Plug Identification Help
Tony SN956
I've got a 1994 GT Convertible that the previous owner did an absolute hack job on the wiring. They installed a aftermarket fan and tied into the wires but they cut off a plug. I'm trying to get this back to running condition but I am not sure what plug goes here. I found a pic on ebay and I think this is the plug I need but idk what it's called and I tried searching all over the place but can't figure it out.
Anyone know what this goes to? It looks like it pops out right before the radiator fan connector.
cobrajeff96
Germany
That one you have circled I'm pretty sure is a headlamp (9004/9007) connector for the low/high beam. It kinda fits since just south of it with the fir tree plastic pushpin is the fog lamp connector and the one right next to it is the topside frame rail twin-ground socket.
It would help to see the connector face of the one you're holding onto in the pics.
As for the coolant fan, I'd just get a replacement fan connector from any of the resto sites (LMR/CJ/AM/etc) and splice it in. But do a good job because that's high current passing through the orange/light blue lead when the high speed fan kicks on.
T
Tony SN956
That's what I thought too but it's not the headlamp both the headlamps are connected and there's some pretty thick wires like it's for high current. I tried to zoom in as much as I could but that's the best image that I could get it comes out of the harness right before the fan plug the fan plug itself is there it's the one right before it that I'm missing but I looked all over the engine bay I couldn't find it I tried looking at a bunch of wiring diagrams and I can't find it all I know is that it has a red orange and black connector and they're pretty thick wires
cobrajeff96
Germany
Car has ABS? Looks like it does with that red ABS test port on the harness.
If so, where is the pump module located?
T
Tony SN956
down under the radiator or like in front of it but theres a plug going into the top of it. Then again I do have an abs light on. Is it supposed to have 2 plugs?
T
Tony SN956
Actually now that I was looking around more I think that plug that is cut off IS the fan plug and the one at the end of the pigtail is the one for the overflow bottle sensor. My car doesn't have one but maybe the previous owner swapped it or it just didn't have one and it's a dead plug?
cobrajeff96
Germany
You might be better off just buying a complete engine harness at this point. National Parts Depot might have it, or any of those other restoration websites I previously mentioned. No telling what kind of butchery happened over the years.
Daryl
SoCal
This might also be a good place to check out
RevJon
