Post your mods!! (96-04 4V)
white95
Apex Junky
Admin
Prairieville, LA
I'd like to see what everyone has done to their cars!! Copy and paste this template and fill in YOUR mods!!
Engine/under hood/ECU :
Drivetrain:
Chassis/wheels/tires:
Interior:
Exterior:
other:
DeepList
Administrator
Admin
Auburn, IN
Engine/under hood/ECU:
P-1SC Procharger. Intercooled.
Aftermarket fuel injectors & Coils
Tuned
Drivetrain:
4:10 Gears
Hurst short throw shifter
FR500 Wheels
Nitto Tires
Interior:
Double DIN Bezel Swap
Pioneer Avic Double DIN Head Unit Touch Screen/Navigation
12" Pioneer Subwoofers - Custom Trunk Box
Bullitt Pedals
Exterior:
Mach 1 Chin Spoiler
Shorty Radio Antenna
Rear Bumper Inserts
Other:
Complete MagnaFlow Exhaust
the.greg
Gastonia, NC
03-04 COP conversion/blue 03-04 valve covers,
ngk tr6 plugs,
BBK CAI,
1.5 Kenne Bell supercharger,
Snow Performance meth injection kit,
Mishimoto radiator,
Moroso coolant reservoir,
Lightning maf,
42lb injectors,
255 walbro, dyno
tuned by Kurgan Motorsports 93 octane/meth injection/9psi tune on sct xcal 3,
Gates racing blue radiator hoses,
180d thermostat
Drivetrain:
Ram HDX clutch
new ford racing tob
new ford racing pilot bearing
new ford racing clutch fork
Fidanza aluminum flywheel
"built" t45 from the t45 source
aluminum driveshaft
new heavy duty u joints
ford racing 4.1 gears w fresh<300miles royal purple oil,
firewall clutch adjuster
aftermarket clutch quadrant
steeda tri ax
billet rockcrusher shifter handle
18x10&18x9 fr500 wheels, also I have a set of 17x9 95R wheels with nitto 555R for if I ever make it to the strip
tokico adjustable dampers
steeda cc plates
steeda progressive rate lowering springs
steeda rear upper
steeda lower control arms
steeda subframe connectors
Interior:
Saddle to black interior conversion
2001 cobra seats
autometer guage cluster pod w/boost and water temp
led guage cluster upgrad
led ac panel upgrade
jvc headunit
98 center console(cupholders ftw)
mach 1 "aluminum "pedal kit
03 cobra style shift knob
billet headlight knob
sct dashscan engine parameter monitor
Exterior:
export side mirrors
sequential taillight conversion
hid 8k headlights
hid 8k foglights w foglight mod
new cobra clear headlights
clear sidemarkers
led license plate lights
03 cobra "svt" rear emblem
shorty antenna
black rear bumper letter inserts
black painted rear valance
other:
BBK offroad h pipe
flowmaster mufflers/catback
hawk hps brake pads
custom "sawzall the casting ears off the t45 mod"
a plethora of stickers
and of course driver mod ;)
2004 cobra ECU and wiring harnesses.
Diablo Sport chip - dyno tuned
late-build 2004 cobra engine
JLT carbon fiber CAI
SCT BA3000 MAF (Whatever the big one is)
Acuufab tb
Acuufab plenum
Ported eaton
3.4 upper pulley
8# lower pulley
kooks long tube headers (ceramic coated inside and out)
custom catted x pipe - jones mufflers - dumpped
canton 7 qt oil pan
canton windage tray
ford racing nodular iron flywheel
centerforce clutch
FRPP T.O.B, pilot bearing, clutch fork.
Evenflow cooling kit
LFP radiator
LFP heat exchanger (heat extraction coating)
Fuel cooler, power steering cooler, oil cooler
Complete custom fuel system - return style - e85
Drivetrain:
Hurst shifter, T45 transmission
FRPP Aluminum driveshaft
4.10:1 gears
Eaton 31 spline LSD posi
moser 31 spline axles
FRPP axle girdle
Custom tubular chasis in front
MM sub frame connectors
MM HD LRCAs
FRPP URCAs
BBK Gripp springs
Tokico shocks
bilstein struts
Roto-tech rotors
hawk pads
2003/2004 cobra front a-arms
MM bump-steer kit (drill through)
1999 cobra steering rack
MM solid rack bushings
MM Solid steering shaft
MM Caster Camber plates
Prothyne bushings all around (less URCAs)
Interior:
Autometer a-pillar pod
Paul's center consol dual gauge pod
radio delete
auto meter full sweep electric blah blah fancy-pants gauges
Exterior:
what? do i look like a fag?
other:
2004 cobra gas tank
moroso battery relocation kit
moroso coolant exansion tanks (engine and s/c)
and more, i'm sure... ....
