Welcome, Guest. Please login or register.
Pages: [1] 2   Go Down
  Print
Author Topic: Need any Wiring Diagrams? (Stereo, Alarm and/or Crusie Control)  (Read 3059 times)
0 Members and 1 Guest are viewing this topic.
timeMarch 10, 2006, 04:53 PM #0
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
tickle tickle tickle...ahhh!
WWW
Feel free to ask me.  I can get them for basically any vehicle.  Just post here and ill post em up.
Instead of guessing the stereo wires or spending $20 on a vehicle specific harness you can just get the diagrams match them up with your headunit diagrams and your good to go.
EXAMPLE
1995-1997 Mustang STEREO WIRING
Constant 12V+   Green/Yellow
Switched 12V+    Yellow/Black
Ground    Black/Green
Illumination Light Blue/Red
Dimmer    n/a
Amplifier Remote Dark Blue
Antenna Right Front
Front Speakers    5" x 7" Doors
Left Front (+)    Orange/Light Green
Left Front (-)    Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers    5" x 7" Rear Deck
Left Rear (+)    Gray/Light Blue
Left Rear (-)    Tan/Yellow
Right Rear (+)    Orange/Red
Right Rear (-)    Brown/Pink
I can get these (Stereo Diagrams) as well as Alarm Diagrams, and Crusie Control Diagrams for pretty much any vehicle.
« Last Edit: July 31, 2006, 06:47 PM by Matt94GT » Logged
timeMarch 10, 2006, 07:13 PM #1
Lightning Struck
I was robbed on my 11!
SN95Forums Supporter
Trade Count: (0)
SN95 Veteran
Offline Offline
2004 Lightning 2.3 Whipple Powered
hey I'm having a little trouble with my mach 460 in my cobra, I think I have a bad connection or something, because every other day or so my rear speakers sound like they are blown.  I have disconnected a plug right in the middle of the trunk area under the seat trim, and then plugged it back in and it goes away only to come back again later.  The previous owner added subs I think because on the back of the rear left seat there a 4 holes that looks like the spot a amp use to be mounted at, also on the left amp harness there is two plastic splice in pieces for external hook ups........maybe he messed something up when he did that? A diagram of the correct wiring would be great, also any suggestions or ideas on this would be terrific.
Logged
12.45@106  1.69 60ft time on Ported eaton
Dynojet 520rwhp/565rwtq 12.1 @ 114mph spinning like top
timeMarch 20, 2006, 09:19 PM #2
wolvee123
Trade Count: (0)
sitting in the driveway
Offline Offline
GT not Cobra... If it ain't custom, It ain't a Rod
I have a 96 gt vert with a CodeAlarm system in it and for some reason none of my interior lights work.  Someone i spoke with said that the interiors are conceted through the aftermarket alarm and thats where I should check first for wiring problems...  obviously I checked all bulbs and fuses and door switches.  I do have the glovebox light and all dash lights.  What wire digram would i need and can you get it?  THanks
MikeW
Logged
96vertGT and proud of it!
timeJuly 31, 2006, 05:47 PM #3
B0mb3r645
Trade Count: (0)
Offline Offline
Hey I'm having troubles with my Mach 460 system, and am asking for a diagram so I can look into it without spending money I don't have.
And if you do, do you have both fuse panel diagrams?  Didn't get a car manual when I got the stang.
Logged
timeJuly 31, 2006, 06:43 PM #4
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
I dont have the mach460 diagram or at least I dont think it is, unless its the one at the very top in my 1st post (check that out).
Here I hosted up a online shop manual (much better then ford) download it here:
http://www.sn95forums.com/misc/94CAR_06_0.iso.zip
Only thing is that its more so for the 94-95 but it should still have the fuse panel diagrams on there.
« Last Edit: July 31, 2006, 06:48 PM by Matt94GT » Logged
timeJuly 31, 2006, 10:37 PM #5
B0mb3r645
Trade Count: (0)
Offline Offline
Thanks!  Dl'ed, will take a look at it 2morrow.
Logged
timeAugust 13, 2006, 01:17 PM #6
gearhead
Trade Count: (0)
engine running
Offline Offline
Do you have any for the 96-98 mach sound systems?
Logged
Chameleon Blue 96GT: 02 PI engine, 75mm Accufab T-body/Plenum, Pro-M filter, 80mm Gran. MAF, 24 lb inj, Kirban FPR, Stage II ported heads, FRPP shortys, Magnaflow O/R X w/ Borla Catback
Steeda Tri-ax, 190 fuel pump, UDP's, sport springs, U&LCA's, BBK Cast./Cam Plts, Tokico shocks/struts, front & rear swaybars
Motive 3.90 gears, Alum. D/S, Upgraded T-45 w/ KC clutch
13" Cobra brakes
279rwhp/329rwtq
8.71 @ 81 MPH w/ 2.10 60'
timeAugust 16, 2006, 09:48 PM #7
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
no i cant find the mach unless this is it:
Ground    Black/Green
Dimmer    n/a
Antenna Right Front
Logged
timeAugust 17, 2006, 02:14 PM #8
gearhead
Trade Count: (0)
engine running
Offline Offline
Do you know where the amp or amps are for my system??  I think I blew mine out, but I have no idea where to begin troubleshooting.  I have a hane's manual and their diagrams suck, plus they have nothing in there about the sound systems.
