Airbag error 12 & fuse 4 instantly popping
tachicardia
So I just bought a 96 mystic cobra that was sitting in storage for 10+ years. One of the kinks I'm trying to work out is the Airbag error light the car has. It's giving me an error code 12. I narrowed down the issue to fuse 4 (under the dash) being blown. With the car off and no keys in the ignition I replace the fuse and it was instantly blown. I pulled that fuse and replaced with another new 10amp fuse, it didn't even make its way into the slot and was blown. I could even hear the contacts sparking as I put the fuse in.
So, clearly the 12 error code is that power isn't reaching the module because of the fuse - but if I can't replace the fuse I can't further trouble shoot the issue. Has anyone seen this before or have any ideas on how to start to figure this out? Would a loose ground cause this situation? I would have thought the fuse would pop with the car on or running, not be burnt out instantly with the car off. It sounds like somehow that line is getting overloaded with power with the car off.
FYI the car has 25XXX miles and is otherwise in great looking/running shape.
Thanks!
Eric
first - do NOT replace a blown fuse with a larger fuse ever again. Hopefully you didn't do any further damage. Has the car been in any accidents? Was the heater core replaced recently or the steering wheel out for any reason?
T
tachicardia
10amp was the original size, a bigger fuse was never put in :thumbsup:
No accidents, steering wheel wasn't removed and heater core is original. Cruise control and horn both work so it's likely not the clock spring (as far as I can tell from what I've read).
07GtS197
Fort Myers, Fl
Have you tried resetting the airbag computer by jumping the gray connector under the glove box? It could be nothing or it could be something like a bad ground or the airbag computer is bad.
Mustanger
Southern Oregon
if the fuse blows instantly that indicates a hot wire to ground short...like a skinned wire touching metal or some other failure like that. get a wire color code diagram & start look from the fuse on..good luck.
T
tachicardia
Yup, but without a fuse in place the 12 fault code won't go away. I'm going to work my way around the ground wires to see if that might be ut, thanks.
T
tachicardia
Yea, I'm thinking the same. I was hoping someone else might have experienced this and had a direction to point me in. A quick Google search shows one other person had a similar scenario but there was never a solution posted. Thanks!
we need to find out exactly what circuits are on that fuse and then isolate them by disconecting them and then inserting the fuse to see if it pops with out that piece in the circuit. I would use my manual but its for 94/95 and I am sure its different by 97. Anyone have an orange OEM manual?
T
tachicardia
Thanks ttocs. It's a 96 if that matters?
According to the veryusefulinfo.com page the fuse should be hot all the time (good news) and it identifies 2 areas to check for constantly blowing fuses. The diagram is below - does anyone know where those grounds are located?
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Man, I had this same code and problem on my 98. I never got it fixed though, and honestly I quit looking for it. Im interested to see what you find. Ive been through my whole wire harness and I dont have any shorted wires. I wonder if the module itself is bad and shorting internally?
T
tachicardia
Ugh - that's not promising! Haha. I guess at the least I should find out if the hot wire is coming from the module or from the engine bay, that should help narrow down the module as the issue. Or maybe disconnecting the airbag module harness, that should eliminate any power from the module at least, then check to see if the fuse socket is still live.
in the orange manual there is a spot that shows where all the grounds are. I think the abs is under the console isn't it? I would look there for the closest ground and trace some wires to see what you find. You can also try disconnecting it and then insert the fuse to see if it blows as if it does not then you know its the abs module.
lwarrior1016
South Mississippi
Air bag module, right?
aj351w
Anyone ever find a fix for this, I have the same issue with my 95 Cobra...
did we ever see what code 13 and 14 was since it says that might cause it to blow the fuse?
aj351w
Yes that involves taking the center console apart to get at the airbag control module. Haven’t done that yet.
Melliott574
I had the exact same issue Fuse kept blowing with code 12, My turned out to be the module, a simple voltage regulator thing inside the module. IMG_7252.jpeg
RevJon
