clayton
- Joined
- Sep 5, 2024
- Messages
- 4
- Reaction score
- 0
Hey everyone, name is Clayton and I am new here. So here's the deal, I have a 95 gt with a 331 that heats up quick. After about 15 minutes of driving it heats up to 3/4 of the way on the gauge, and doesn't cool off until I turn the heater on. Then it stays around the A in NORMAL on the guage. The fan is working, and this car is still running the factory Tstat and factory rad. The engines mildly built...331, twisted wedge heads, 1.6 rockers, TFS stage 1 cam, track heat upper and lower intake, 30lb injectors, trick flow rails, 190 fuel pump, EGR delete, BBK shorty headers that leads to straight pipes. I'm guessing the stock rad just isn't cool enough for the build. So I'm replacing the Tstat with a 180 unit and looking for a good aluminum aftermarket rad for this motor. I've been reading reveiws on all different brands. I'd like one that is a direct fit for my 95 with no fabrication to mounting, clearance issues and one I can directly mount the factory electric fan to. Anyone have any suggestions? I do know I've read the SVE leaks from drain cockpit and you usually have to mess with ABS lines to get the rad to fit correctly. If I can get away with direct bolt up that would be great. Thanks for any input! Btw this is my first SN95...all prior mustangs were 1970, so a lot of the ropes around this car I'm just now learning. So far love the car, very fun ride and defenetly handles better than my last 1970 coupe
