Welcome, Guest. Please login or register.
Pages: [1] 2   Go Down
  Print
Author Topic: Hey guys I have a huge problem now!  (Read 662 times)
0 Members and 2 Guests are viewing this topic.
timeAugust 27, 2009, 06:31 AM #0
GUIL-BOT
SN95Forums Supporter
Trade Count: (0)
revving engine
Offline Offline
WWW
I drove my car for approximately two hours yesterday (first time out in a month) I beat it a bit lol.. And I could smell my clutch burning at times? I thought it could be happening as I was flooring. But, when I went in a parking lot to try a burn the REAL trouble starting happening. I started to rev the engine at 3000rmp then release the clutch and press on the break to make it spin. After approx. 5 seconds, I decided to see if it could take 2nd gear.
I was in second gear and it seemed to give a lot of power! I thought "WOW, let's give 3rd a try"..... I was like wtf is that possible?..I stopped pressing on the gas pedal and saw A LOT of smoke popping of my hood + I was not able to move forward.   I was able to rev the engine, but not accelerate. I turned off the car in a panic, obviously.   I waited about 20 min for the smoke to stop coming out from behind the engine.    After that, I tried to start the car. I could hear it turning, but it sounded really bad and then unfortunately, there was smoke again!!  I went to see the marks of the burn: there was freaking nothing? then where did all that smoke come from??!! I have obviously screwed something up and don?t know what f**k it is . So I had to call for a tow to get it home -.- I am hoping you guys have an idea of what could of caused this.
All help will be appreciated.
Thank you so much!
Logged
95 Mustang GTS
-BBK Aluminum Pulleys - Need to be install
Ford Racing 3.73
SPEC Stage 2 Clutch
Magnaflow Catback
Magnaflow Tru-X X-Pipe/catted
BBK Throttle Body 70mm
BBK Equal Length Shorty Headers
BBK Cold Air Intake
timeAugust 27, 2009, 06:59 AM #1
Win
Hustling
Trade Count: (+20)
SN95 Veteran
Offline Offline
Formerly 95convGT
Sounds like you might have just roasted your clutch disc. Something wouldn't let your pressure plate engage fully onto your disc and flywheel to clamp them all together. Sounds like it is time for a new clutch.
I would replace
Clutch
TOB
Pilot bearing
I would also look into maybe a new cable. possible a new clutch Fork and Pivot ball also.
Logged
06 Mazdaspeed 6
03 Kawasaki ZR1000
Then the beast 94 GT
Win=Paul.
Quote from: The Stig
The Stig is worth 20+ hp easy.
Quote
life is much more manageable when thought of as a scavenger hunt as opposed to a surprise party.
Jimmy Buffett
timeAugust 27, 2009, 07:17 AM #2
SVTurbo 98
Trade Count: (+3)
redlining 1st
Online Online
Yeah it sounds like you smoked your clutch really bad....
Logged
timeAugust 27, 2009, 07:38 AM #3
Paul
Undersecretary for GoFuckYourself
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
You wasted your clutch.
Have fun replacing that.
Logged
timeAugust 27, 2009, 07:56 AM #4
mustangshane
Trade Count: (+1)
shiftin thru 4th
Offline Offline
White Mustang Mafia! Here kitty kitty kitty!!
ROFL! That was funny! Yeah dude, you probably completely smoked that clutch, no pun intended.
Logged
"I believe God is managing affairs and that He doesn't need any advice from me. With God in charge, I believe everything will work out for the best in the end. So what is there to worry about." --Henry Ford
timeAugust 27, 2009, 09:10 AM #5
GUIL-BOT
Trade Count: (0)
revving engine
Offline Offline
WWW
This means a lot of work... :( But I also want to let you know that there is no compression... Do you think it could be the timing chain?
Logged
95 Mustang GTS
Ford Racing 3.73
SPEC Stage 2 Clutch
Magnaflow Catback
BBK Cold Air Intake
timeAugust 27, 2009, 09:16 AM #6
Win
Hustling
Trade Count: (+20)
SN95 Veteran
Offline Offline
Formerly 95convGT
you did a compression test and you have no compression ??? In which cyl??
Logged
06 Mazdaspeed 6
03 Kawasaki ZR1000
Win=Paul.
