Highlighted posts from Thursday, Nov. 11, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 10, 2021 * 20 posts * 100 views
Chenn2389 said: So I think I might try using the old school 90 degree elbow from the carb set up and run rubber coolant hose back to the heater core and another hose returning straight to the ... Read more >>
November 11, 2021 * 23 posts * 241 views
tpoteet said: So the idle "cam" feeling came back at a stop light along with the intermittent CEL, so I rushed home and grabbed the scanner and did a KOER test so it wouldn't disappear like ... Read more >>
November 11, 2021 * 21 posts * 194 views
07GtS197 said: Ford used a metal intake for the 4.6 equipped f150s in the late 90s too but they're tall and use a different plenum. Also Ford used an aluminum intake for the early 90s 4.6's in ... Read more >>
November 10, 2021 * 7 posts * 39 views
Chenn2389 said: I am having an issues with my cooling fan. I am using a Dakota Digital 2750 controller. I have it programmed to run a two speed fan. When I go to test the fan manually on the controller ... Read more >>
November 10, 2021 * 8 posts * 65 views
ttocs said: they look so familiar I thought someone would know by now Read more >>
November 10, 2021 * 3 posts * 27 views
white95 said: Congratulations to Caleb ( @ElrodKTPQ_89 ) on winning the Nov 2021 POTM contest. [image] Read more >>
November 10, 2021 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts 95 GT | Unable to trace idle issue November 10, 2021 * 21 posts * 183 views 94-95 5.0 - Specific Car is tuned, runs great, at idle ... Read more >>
Continue reading...
FHCee
