BBK Throttle Body 70mm BBK Equal Length Shorty Headers BBK Cold Air Intake
August 27, 2009, 06:59 AM | #1 |
Win
Hustling
Trade Count:
( +20)
SN95 Veteran
Offline
Formerly 95convGT
Sounds like you might have just roasted your clutch disc. Something wouldn't let your pressure plate engage fully onto your disc and flywheel to clamp them all together. Sounds like it is time for a new clutch.
I would replace
Clutch TOB Pilot bearing
I would also look into maybe a new cable. possible a new clutch Fork and Pivot ball also.
Logged
06 Mazdaspeed 6 03 Kawasaki ZR1000 Then the beast 94 GT  Win=Paul.
The Stig is worth 20+ hp easy. life is much more manageable when thought of as a scavenger hunt as opposed to a surprise party. Jimmy Buffett
August 27, 2009, 07:17 AM | #2 |
SVTurbo 98
Trade Count:
( +3)
redlining 1st
Online
Yeah it sounds like you smoked your clutch really bad....
Logged
August 27, 2009, 07:38 AM | #3 |
Paul
Undersecretary for GoFuckYourself
Global Moderator
Trade Count:
( +24)
SN95 Veteran
Offline
Shadetree Mechanic
You wasted your clutch.
Have fun replacing that.
Logged
August 27, 2009, 07:56 AM | #4 |
mustangshane
Trade Count:
( +1)
shiftin thru 4th
Offline
White Mustang Mafia! Here kitty kitty kitty!!
ROFL! That was funny! Yeah dude, you probably completely smoked that clutch, no pun intended.
Logged
"I believe God is managing affairs and that He doesn't need any advice from me. With God in charge, I believe everything will work out for the best in the end. So what is there to worry about." --Henry Ford
August 27, 2009, 09:10 AM | #5 |
GUIL-BOT
Trade Count:
( 0)
revving engine
Offline
This means a lot of work... :( But I also want to let you know that there is no compression... Do you think it could be the timing chain?
Logged
August 27, 2009, 09:16 AM | #6 |
Win
Hustling
Trade Count:
( +20)
SN95 Veteran
Offline
Formerly 95convGT
you did a compression test and you have no compression ??? In which cyl??
Logged
August 27, 2009, 09:25 AM | #7 |
mustangshane
Trade Count:
( +1)
shiftin thru 4th
Offline
I think were missing something here...
Logged
August 27, 2009, 09:28 AM | #8 |
GUIL-BOT
Trade Count:
( 0)
revving engine
Offline
Well my friend told me that... He was with me when that happend last night... We didn't do a compression test...
Logged
August 27, 2009, 09:31 AM | #9 |
Paul
Global Moderator
Trade Count:
( +24)
SN95 Veteran
Offline
Shadetree Mechanic
Then how the hell do you know that you have no compression?
Stop listening to retards who don't know what they're talking about.
Logged
August 27, 2009, 09:36 AM | #10 |
mustangshane
Trade Count:
( +1)
shiftin thru 4th
Offline
Exactly what Paul said. You know, what you did would FRY the clutch. If you lost compression the engine would have shut off on its own. One thing is not related to the other, unless there's something you didn't tell us.
Logged
August 27, 2009, 09:45 AM | #11 |
x182dan
Trade Count:
( +4)
SN95 Veteran
Offline
I am confused why doesnt it have compression? Your car was running when you were burning up your clutch so therefor your motor was making compression. I think you didn't burn the tires at all probably just the clutch the whole time. I bet if you drop the inspection cover you'll find a lot of friction material.
Logged
 1995 Mustang GT-(320rwhp, 355rwtq)<---needs more HP 1994 Tbird SC-331 stroker conversion(parted and JUNKED) 2002 Ranger XLT 4x4-daily driver 1989 Taurus SHO(sold but it was a fun sleeper) 1991 Taurus SHO(parted out) 1990 Tbird SC 5spd(modded but sold it for the truck)
August 27, 2009, 09:47 AM | #12 |
Paul
Global Moderator
Trade Count:
( +24)
SN95 Veteran
Offline
Shadetree Mechanic
Get your car up on jacks and pull the exhaust and trans.
Logged
August 27, 2009, 10:13 AM | #13 |
Win
Hustling
Trade Count:
( +20)
SN95 Veteran
Offline
Formerly 95convGT
Just a Ques?? Is this the guy that said he couldn't get your catback on without taking the wheel off???
