98' GT bbk h-pipe w/stock manifold exhaust leak
amf201091
Omaha, Nebraska
The previous owner installed a bbk h-pipe from AmericanMuscle and kept the stock manifold. The car has an exhaust leak where the manifold meets the h-pipe on the passenger side. I took it to an exhaust shop and the owner told me that I would either need to find a gasket that's thicker and better quality than OEM (option A) or (option b) get some headers. AmericanMuscle says that the BBK h-pipe is meant to go with bbk long tubes and I'm guessing this is why... Does anyone know where I can find a thicker/better quality gasket that would go in between the manifold and the h-pipe?
delling3
Sterling Heights, MI
BBK makes two different H pipes - one for the stock manifold or shorty headers, and one for long tubes. If the pipe you have will even remotely come close to bolting up to the stock manifold, you have the right H-pipe.
My understanding is that installing long-tube headers requires you to lift the engine off it's mounts, or drop the front K-member for clearance. Not sure if it possible, but likely you could install shorty headers without this, but I am not sure that they would do you any good.
amf201091
amf201091
Omaha, Nebraska
Yeah, I just noticed it's not the same one that is currently offered on AmericanMuscle. The one I have is meant to be a direct replacement of the factory mid-pipe. I'm thinking of just ordering a OE gasket off AmericanMuscle and hoping that fixes the leak.
96blak54
Lawrenceburg Kentucky
The bolts probably stretched out some. They do experience tons of heat and any tension is gonna allow them to stretch out into nominal unclamping state.
Maybe a new gasket and bolts
joe65
you could buy gasket material and make one?
I am gonna need pics to see how they have h pipe for long tubes hooked up to the stock manifold.
I am still confused on how a mid pipe made for long tubes could ever fit a stock manifold and not because of the connection. I thought long tubes came down a bit further than shorties, and the mid pipe was shorter because of this?
joe65
they do (longtubes), it has to be a standard full h pipe. The only other option is custom cut and weld.
amf201091
amf201091
Omaha, Nebraska
RAU03MACH
NEW MEXICO
I ended up putting 2 of those on the passenger side of my cobra
Not sure about the gap between I did blow one out on the passenger side
RAU03MACH
NEW MEXICO
Now I remember why I put 2 in there was a little bit of a gap in between the jba shorty header and the bbk flange
The header manufacturer or bbk to short
That's why I put 2 of them in and tighten the shit out of it
Would it help to take the back connection to the pipe off or at the least loosen it, tighten the front and then go to the back?
RAU03MACH
NEW MEXICO
No because the driver side bbk h pipe was slightly longer on driver side
And made it look like the jba header shorter on the passenger side just a manufacturer defect in one ore the other I closed the gap up on passenger side I put 2 gaskets it worked you would think everything is to a t
Fit
The quality on parts have been in the shitter for a while
amf201091
amf201091
Omaha, Nebraska
Fit
So you think if I put two of these https://www.americanmuscle.com/ford-manifold-to-midpipe-gasket-rh-9604.html on it would fix the leak?
Jakespeeds
Camarillo, California
FHCee
