dannyboy1999
- Joined
- Jul 28, 2024
- Messages
- 25
- Reaction score
- 4
Also going for a full N/A build so what comp cams would you recommend?Just a regular 5.0 stock coyote with the stock fuel rails and injectors and stock throttle body which is drive by wire. Only modification is that I welded a -6an fitting to one end so I can use a adjustable fuel press regulator as the holley terminator max is a return to tank fuel system. Please note that on a 5.4 with this manifold you will have to relocate your alternator as the throttle body is in the same space as the alternator. I put it were the ac compressor is using a 3/4” aluminun bracket and all new belt routing pulleys. Im seriously considering using the MFP reverse mount relocation setup as Im getting to be an old man and really want AC
