Trey Adair
So one day my ac just decided to get really hot. like the whole ac panel is hot and it’s blowing out hot air. I tried recharging my ac my self with the freon and a pressure gauge, but it made no difference please help!!
BigBore96
Is the compressor turning on? Can be verified by the clutch engaging on the compressor in the engine bay when ac is turned on
Sent from my SM-N950U using Tapatalk
T
Trey Adair
yes i believe so and maybe it increases my rpms when it does turn on?
Do you have A/C gage's to check and see if there is a block in the system or if it's just low
Do not just add freon you will damage the system if over filled
T
Trey Adair
idk about to the block but i did have the gauge to check the pressure..
bigmike636
What are the pressures that you’re seeing ?
T
Trey Adair
When i first put the gauge on the pressure was too high and was popping it right back off.. so I removed all pressure and now it’s sitting in the green.
bigmike636
What do you mean, you removed all pressure ? How did you remove the pressure ? And by it’s sitting in the green, you mean on the can of refrigerant, like Pro AC or whatever you are using to charge it ?
bigmike636
Can you include a picture of the gauge that you are using ? And maybe a picture of the line that you are tapped into ?
T
Trey Adair
it was a small kit to remove the pressure, but yes on the pressure gauge of the ac refrigerant. ill take a picture once im home!
bigmike636
Also if you could tell us what kind of car you have ? Is it R-134a ?
FHCee