492 RWHP
492 RWTQ
chrisv_10
Asherton, tx
mark viii 4valve swap (still in progress)
stock cobra headers
K&N with heat shield
Solid motor mounts
offroad x pipe
flowmasters dumped
Drivetrain:
Steeda short shifter
Exedy mach 350 clutch
Billet quadrant
energy suspension trans mount
3.73 gears
stock 17's painted gunmetal
245/40 nt555s
CJ pony parts 2 inch drop springs
Interior:
stock
Exterior:
Painted matte black taillight bezels
no wing
other:
255lph walbro pump
mygreengt
South Dakota/ Iowa
BA2800 MAF
K&N Filter
Fluidine Heat Exchanger
Kenne bell 2.2 Twin Screw Supercharger
Metco Idlers
4# Lower Pulley
3.5" Upper Pulley
Intercooler Coolant Tank
Sct Xcal 3 tuner
Boost a Spark
Boost a Pump
Lethal Performance Boost a Pump Upgrade Kit
60# injectors
Drivetrain:
Steeda Triax Shifter
Spec Stage 3 Clutch
LPW Differential cover
Maximum Motorsports IRS Bushings Package
Camber/Caster Plates
H&R Springs
Cobra R Rims - 9in" Fronts, 10in" Rears
Mickey Thompson Drag Radials
Interior:
Autometer Boost Gauge
Innovate Wideband
GlowShift Digital Boost Gauge
Autometer Narrowband
Custom Headrests
Other:
JBA Shorty Headers
O/R X-pipe
MagnaFlow Catback
Black Chrome Rolled Exhaust Tips
rz5.0
Great state of TEXAS
bbk long tubes
canton expansion tank
k&n filter
Drivetrain:
b&m short throw
3.73
mm subframes
mm cc plates
sportlines lowering springs
hp megabytes lca
stock wheels
Interior:
03/04 cobra seats
dynamatt
Exterior:
stock
other:
spank 141
So Cal
Engine/under hood/ECU : JLT RAI, MMR Intake spacer, MMR imrc deletes, SAI delete, EGR delete. Mac long tube headers, mac off road H pipe and a 03 cobra magnaflow cat back exhaust SCT tuner by BAMA
Drivetrain:Upr K member, a arms and coil overs, Bilestien shocks. Rear is A 03 cobra IRS with Ebiach springs, and 3:73 gears. Aftermarket clutch, clutch cable and quadrant dont' know brand guy I got car from didn't know. Its alot heavier than my other 96 cobra was.
Chassis/wheels/tires: FR500s 295/35/17 kuhmos back 275/35/17 kuhmos on front.
Interior: 03 cobra interior soon to be swapped for stock. I don't like the seats. Pioneer stereo.
Exterior:All stock.
other:engine has some billet stuff underhood. was there when I bought it.
Cobra/1997
North East (Rhode Island)
Engine/under hood/ECU : Stock / K and N filter
Drivetrain: Stock
Chassis/wheels/tires: FR5 Rims (FR500s) 17x9 and 17x10.5 /Falken FK452 245/ 275 ultra high performance Tires
Interior: Stock / Sony 1100W amp / Sony boxed 10" subs
Exterior:Eibach Pro-Kit lowering springs/ 1.5" drop (or close to it)
other:[/QUOTE] Keeping it stock, car has 43k miles / everythings Original
Spiney
96 Cobra 50K miles. Always garage kept sunny day only driven.
Royal Purple full synthetic oil it's whole life
BAMA 93 tune W/ SCT Tuner
K&N CAI
Drivetrain:
B&M short shift kit
H Pipe no cats, FlowMaster 40's
H&R Springs 1.5" drop
MM Caster Camber Plates
New Isolators
Golden West Suspension Full Length Sub Frame Connector
Bilstein shocks & struts
FRPP Cobra 95R 17x9 wheels
New Goodyear Eagle F-1 Radials 275-45-17
Hawk Red brake pads
Interior:
Lloyd's Cobra floor matts
FRPP Billet foot pedals
Valentine 1 Radar Detector
Exterior:
Silverhorse Racing Black Billet Fuel Door
Raxiom sequential turn signals
Exterior maintained by Croftgate USA Products. Paint corrected by Maguiars MF compound & polish
Covercraft Noah cover
Brand new leather Bra not installed yet
Only use Shell or Sunoco 93 octane gas
Grundy Collector's Insurance
white95
white95
Apex Junky
Admin
Prairieville, LA
Engine/underhood/ecu:
4.6 4V
Teksid block, painted black
10.9:1 Diamond pistons/Total Seal AP SS rings
5.0L Coyote/Boss 302 rods/Clevite H-series bearings
Kellogg crank/Clevite H-series bearings
Boundary Billet 3V/GT500 oil pump
