Highlighted posts from Wednesday, Apr. 07, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
April 06, 2021 * 4 posts * 48 views
ttocs said: yea if you are experiencing temps that high, and even worse on a dark colored car it will be hard to use anything less then nice upholstery trim and that isn't something you buy ... Read more >>
April 06, 2021 * 4 posts * 64 views
96blak54 said: Forget the adapter idea and go straight to a widened edelbrock intake. Gotta cut it in half add material. Change the fuel rail locations to accept the stock rails. Might loose ... Read more >>
April 07, 2021 * 1 post * 18 views
Warhorse Racing said: Looking ahead is a fundamental autocross skill. Giving yourself as much time as possible to prepare your steering, braking, and throttle inputs will help you get faster. Looking ... Read more >>
April 06, 2021 * 1 post * 5 views
SN95Newsletter said: Click here to view on the web Highlighted posts Personalized license plate ideas wanted... April 05, 2021 * 14 posts * 139 views 94-95 5.0 - Specific Fuel Pump Wiring Tips April ... Read more >>
April 07, 2021 * 20 posts * 499 views
Flade said: The GT40 heads use the standard Plug position used with every 289, 302 and 5.0L heads except the GT40P. You have it backwards. Standard heads have the plug angled. GT40P heads ... Read more >>
April 06, 2021 * 2 posts * 172 views
turboant916 said: Do you still have the this I can do $150 shipped? Read more >>
Continue reading...
FHCee
