Highlighted posts from Monday, Sep. 12, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
September 12, 2022 * 24 posts * 133 views
BHernandez said: Replacing the seat belt modules is expensive. If you can find them new, they're about $250/each. Most times they can be cleaned. Put some fresh dielectric grease in the coupling ... Read more >>
September 11, 2022 * 11 posts * 72 views
TrickVert said: If your drivability problems are below 2K RPM and are, indeed, spark related, it's not because you're supercharged. Plug gap is reduced when spark blowout occurs at high RPM and ... Read more >>
September 12, 2022 * 74 posts * 896 views
That Mustang Guy said: I'm sure most of you have heard of or owned an N-Gauge from Hp tuners or the Lund N-Gauge. The company that made the N-Gauge was E-Motion Products. From everything I could find ... Read more >>
September 11, 2022 * 5 posts * 63 views
94IVGT said: Check out Anderson Ford motorsport for good off the shelf cams, or Ed Curtis for a custom cam. Read more >>
September 11, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts "Air Bag" light came on yesterday.............. September 10, 2022 * 17 posts * 74 views Electrical & Stereo Can i... September ... Read more >>
September 12, 2022 * 1 post * 8 views
That Mustang Guy said: I have a 4-inch H.O. fiber trends fiberglass hood for 99-04 that I want to trade for a VFN 4-inch Cajun pro hood bolt-on or pin-on. Here are pics of what I have and what I want. ... Read more >>
September 11, 2022 * 6 posts * 97 views
tvsn95 said: No as to location. I too had run LCA w/Poly for years and started having the turn in problem after much usage. In my efforts to resolve I found the split bushing on the left front. ... Read more >>
September 11, 2022 * 6 posts * 90 views
Monday said: Why not hit the pull yard and grab a new assembly? It's super easy to swap out. You have the hard stuff done already. Speakers already out the way - the longest part about doing ... Read more >>
Continue reading...
FHCee