ARP fasteners throughout
MMR oil pan
2003 Cobra heads
2003 Cobra cams
Wonder Racing head cooling mod
Mach 1 intake
stock throttle body
stock MAF
JLT cold air intake
Coil on plug
stock ECU
SCT Tuner
Converted to hydroboost brakes
Converted power steering hoses to AN hoses
2000 Cobra R steering rack
BBK long tube headers
2.5" BBK catted H-pipe
2.5" Bassani catback
Drivetrain:
T45 [billet shift forks, bronze fork pads, carbon synchros]
Pro 5.0 shifter with Hurst handle
Unknown brand, 6 puck clutch and stock flywheel
Steeda double hook clutch quadrant
8.8 with Eaton Truetrac, Yukon 31 spline axles, Strange C-Clip eliminators
4.10 gears
Maximum Motorsports tubular K member, forward offset control arms, RA3 struts/coil overs, caster/camber plates, subframe connectors, RA2 shocks/coil overs, road race control arms, rear adjustable sway bar, panhard bar, heavy duty torque arm
18x9.5 FoMoCo Shelby GT500 wheels
275/35/18 tires
14” FTR S550 caliper/GT500 rotor kit
13” Baer Eradispeed +1 rear rotor kit kit
Interior:
grey, 98 GT interior [no dash clock]
2003 Cobra center console Corbeau Forza Sport drivers seat, black
Unicorn head light knob
Exterior:
vertical, export tail lights
Carbon Fiber T1 spoiler
Trufiber cowl hood with Tracspec vent & Aerocatch latches
Cobra style headlights
96blak54
Lawrenceburg Kentucky
Engine: junk and a set of 274 comp cams
Tranny: junk
Rear: junk
Exhaust : junk
Tuned by Blankenship....not junk!
Bogs
Tuned
Drivetrain:
4:10 Gears
FR500 Wheels
Nitto Tires
Interior:
Bullitt Pedals
Exterior:
Mach 1 Chin Spoiler
Rear Bumper Inserts
Other:
How do you like the Hurst Shifter?
RAU03MACH
NEW MEXICO
98 GT Mustang
Block & Heads
03 4.6 MACH1 Teksid block with DOHC heads
11.1 Diamond pistons sealed power rings
Mach 1 intake
Stock throttle body
Stock MAF
K&N cold air intake
Stock ECU
Stock injectors
Stock fuel pump
Stock Cams
Stock Crank
Ford Perfomance timming chain kit
Ford Racing wire set hemi style in valve cover
Champion 3 core Radiator
Aeromotive Fuel Rail and Fuel regulator
Catch Cans
TRANS MISSION
4R70W
B&M Street and strip shift kit
Exhaust System
JBA Shorty headers
2.5" BBK no cats H-pipe
2.5" Supper 44 Flowamsters catback
Suspension
EIBACH PRO-KIT 1.5 Lowering kit
Brakes Stock
Rack & Pinion Quick ratio
Gears 3.73 WILL CHANGE TO 4.10
TIRES WHEELS
FRONT 245/45/17 NITTOS
REAR 285/40/17 NITTOS
Front 17x9 cobra replicas
Rear 17x10.5 Cobra replicas
RAU03MACH
NEW MEXICO
97 Cobra Mustang
Block & Heads
RMN 4.6 IRON BLOCK .020" MODMAX SHORT BLOCK
4.6-4340 Crank 3.543"XOEM Int.91025335
4.6L 5.933XOEM 4340 H-Bm .86665025400
FORD 4.6 / 5.4 Rod Bearing V8KNGCR 868XPN
BEARING SET KNGMB5353HP
F 4.6/5.4 CTR MAIN BOLT WT 90625200
F 4.6/5.4 CTR MAIN BOLT STD 90625100
Ford Modular V8 main cap-side ARP156-5201
SHORT BLOCK ASSEMBLY
INT BALANCING
Cams stock
Valves replaced valve guides replaced
Ford Performance Timing chain kit
Ford Performance spark plug wire kit
Champion 3 core radiator
JLT cold air intake
Stock throttle body
Stock MAF
Stock ECU
Stock Coils
Kenne Bell Boost pump
Kenne Bell tune
Stock Fuel pump and injectors
Catch Cans
kenne Bell Supercharger 2.1
FORD:TS1000-96C 6 PSI KIT W/AC ('96-'98 4.6 COBRA 4 VALVE) 2.1L 3" Pulley
plans swapping the pulley
Transmission
5 speed manual with king cobra clutch
Hurst Ford Performance short throw shifter
Exhaust System
JBA Shorty headers
2.5" Supper 44 Lowmasters cat back
Suspension Front
EIBACH PRO-KIT 1.5 Rear 1.7 Front Lowering kit
Brakes Stock
Bump steer kit
New but stock lower control arms
Suspension Rear
Brakes Stock
UPR Rear Control Arm Kit lower And Adjustable upper
Gears
3.73
TIRES WHEELS
REAR 305/45/17 NITTOS
FRONT 17X9 03 COBRA REPLICAS
REAR 17X10.5 03 COBRA REPLICAS
RevJon