All I did was check the fuse in the fuse panel for it, and it was good.  Any help is appreciated!!
Logged
13" Cobra brakes
279rwhp/329rwtq
timeAugust 17, 2006, 05:59 PM #9
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
should be in the trunk in either the corner or up top below the windshield.
Logged
timeAugust 29, 2006, 03:50 PM #10
luke five oh
Trade Count: (0)
Newbie
Offline Offline
Just lately, I keep blowing the #8 fuse...and I have no idea where or why.... a wiring diagram of everything connected through that fuse and how the wiring is run would be a huge help.... or maybe if this is a common issue or something
Logged
timeAugust 29, 2006, 05:32 PM #11
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
Which is fuse #8?  Sorry I dont have a diagram like that.
Logged
timeAugust 30, 2006, 06:26 AM #12
luke five oh
Trade Count: (0)
Newbie
Offline Offline
Judging from what's not working...itts the courtesy lights, radio, clock pod, speedo amplifier
Logged
timeAugust 30, 2006, 05:37 PM #13
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
Do you have a stock stereo?  Any aftermarket gauges?
Logged
timeAugust 30, 2006, 06:51 PM #14
luke five oh
Trade Count: (0)
Newbie
Offline Offline
bought the car, it had an aftermarket sony radio....no custom gauges or anything though
Logged
timeAugust 30, 2006, 06:59 PM #15
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
If it were me id prob just install a slightly higer amperage fuse, I know thats not right but it will work and if that blows then you know you have a problem you gotta solve on your hands
Logged
timeSeptember 04, 2006, 04:01 PM #16
MeanGrn Gt
Trade Count: (0)
SN95 Veteran
Offline Offline
My other toy has tits
You dont by chance have a diagram of the third brake light housing for a 95 do ya(didnt think ya pry would but figured id ask)? The previous owner put on a cobra wing and he hacked up the wiring and a couple wires are not hooked up.
Logged
timeSeptember 04, 2006, 07:59 PM #17
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
I found a diagram of the stereo for the mach:
Logged
timeSeptember 18, 2006, 06:40 AM #18
Tattoogod
Trade Count: (0)
smoking 'em in 2nd
Offline Offline
Has your Horse eaten any rice lately?
Hi , Can you check to see if the hazard flasher is the same as the turn signal flasher..I was told they are the same relay with two parts in them..since my airbag light came on..peeps are telling me the clock spring is bad..would this cause the turnsignals stop working...everything else works perfect. I give up  >:(
Logged
timeSeptember 18, 2006, 11:22 PM #19
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
cant help ya there bud, id just ask ford.  i know my signals work and my airbag light is on...?
Logged
timeNovember 24, 2006, 01:38 AM #20
Sonic
Trade Count: (0)
Speedo Pinned in 5th
Offline Offline
Mighty Mustangs Europe Founder/Admin
WWW
Hey matt can you help me out with a mach1000 wiring diagram? I bought the system from a friend but without the harness...
Logged
timeDecember 12, 2006, 06:28 PM #21
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
I posted all i can find in the other thread sorry man.
Logged
timeDecember 13, 2006, 01:24 AM #22
Sonic
Trade Count: (0)
Offline Offline
WWW
No prob. Thanks, though.
Logged
timeDecember 26, 2006, 10:05 AM #23
philoldsmobile
Trade Count: (0)
engine running
Offline Offline
hi,
i'm installing an ipod compatible head unit into my SN95 (96 export spec V6) and dont want to use the stock amp..
if i cut and isolate wires 1 and 3 on the power connector, am i right in assuming the amp simply wont function? i am running new speaker cables directly to the speakers from the head unit, as no suitable interface is available over here...
is there any chance of it affecting anything else, all seems fine in a test, but i want ti be sure before i solder / heatshrink everything..
BTW, i have no remote entry or alarm....
« Last Edit: December 26, 2006, 10:07 AM by philoldsmobile » Logged
timeDecember 26, 2006, 10:08 AM #24
Sonic
Trade Count: (0)
Offline Offline
WWW
I'd say yes. But you can try without cutting the cables - just pull the plug from the socket and use some cables to bridge 2, 4, 5, 6, 7, 8 and see what happens.
Logged
timeDecember 26, 2006, 10:32 AM #25
philoldsmobile
Trade Count: (0)
engine running
Offline Offline
excelent, thanks..