Quote
Jimmy Buffett
timeAugust 27, 2009, 09:25 AM #7
mustangshane
Trade Count: (+1)
shiftin thru 4th
Offline Offline
I think were missing something here...
Logged
timeAugust 27, 2009, 09:28 AM #8
GUIL-BOT
Trade Count: (0)
revving engine
Offline Offline
WWW
Well my friend told me that... He was with me when that happend last night... We didn't do a compression test...
Logged
95 Mustang GTS
Ford Racing 3.73
SPEC Stage 2 Clutch
Magnaflow Catback
BBK Cold Air Intake
timeAugust 27, 2009, 09:31 AM #9
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
Then how the hell do you know that you have no compression?
Stop listening to retards who don't know what they're talking about.
Logged
timeAugust 27, 2009, 09:36 AM #10
mustangshane
Trade Count: (+1)
shiftin thru 4th
Offline Offline
Exactly what Paul said. You know, what you did would FRY the clutch. If you lost compression the engine would have shut off on its own. One thing is not related to the other, unless there's something you didn't tell us.
Logged
timeAugust 27, 2009, 09:45 AM #11
x182dan
Trade Count: (+4)
SN95 Veteran
Offline Offline
I am confused why doesnt it have compression?  Your car was running when you were burning up your clutch so therefor your motor was making compression.  I think you didn't burn the tires at all probably just the clutch the whole time.  I bet if you drop the inspection cover you'll find a lot of friction material.
Logged
1995 Mustang GT-(320rwhp, 355rwtq)<---needs more HP
1994 Tbird SC-331 stroker conversion(parted and JUNKED)
2002 Ranger XLT 4x4-daily driver
1989 Taurus SHO(sold but it was a fun sleeper)
1991 Taurus SHO(parted out)
1990 Tbird SC 5spd(modded but sold it for the truck)
timeAugust 27, 2009, 09:47 AM #12
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
Get your car up on jacks and pull the exhaust and trans.
Logged
timeAugust 27, 2009, 10:13 AM #13
Win
Hustling
Trade Count: (+20)
SN95 Veteran
Offline Offline
Formerly 95convGT
Just a Ques?? Is this the guy that said he couldn't get your catback on without taking the wheel off???
Just what paul said throw it up on jackstands and pull the Crossover pipe driveshaft then the tranny and you will find your problem right there.
Logged
06 Mazdaspeed 6
03 Kawasaki ZR1000
Win=Paul.
Quote
Jimmy Buffett
timeAugust 27, 2009, 10:26 AM #14
joekd
Trade Count: (+4)
SN95 Veteran
Online Online
If anyone tells you that your car lost compression and didn't even pull a plug then they aren't someone you want working on your car...ever
Logged
1996 Mustang GT convertible
timeAugust 27, 2009, 12:58 PM #15
Venom351R
Trade Count: (+4)
SN95 Veteran
Offline Offline
sounds like your friends a moron and a few cupcakes shot of a full box
Logged
1994 SVT Cobra (#42 out of 5009) w/ 95 Cobra R drivetrain.
344 RWHP 347 RWTQ
12.531@108.80   1.710 60' / Best 60' 1.66
AFR 185's/FTI Camshaft/Edelbrock Victor 5.8/ PMAS 95MM Velocity Meter/4.10's/Centerforce Clutch/ Tremec 3550/ Roush 351 Headers/Bassani X pipe with Cats/Magnapack Mufflers/Moser 31 spline axles/Subframes/ Maximum Motorsport LCA/MT Slicks
http://youtube.com/watch?v=2gzdDJNQNHw
http://youtube.com/watch?v=cBTIApMbhO0
timeAugust 27, 2009, 01:00 PM #16
x182dan
Trade Count: (+4)
SN95 Veteran
Offline Offline
or hes a 16year old know it all
Logged
timeAugust 27, 2009, 03:59 PM #17
GUIL-BOT
Trade Count: (0)
revving engine
Offline Offline
WWW
Okay, thanks for all the help cheesy
First of all, my car is parked in my driveway ( incline ). I tried to see if my car would go down by releasing the handbrake and by putting my car in gear... What happen is that it didn't block like it's suppose to :P I also ask two mechanic in my neighborhood to come look at it.. And they told me that the starter was not working.. Do you guys think when I burned the clutch, all the thing went in front of the starter thing... so this is why I can't hear it?