Just what paul said throw it up on jackstands and pull the Crossover pipe driveshaft then the tranny and you will find your problem right there.
Logged
August 27, 2009, 10:26 AM | #14 |
joekd
Trade Count:
( +4)
SN95 Veteran
Online
If anyone tells you that your car lost compression and didn't even pull a plug then they aren't someone you want working on your car...ever
Logged
1996 Mustang GT convertible
August 27, 2009, 12:58 PM | #15 |
Venom351R
Trade Count:
( +4)
SN95 Veteran
Offline
sounds like your friends a moron and a few cupcakes shot of a full box
Logged
August 27, 2009, 01:00 PM | #16 |
x182dan
Trade Count:
( +4)
SN95 Veteran
Offline
or hes a 16year old know it all
Logged
August 27, 2009, 03:59 PM | #17 |
GUIL-BOT
Trade Count:
( 0)
revving engine
Offline
Okay, thanks for all the help First of all, my car is parked in my driveway ( incline ). I tried to see if my car would go down by releasing the handbrake and by putting my car in gear... What happen is that it didn't block like it's suppose to :P I also ask two mechanic in my neighborhood to come look at it.. And they told me that the starter was not working.. Do you guys think when I burned the clutch, all the thing went in front of the starter thing... so this is why I can't hear it?
Logged
August 27, 2009, 05:26 PM | #18 |
rebelyell
Damn Right & Rebel Proud
Webmaster
Trade Count:
( 0)
SN95 Veteran
Offline
Okay, thanks for all the help First of all, my car is parked in my driveway ( incline ). I tried to see if my car would go down by releasing the handbrake and by putting my car in gear... What happen is that it didn't block like it's suppose to :P I also ask two mechanic in my neighborhood to come look at it.. And they told me that the starter was not working.. Do you guys think when I burned the clutch, all the thing went in front of the starter thing... so this is why I can't hear it? wow... but if the starter starts your car... then how in the hell could it be bad??? Is the starter engaging and turning the motor and not disengaging? Meaning even though the motor is running the starter keeps spinning? Listen carefully, it should be very obvious if thats the case...
Logged
I am so sick of all of this self help, twelve step, leftover hippie generation bullshit! Now they don't want you to do anything, right? Just sit there. Don't drink. Don't smoke. Don't drive fast. Kiss my a*s! F*ck it! Do it all I say! Do you think Duke Wayne spent all of his time talking about his feelings with a f*ckin' therapist? There's no f*cking way he did! John Wayne died with five pounds of undigested red meat in his a*s. Now that's a man! Real men hide their feelings. Why? Because it's none of your f*ckin' business! Men do not cry. Men do... not pout. Men jack you in the f*ckin' jaw and say...Thanks for comin' out.
August 27, 2009, 06:56 PM | #19 |
Win
Hustling
Trade Count:
( +20)
SN95 Veteran
Offline
Formerly 95convGT
Didn't block i am lost. If you rolled your car in reverse or 1st gear you should be able to pop your clutch to get it started without a starter.
Logged
August 27, 2009, 07:20 PM | #20 |
Paul
Global Moderator
Trade Count:
( +24)
SN95 Veteran
Offline
Shadetree Mechanic
This thread makes my head hurt.
Logged
August 27, 2009, 08:59 PM | #21 |
GUIL-BOT
Trade Count:
( 0)
revving engine
Offline
Nothing work.. it look like there is nothing... W/e.... Should I order these from AM: -SPEC Stage 3+ Clutch (86-Mid 01 GT and 93-98 Cobra) -Mustang Clutch Adjuster Kit (83-95 V8) -SPEC Billet Aluminum Flywheel (86-95 5.0L) What you guys think..
Logged
August 27, 2009, 09:07 PM | #22 |
rebelyell
Webmaster
Trade Count:
( 0)
SN95 Veteran
Offline
Nothing work.. it look like there is nothing... W/e.... Should I order these from AM: -SPEC Stage 3+ Clutch (86-Mid 01 GT and 93-98 Cobra) -Mustang Clutch Adjuster Kit (83-95 V8) -SPEC Billet Aluminum Flywheel (86-95 5.0L) What you guys think.. spec 3 clutch totally unnecessary flywheel ok, dont need it though... but will free up some power and get better throttle response... dont waste your time with aftermarket clutch cables adjusters and quadrants
Logged
August 27, 2009, 09:29 PM | #23 |
August 27, 2009, 09:34 PM | #24 |
95_5.0@15
Trade Count:
( 0)
SN95 Veteran
Online
I'd rather have a big hood than big rims....
