PI swap problem
Booboo
I just completed a PI head swap on my 97GT, stock NPI bottom end. I had a local machine shop do a valve job, install MMR stainless valves, guides and seals, BTR .600 springs. I used new lash adjusters, new timing chains. XE262AH cams that MHS degreed. The engine runs but is down on power. The tuner says the load is about 30% less than it should be. It’s loosing air somewhere. Comparession test shows 180 on all except #2 which is 170. Any ideas?
B
Booboo
Anyone? Any ideas before I start taking this apart?
To explain it better, We are seeing about 70% of the power we should for the air that is coming into the engine measured at the MAF.
B
Booboo
That was my first thought, tested pressure and it was fine, even swapped out fuel injectors and the ECU. Wondering if the cams are somehow retarded.
96blak54
Lawrenceburg Kentucky
Ive seen lash adjusters hold valves open. Engine was down on power, couldnt figure it out, pulled heads off and noticed closed valves were slightly raised off the seat when they should have been seated closed
B
Booboo
This was my next guess, I installed brand new lash adjusters when I did the swap. This weekend I plan to replace all of them with a set of known good ones off the old non PI heads.
When you had this problem did you do a compression test? The decent compression I am seeing is got me confused.
96blak54
Yes for some reason when compression checked, each cylinder fell inline numerically close. My only guess is the valves were hanging open close enough to the seat to catch when pressures in the cylinder. The valves hanging open when they should have been seated was only caught by luck. Granted removal of the engine, heads off, looking at everything it was by chance a keen eye caught the valves off the seat slightly.
Hind sight, thinking of a way to diagnose this scenario,...on a cold engine, apply low regulated compressed air into the cylinder thru the sparkplug hole. Remove the trottle body and do some listening.
Take the lashers out, holding them with pliers or in a vise and heat them up to engine temp and squeeze out the contents while working them. Take the old lashers and do the same. Who to say the manufacturing is the same. The new lashers could be different. Oil weights play a big role in lashers due to their microscopic tolerances. Who to say manufacturing oil or assembly oil isnt trapped in them screwing with you. Oil just doesnt flow through these things and typically gets trapped.
Im a fan of strong lashers on the intake valve and loose sloppy lashers on the exhaust valve.
96blak54
At the time, rpm wouldnt get beyond 4500rpm on the dyno. After correcting lasher crap, then on the dyno again, a 6000rpm pull was made and revealed more issues. Like serpentine belt failure, fuel air management, weak torque converter.
B
Booboo
On the right is a brand new Ford lash adjuster that I installed with the PI heads. On the left is one from the non-PI heads prior to the PI swap. The motor prior to the PI swap was running great and had 120k miles on it. I am swapping out all the new lash adjusters with the old ones. Lets hope that solves the problem.
96blak54
Gotta love them sloppy npi lashers! One of npi head power faults were the lashers and low oil psi to them. Gotta get up into the high rpm for them lashers to make the full cam profile, but that was also fords intention with the hydraulic lasher and follower design.
B
Booboo
I swapped out the lash adjusters with the old NPI ones and the old followers. It seems to have fixed the power problem but it’s now noisy after it warms up. I’m thinking about getting a new set of lash adjusters and followers. Any recommendation? Ford, truck flow, ???
96blak54
Ford 100% you could take old pi lashers, heat them up with a heat gun and work the trash out of them with pliers. Also, lashers are very particular to oil weights. Running a thicker oil with cause their hydraulic characteristics to pump up and not bleed out properly. The lashers internal clearances are microscopic compared to any other bearing clearances.
RevJon
