Welcome, Guest. Please login or register.
Pages: 1 [2]   Go Down
  Print
Author Topic: pwnage of the ricers (ROFLMFAO OMG SO FUNNY MUST SEE!!!!!!!!!!!!!!!!!!ONE!!1111)  (Read 948 times)
0 Members and 1 Guest are viewing this topic.
timeDecember 08, 2006, 06:53 PM #35
rebelyell
duff daddy was here
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
yeah talk about suffocating your motor.
 :banana: dont have to worry about that one anymore. WE done did took care of all of them hehe. Do you still need MIL's?
yeah i do need the MIL's but there not completely necessary at the moment.  I do have to say that the CE light is really annoying but for now it can wait.
well that means your A/F ratio is Nancy Kerrigan up... so getting them is a great idea... Check Engine light is bad... Its not on to annoy you, its on cause somethings Nancy Kerrigan up... get the damn MILs and fix the son r sheep skin already :nonono:
as always; Thanks Greg for your input.  But I know exactly why the CE light is on.  The o2's aren't sensing the rear cats.  I need to get my solenoid and my heater core taken care of before I worry about the MIL's.
I'm pretty sure that if your CE light is on that your A/F ratio is Nancy Kerrigan up... which can kill your engine...
i'm not saying my A/F isn't off.  I'm sure it is.  I'm just saying that I know why the CE light is on in the first place.  O/R X-PIPE
NO STUPID! Try to listen close...
the CE light is on because your A/F ratio is wrong
Your A/F ratio is bad because of the x pipe...
A bad A/F could cause detonation or pre ignition...
which could germinate  up your engine... bad
so.oo... fix it before you germinate  it up
Logged
Quote
If you're not making mistakes, you're dying... If you don't learn from your mistakes...
YOU'RE DEAD
timeDecember 08, 2006, 06:56 PM #36
rebelyell
duff daddy was here
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
and stop doing **** half assed...
you wanna do something do it right...
You wouldn't buy just one head would you?
Logged
Quote
YOU'RE DEAD
timeDecember 08, 2006, 08:42 PM #37
AaRoN
WildFire
SN95Forums Supporter
Trade Count: (+1)
SN95 Veteran
Offline Offline
Knowledge does not cure opinion.
WWW
who the hell said i did anything half a*s?  because i didn't do it the way you would do it?  so...why is my a/f wrong?  because i have no cats.  hence, the CE LIGHT IS ON because there are no cats.
Logged
timeDecember 08, 2006, 09:00 PM #38
Administrator
Trade Count: (+5)
SN95 Veteran
Offline Offline
Boom Baby!
Dont be a stick Greg, not everyone has the same experience as you.
Logged
__________________________________________________________________
Quote
A wise & frugal government ...shall leave men free to regulate their own persuits of industry & improvement,
shall not take from the mouth of labor - the bread it has earned.  This is the sum of good government.
-THOMAS JEFFERSON
4. It was a rocket car, propelled by my awesomeness, powered by my manhood
timeDecember 08, 2006, 09:00 PM #39
rebelyell
duff daddy was here
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
listen you don't understand...
If you're A/F ratio is bad... it doesn't mean... eh no biggy...
It means that the engine is not running correctly...
It means that you're timing is off
It means you putting extra uneeded wear and tear on the engine
It could germinate  up the valves, or even the whole head depending on how bad it gets...
The light is NOT on because you have no cats
The Light IS ON BEACAUSE YOU HAVE A BAD A/F RATIO AND THE ENGINE IS NOT RUNNING THE WAY IT SHOULD BE... the cause of this is that you have no cats...
You don't want to run rich or lean... its very bad... you want to fix it... as soon as possible...
Logged
Quote
YOU'RE DEAD
timeDecember 08, 2006, 09:01 PM #40
rebelyell
duff daddy was here
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
I'm trying to tell him that the mil eliminators arent there just to make that light go away... theres more too it going on... trying to help him understand...
I'm really not trying to be a stick...
Logged
Quote
YOU'RE DEAD
timeDecember 08, 2006, 09:02 PM #41
AaRoN
WildFire
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
yeah i know.  i thought you were trying to say that it wasn't because of my o/r x that the light is on.  my bad.
check out the note underneath the install directions (step #12)
http://www.uprproducts.com/PDF/_vti_cnf/96Xpipe.pdf
« Last Edit: December 08, 2006, 09:05 PM by SilverSol » Logged
timeDecember 08, 2006, 09:13 PM #42
rebelyell
duff daddy was here
Webmaster
Trade Count: (0)
SN95 Veteran
Offline Offline
WWW
well the guy who wrote thats a ying yang...
in '96 they changed not only the engine from 302OHV to 281SOCH
they also changed the cpu from OBD I (On Board Diagnostic Ver. 1.0) to OBD II (On Board Diagnostic Ver. 2.0)
OBD II cars have O2 sensors (1 before the 1rst cat, 1 after)
OBD I only had 1 (before cats)
OBD I and older you wouldn't need the MILs
So it may be that those write ups are for a car older then '96
Regardless... I would suggest that you put that on the top of your to do list...
Not only will the light go out, but the A/F will be fixed, you will gain more power and gas milage... and you won't be at risk of messing up your car...
Logged
Quote
YOU'RE DEAD
timeDecember 08, 2006, 09:19 PM #43
Administrator
Trade Count: (+5)
SN95 Veteran
Offline Offline
Boom Baby!
What greg said about the OBD II is correct.
the other way is to get a tune and have it turned off.  but that usually cost's more than mil's.
Logged
Quote
-THOMAS JEFFERSON
timeDecember 08, 2006, 09:19 PM #44
AaRoN
WildFire
Trade Count: (+1)
SN95 Veteran
Offline Offline
WWW
will do Greg.  definitely at the top of my list of things to do.  i'm not even driving the mustang at the moment anyway.  maybe the write up is for pre-96.  i don't know.  doesn't matter cause i planned on getting the mil's anyway.
Logged
Pages: 1 [2]   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
BAhahahaha Ricers...
.:Lounge:.
sʇǝɟ 22 438 Last post February 09, 2010, 03:56 PM
by Duff Daddy
Stupid Ricers!
.:Lounge:.
uncltrvlnmatt 11 251 Last post April 04, 2007, 08:40 AM
by Hybridbird
i made a ricers day
.:The Garage:.
BigJohnsonDOHC 15 320 Last post June 01, 2007, 01:33 PM
by GDawg
New exhaust and RX8 pwnage
302Stang 9 177 Last post June 08, 2008, 07:27 AM
by realitygt
Ricers are Funny
phil_the_thrill 4 157 Last post June 14, 2008, 11:59 AM
by Spooling2Valve
2010 camaro pwnage
.:Lounge:.
Matt94GT 5 145 Last post June 01, 2009, 03:51 PM
by xsoutherngun89x
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
