Dyno numbers in
G_94_T
TN
this is the second pull SAE corrected.....running pig ric
G
G_94_T
TN
Iron gt40`s cut to 58.5cc
Lunati cam 215 intake,224 exhaust @.050 .522 lift
Stock bottom end with new rings/bearings
BBK longtubes
14* timing
Explorer upper/lower
24lb inj
Pro-M 75mm
Scorpion 1.6 rr`s
O/R h pipe
Flowmaster cat back
70mm tb
CAI
hottwheels04
BBK longtubes
14* timing
24lb inj
Pro-M 75mm
Scorpion 1.6 rr`s
O/R h pipe
Flowmaster cat back
70mm tb
CAI
So you retuning it then? if that was running rich. I think you can get 270-280rwhp out of it. maybe some timing / tunning or few changes you can ring out a 280-290rwhp range. alot of guys make around 270-300rwhp with similar setups give or take dyno weather/ mods etc.
G
G_94_T
TN
these are the numbers after rebuild........hopefully better ones to come as my afr is WAY rich
Doodler
That's almost a mirror of my old set up and was good for 276rwhp with just the factory tune. She still has a bit more in her :thumbsup:
Mustanger
Southern Oregon
Nice! I like those numbers....stock 03-04 Mach 1 numbers & that car is fast enough! LOL....(ok, no car is ever fast enough!...lol)
RevJon
