Accurately predict my dyno results... **STILL A TIE lol**
Status
Not open for further replies.
white95
Apex Junky
Admin
Prairieville, LA
Engine:-410w-EZ6M-6015-G351 SVO block (4.040" x 4.00)-Eagle ESP 4340 crank-Eagle ESP H-beam rods-SRP Pistons (-19 cc/10:1 ratio)-ARP rod bolts, ARP main studs-Canton 7 qt oil pan-Procomp 210 cc heads -2.02 x 1.60 stainless valves-titanium locks/retainers-EPW 1.6 ratio RR-Trick Flow stage 3 cam (236°/248° .574/.595, 110°)-Comp Cams retro-fit roller lifters-Comp Cams pushrods-ARP head bolts-Edelbrock valve covers-Edelbrock Performer RPM 351 (powder coated red)-75 mm throttle body-42# injectors-S197 MAS -custom 4" cold air -Aeromotive fuel rails -black fuel lines/fittings-AEM, externally mounted fuel pressure regulator-190 lph in-tank pump-'95 Lightning distributor-MSD cap/rotor/coil-Taylor plug wires -T4M0 ECU with Moates chip-BBK unequal length headers -Prochamber 2.5"-MAC 2.5" cat back 3.73 gears.. 295/35/18 tires...That's all I'm saying... Guess correctly*, win a hat!!(Whoever gets closest wins unless two people hit next to the actual figure: 377 378 379 If that happens, out of those two people, whoever got closest to the torque figure will win.)
RichV
CO
378/412
Sweet setup!
When are you going?
white95
white95
Apex Junky
Admin
Prairieville, LA
Thanks!! I meant to buy brakes, beef up the suspension more and put in a cage BUT I couldnt catch the snowball!!!!
Oh, and the car is already there!!
since you're running 295/35/18's im gonna say
395 rwhp & 418 ft/lbs
Musturd
419/456 should make some good numbers as long as enough fuel and everything works out good for you. I've seen quite a few guys using these heads down here and pumping out some nice numbers ... Can't wait till you getter back and enjoy the shiit out of it . I'm already planning a new combo and my cars not even back from paint yet . Lol . Mad jealous of ur big cubed stroker :(
Status
FHCee