Logged
timeApril 06, 2007, 06:13 AM #26
kspilly
Trade Count: (0)
engine running
Offline Offline
WWW
Wondering if you can hook me up with the stereo wiring for an 01 Cobra? A friend has one and wants to wire in a new deck without using an adapter. Let me know what you can do.
 cheesy
Logged
-97 SVT Cobra: Procharger supercharger, Flowmaster exhaust, bi-xenon lighting, Stewart Warner gauges, custom system...
-96 Grand Cherokee: Sparco race seats and harnesses, custom harness bar, bi-xenon lighting, LED lighting, system...
-94 Jetta GL: Carbon boser hood, system...
timeMay 18, 2007, 04:15 AM #27
fatman2k4
Trade Count: (0)
Offline Offline
I'm Fat, But You’re Ugly, And I Can Lose Weight...
WWW
A couple of my friends have Elemental Designs subs and amp...they sound really good and are made to last......and they aren't very expensive.....I'm going to put two of their 10's in my next car.....or maybe a 18"....hehe..
Here's the link to their site...
http://www.edesignaudio.com/edv2/index.php
And here are some videos of their subs.....the videos do no justification of how powerful they are.......click on 'e' and find Elemental Designs...
http://www.realmofexcursion.com/videos.html
Logged
Life Is A Journey, Not To Go To The Grave With A Well Preserved Body, But Rather To Skid In Sideways, Screaming "Holy SH*T!”
timeAugust 21, 2007, 07:14 PM #28
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
yeah ED makes good stuff, I remember I bought one of their lower end subs when they first came out...probably 4 years ago? was a good sub for sure
Logged
timeNovember 19, 2007, 01:45 PM #29
Wayne
Trade Count: (0)
revving engine
Offline Offline
I did a down load but my computer says it needs a program to open the file. what program would that be :help2:
Logged
95 Mustang GT, 94 3.8 and 79 3.3 mustangs in the coral
timeNovember 24, 2007, 09:17 PM #30
Matt94GT
Administrator
Trade Count: (+2)
SN95 Veteran
Offline Offline
WWW
no idea what kind of file is it? should say when you right click and see info.
Logged
timeMarch 09, 2009, 04:03 PM #31
tgreenwood
Trade Count: (0)
Newbie
Offline Offline
Do you have any wiring diagrams for the mach 460 in a 94 gt? I have no sound from speakers. thanks Travis
Logged
timeAugust 06, 2009, 08:59 PM #32
kintek
Trade Count: (0)
revving engine
Offline Offline
Matt do you what the wire specs would be for a 95 3.8 so I can get my alarm hooked up on it myself.  Thanks
Logged
1995 Green Mustang 3.8 rebuilt 5 speed resealed, AVS Black out light covers, Mac H pipe, dual mach 1 03' exhaust pipes,3.27 gears with t-lok differential, aluminum drive shaft, aluminum raidator, aluminum overflow tank, 03 cobra clutch installed, new coolant hoses, heater core, Matrix Angel Projector Headlights, more mods to come.
1995 Red Mustang 3.8 rebuilt with hyperestatic pistons, refreshed autotransmission, New coolant system everythings the same as the green stang cept this has a Fluidyne raidator, aluminum driveshaft, 3.27 gears with t-lok, 03 cobra exhaust system, Matrix Angel Projector Headlights, more mods to come.
timeNovember 15, 2009, 10:23 PM #33
Leroy Brown
Trade Count: (0)
Offline Offline
WWW
How about tach/oil pressure/temp wiring in the engine bay on a 94 v6?
Logged
timeMarch 18, 2010, 03:04 AM #34
1ofakindgt
Trade Count: (0)
Offline Offline
headlight diaghram.
Logged
Pages: [1] 2   Go Up
  Print
Jump to:
Related Topics
Subject Started by Replies Views Last post
FUSE BOX (x2) DIAGRAMS
Electrical & Stereo
Matt94GT 15 718 Last post June 06, 2010, 12:30 PM
by 98GTnSC
FFW, Hooters Crusie, Burnout Contest and Qualifying!!!
.:Lounge:.
7DMACH1 1 155 Last post March 05, 2007, 09:57 AM
by Red
My crusie control left me
GENERAL TECH
QwanSanchez 12 209 Last post February 29, 2008, 11:24 AM
by QwanSanchez
95 wiring diagrams wanted.
94-04 - V6 Specific
Tungstenizer_GT 2 164 Last post May 02, 2009, 09:49 AM
by Javi
Need wiring diagrams? Get'em here.
Electrical & Stereo
dustyboner 2 327 Last post November 03, 2009, 05:54 AM
by ttocs
WTB: Stereo Wiring harness for a '97 GT.
WTB (Wanted)
built454 1 23 Last post June 28, 2010, 10:49 AM
by 94-427
Designed, Maintained and Hosted by Voltage New Media - Web Design Victoria BC
100% Mustang Tech SN95Mustangs.com
SimplePortal Classic 2.0.5