Logged
95 Mustang GTS
Ford Racing 3.73
SPEC Stage 2 Clutch
Magnaflow Catback
BBK Cold Air Intake
timeAugust 27, 2009, 05:26 PM #18
rebelyell
Damn Right & Rebel Proud
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
wow... but if the starter starts your car... then how in the hell could it be bad???
Is the starter engaging and turning the motor and not disengaging? Meaning even though the motor is running the starter keeps spinning? Listen carefully, it should be very obvious if thats the case...
Logged
Quote
I am so sick of all of this self help, twelve step, leftover hippie generation bullshit! Now they don't want you to do anything, right? Just sit there. Don't drink. Don't smoke. Don't drive fast. Kiss my a*s! F*ck it! Do it all I say!  Do you think Duke Wayne spent all of his time talking about his feelings with a f*ckin' therapist? There's no f*cking way he did! John Wayne died with five pounds of undigested red meat in his a*s. Now that's a man! Real men hide their feelings. Why? Because it's none of your f*ckin' business! Men do not cry. Men do... not pout. Men jack you in the f*ckin' jaw and say...Thanks for comin' out.
timeAugust 27, 2009, 06:56 PM #19
Win
Hustling
Trade Count: (+20)
SN95 Veteran
Offline Offline
Formerly 95convGT
Didn't block i am lost. If you rolled your car in reverse or 1st gear you should be able to pop your clutch to get it started without a starter.
Logged
06 Mazdaspeed 6
03 Kawasaki ZR1000
Win=Paul.
Quote
Jimmy Buffett
timeAugust 27, 2009, 07:20 PM #20
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
This thread makes my head hurt.
Logged
timeAugust 27, 2009, 08:59 PM #21
GUIL-BOT
Trade Count: (0)
revving engine
Offline Offline
WWW
Nothing work.. it look like there is nothing... W/e....
Should I order these from AM:
-SPEC Stage 3+ Clutch (86-Mid 01 GT and 93-98 Cobra)
-Mustang Clutch Adjuster Kit (83-95 V8)
-SPEC Billet Aluminum Flywheel (86-95 5.0L)
What you guys think..
Logged
95 Mustang GTS
Ford Racing 3.73
SPEC Stage 2 Clutch
Magnaflow Catback
BBK Cold Air Intake
timeAugust 27, 2009, 09:07 PM #22
rebelyell
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
spec 3 clutch totally unnecessary
flywheel ok, dont need it though... but will free up some power and get better throttle response...
dont waste your time with aftermarket clutch cables adjusters and quadrants
Logged
Quote
timeAugust 27, 2009, 09:29 PM #23
Paul
Global Moderator
Trade Count: (+24)
SN95 Veteran
Offline Offline
Shadetree Mechanic
I am selling a complete solution for you.  Brand new stock replacement clutch, billet quadrant, and firewall adjuster - all for a ridiculously low price.
http://sn95forums.com/index.php/topic,41749.0.html
http://sn95forums.com/index.php/topic,41748.0.html
« Last Edit: August 27, 2009, 10:00 PM by Paul » Logged
timeAugust 27, 2009, 09:34 PM #24
95_5.0@15
Trade Count: (0)
SN95 Veteran
Online Online
I'd rather have a big hood than big rims....
UH it seems like you have some bad mechanics around you..
Logged
timeAugust 28, 2009, 03:00 AM #25
GUIL-BOT
Trade Count: (0)
revving engine
Offline Offline
WWW
Well if the clutch is all burn...what kind of clutch should I buy?
Logged
95 Mustang GTS
Ford Racing 3.73
SPEC Stage 2 Clutch
Magnaflow Catback
BBK Cold Air Intake
timeAugust 28, 2009, 04:34 AM #26
x182dan
Trade Count: (+4)
SN95 Veteran
Offline Offline
you don't need a heavy clutch like the spec.  You can get a much lighter clutch which will be much easier on your tranny.  I am running a super king cobra and so far so good.  It grabs good and its that heavy.  It can hold burnouts without burning up the clutch either!!!
Logged
timeAugust 28, 2009, 04:46 AM #27
GUIL-BOT
Trade Count: (0)
revving engine
Offline Offline
WWW
Okay I see.
I just don't know witch one to buy :S too many choices !!!!
I will order it today so let me know what clutch you guys suggest me to buy.
