Knocking sound after car sat for a few months
Greg Futral
Good Afternoon,
I have a 2002 Mustang GT. It developed a miss, and I did not get around to fixing it. The trickle charger says the battery is charged. I tried to start it, and it will not turn over. What is disturbing to me is that there is a loud sound (in the garage with the hood up) that sounds like a knocking or rapping sound. Any ideas? Thank you!
Greg Futral
Joppa, MD
Miltoid
So you got it running and it has a knock?
Try to turn the engine over by hand.
Does it turn? If so turn on the headlights and try to crank the engine. Do the lights dim down or go off? If so you may have a dirty terminal or a bad battery.
07GtS197
Fort Myers, Fl
So It doesn’t turn over. Just a single click/thud when you turn the key? If that’s the case the starter solenoid is probably frozen. Give it a technical tap with a rubber mallet to free it up and it should spin again. The starter will need to be replaced.
G
Greg Futral
No it was a number of loud noises that reminded me of a old Fiat 124 that needed a new engine. I can't remember how many noises, but perhaps a half dozen or more all withing what seemed to be a second or two. I googled what does a rod knock sound like, and it kind of sounds like this.https://www.google.com/search?q=what+does+rod+knock+sound+like&oq=&gs_lcrp=EgZjaHJvbWUqCQgAEEUYOxjCAzIJCAAQRRg7GMIDMgkIARBFGDsYwgMyEQgCEAAYAxhCGI8BGLQCGOoCMg8IAxAuGAMYjwEYtAIY6gIyEQgEEAAYAxhCGI8BGLQCGOoCMhEIBRAAGAMYQhiPu!ARi0AhjqAjIPCAYQLhgDGI8BGLQCGOoCMhEIBxAAGAMYQhiPARi0AhjqAtIBCTEzODFqMGoxNagCCLACAQ&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:4d2142be,vid:wmtBqNnnvrs,st:0 There was not this noise when the car started misfiring a few months ago. The oil is full. Thank you!
RAU03MACH
NEW MEXICO
It's going to sound crazy but rotate the engine backwards counterclockwise a full turn then try starting it it has a slight hang in the engine somewhere
My 5.4 did it to me twice last year winter start up
And it was sitting for 3 years
G
Greg Futral
Thank you. I don't know enough about rotating an engine backwards. I almost flunked wood shop. I had 12.8 volts on the battery when I tried starting it. Thanks.
RAU03MACH
NEW MEXICO
find a socket that fits the harmonic balancer bolt 1/2 breaker bar and socket deep wall
turn balancer counter clockwise
GTamas
Austria
How you describe it I would guess it's your battery making problems. Rapid clicking noise without the engine turning would be that.
Something like this, but every car could sound a bit different.
You could also make a video of the sound, it would help us help you. :)
G
Greg Futral
Thank you so much. It kinda sounds like the machine gun the guy with the British accent speaks of. So maybe just hook up some jumper cables from the SHO.
96blak54
Lawrenceburg Kentucky
I wouldnt rotate a modular engine backwards. If tension has been lost on the timing chains, a slipped tooth can occur on the crank sprocket ultimately killing the cam timing. And that leads me to say a loud knock noise could be the tensioners not in full function and the chain is slapping around. After nearly 1 hour of run time and multiple oil changes(not sure the multiple oil changes helped any)the knock subsided when my friends mustang had sat for over a year not running. Hopefully this is your scenario
AlexM