UH it seems like you have some bad mechanics around you..
Logged
August 28, 2009, 03:00 AM | #25 |
GUIL-BOT
Trade Count:
( 0)
revving engine
Offline
Well if the clutch is all burn...what kind of clutch should I buy?
Logged
August 28, 2009, 04:34 AM | #26 |
x182dan
Trade Count:
( +4)
SN95 Veteran
Offline
you don't need a heavy clutch like the spec. You can get a much lighter clutch which will be much easier on your tranny. I am running a super king cobra and so far so good. It grabs good and its that heavy. It can hold burnouts without burning up the clutch either!!!
Logged
August 28, 2009, 04:46 AM | #27 |
GUIL-BOT
Trade Count:
( 0)
revving engine
Offline
Okay I see.
I just don't know witch one to buy :S too many choices !!!!
I will order it today so let me know what clutch you guys suggest me to buy.
Thanks,
Alex
Logged
August 28, 2009, 05:02 AM | #28 |
Rice_slayer
Trade Count:
( +1)
SN95 Veteran
Online
I have a centerforce dual friction and love it! People tell me the pedal feel is hard, but I honestly dont see it. I have done a few brake torques with it and never had burning clutch smell or came close to blowing it up. It's rated for 450hp, I think my tranny would blow first :P. Before you order that clutch, take the old one OUT to make sure it is... just in case!
Logged
 1994 Ford Mustang GT Canary Yellow-270rwhp/283rwtq on a mustang dyno Show- 1995 Cobra R 3" hood, Cobra bumper. 18" Cobra wheels on BFG KDW's,tinted taillights/3rd brake light, powdercoated brackets/pullies. Go- 3.73s, 2.5" O/R H-pipe,2.5" Magnaflow catback, Shorties, CAI, aluminium driveshaft, TFS Stage 1 cam, TFS Track Heat Intake, Twisted wedge heads, 75mm TB, 75mm MAF,30# injectors,Astro T5 parts,255lph fuel pump, Steeda Tri-ax, centerforce clutch. Comfort- Updated center console, billet shifter bezel, misc billet parts, 2004 Mach 1 full leather seats,white face gauges. 2005 Ford Escape XLT- No Boundaries package
August 28, 2009, 05:09 AM | #29 |
August 28, 2009, 05:10 AM | #30 |
x182dan
Trade Count:
( +4)
SN95 Veteran
Offline
Yes it will hold the power fine but will it explode before hand maybe? I will never buy another DF again. The pressure plate blew apart on me. Never been to the track or raced either and I'm only at 355rwtq. Want a new clutch plate for yours? Mines still like brand new.
Logged
August 28, 2009, 06:37 AM | #31 |
rebelyell
Webmaster
Trade Count:
( 0)
SN95 Veteran
Offline
Okay I see.
Thanks,
Alex
Buy the stock spec clutch that paul is selling...
Logged
August 28, 2009, 06:38 AM | #32 |
rebelyell
Webmaster
Trade Count:
( 0)
SN95 Veteran
Offline
You shouldn't burn up the clutch when you do burn outs...
Logged
August 28, 2009, 07:28 AM | #33 |
x182dan
Trade Count:
( +4)
SN95 Veteran
Offline
you don't need a heavy clutch like the spec. You can get a much lighter clutch which will be much easier on your tranny. I am running a super king cobra and so far so good. It grabs good and its not that heavy. It can hold burnouts without burning up the clutch either!!!
You shouldn't burn up the clutch when you do burn outs... No you shouldn't but he did. Spec is totally unnecessary for his mods even if he goes full bolt ons. From what I've been reading lately it seems like lots of guys put in super heavy duty clutches when it is not necessary. I have never used spec but from what I hear its a heavy pedal and can cause your tranny to break because its such a heavy clutch.
Logged
August 28, 2009, 07:45 AM | #34 |
rebelyell
Webmaster
Trade Count:
( 0)
SN95 Veteran
Offline
You shouldn't burn up the clutch when you do burn outs... No you shouldn't but he did. Spec is totally unnecessary for his mods even if he goes full bolt ons. From what I've been reading lately it seems like lots of guys put in super heavy duty clutches when it is not necessary. I have never used spec but from what I hear its a heavy pedal and can cause your tranny to break because its such a heavy clutch. clutches don't break trannies... thats something that happens in handz's little world... His best bet is to get the clutch paul is selling and save money for mods that are worth while... like gears, or a cam, or headers
Logged
