Smog pump removed do I need to plug that smog pipe it's sucking are an making noise when running maybe has to do with my idle need some help thanks guys 95 gt
if you are removing the smog pump than you can plug it or remove the tube
it runs from the back side of the heads you would need to plug both heads once tube is removed