Thanks,
Alex
Logged
95 Mustang GTS
Ford Racing 3.73
SPEC Stage 2 Clutch
Magnaflow Catback
BBK Cold Air Intake
timeAugust 28, 2009, 05:02 AM #28
Rice_slayer
Trade Count: (+1)
SN95 Veteran
Online Online
I have a centerforce dual friction and love it! People tell me the pedal feel is hard, but I honestly dont see it. I have done a few brake torques with it and never had burning clutch smell or came close to blowing it up. It's rated for 450hp, I think my tranny would blow first :P. Before you order that clutch, take the old one OUT to make sure it is... just in case!
Logged
1994 Ford Mustang GT Canary Yellow-270rwhp/283rwtq on a mustang dyno
Show- 1995 Cobra R 3" hood, Cobra bumper. 18" Cobra wheels on BFG KDW's,tinted taillights/3rd brake light, powdercoated brackets/pullies.
Go- 3.73s, 2.5" O/R H-pipe,2.5" Magnaflow catback, Shorties, CAI, aluminium driveshaft, TFS Stage 1 cam, TFS Track Heat Intake, Twisted wedge heads, 75mm TB, 75mm MAF,30# injectors,Astro T5 parts,255lph fuel pump, Steeda Tri-ax, centerforce clutch.
Comfort- Updated center console, billet shifter bezel, misc billet parts, 2004 Mach 1 full leather seats,white face gauges.
2005 Ford Escape XLT- No Boundaries package
timeAugust 28, 2009, 05:09 AM #29
ram360
Trade Count: (+6)
SN95 Veteran
Offline Offline
I'm a cowboy on a steel horse I ride
<embed src="
" width="428" height="352" allowFullScreen="true" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed>
Priceless Trans Am
Logged
timeAugust 28, 2009, 05:10 AM #30
x182dan
Trade Count: (+4)
SN95 Veteran
Offline Offline
Yes it will hold the power fine but will it explode before hand maybe?  I will never buy another DF again.  The pressure plate blew apart on me.  Never been to the track or raced either and I'm only at 355rwtq.  Want a new clutch plate for yours?  Mines still like brand new.
Logged
timeAugust 28, 2009, 06:37 AM #31
rebelyell
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
Okay I see.
Thanks,
Alex
Buy the stock spec clutch that paul is selling...
Logged
Quote
timeAugust 28, 2009, 06:38 AM #32
rebelyell
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
You shouldn't burn up the clutch when you do burn outs...
Logged
Quote
timeAugust 28, 2009, 07:28 AM #33
x182dan
Trade Count: (+4)
SN95 Veteran
Offline Offline
you don't need a heavy clutch like the spec.  You can get a much lighter clutch which will be much easier on your tranny.  I am running a super king cobra and so far so good.  It grabs good and its not that heavy.  It can hold burnouts without burning up the clutch either!!!
No you shouldn't but he did.  Spec is totally unnecessary for his mods even if he goes full bolt ons.  From what I've been reading lately it seems like lots of guys put in super heavy duty clutches when it is not necessary.  I have never used spec but from what I hear its a heavy pedal and can cause your tranny to break because its such a heavy clutch.
Logged
timeAugust 28, 2009, 07:45 AM #34
rebelyell
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
clutches don't break trannies... thats something that happens in handz's little world...
His best bet is to get the clutch paul is selling and save money for mods that are worth while... like gears, or a cam, or headers
Logged
Quote
Pages: [1] 2   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
hey guys can u help me out with exhaust problem???
96-04 - 2V Specific
5.HOE 14 432 Last post May 10, 2006, 02:03 PM
by 5.HOE
I have a huge problem, I just saw!!!
1STOF3 4 252 Last post June 02, 2007, 09:58 AM
by 1STOF3
Huge problem!! Power Steering, need help!
GENERAL TECH
1STOF3 17 208 Last post June 15, 2008, 09:50 PM
by reivaxtorres
huge problem help!!!!!!!!
96-04 - 2V Specific
93PGT 4 106 Last post August 04, 2008, 03:32 AM
by 9psi 98
Huge Problem « 1 2 »
.:Lounge:.
TheLastApollo 40 429 Last post March 16, 2010, 06:38 AM
by DropTopPony
HUGE PROBLEM!!!!!
TheNatster513 28 395 Last post August 17, 2010, 05:17 PM
by TheNatster513
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
