SN95 4.6 2V n/a dyno #s
RichV
CO
This sticky is for all 4.6 2V n/a setups.
List your year, engine mods, and any pertinent changes from stock on how you made the #s. Also list the trans you have.
KillNThrill24
Cleveland Ohio
Good idea Rich
00 GT
Bullitt intake manifold
JLT cold air
Bassani o/r x
Borla 3in mufflers
3.73s
Custom tune (was not on yet. Will update when run again on working dyno)
224/256
Sent from my SCH-I605 using Tapatalk 2
joekd
Ct
This is when the car was all stock Npi right down to the paper motorcraft filter, ~65K miles
graph.php
96GT
Ebay CAI
O/R x-pipe
4R70W
lol what a disaster.
158rwhp/???torque.
No idea what the **** kind of dyno or why it's read like this.
duff daddy
No biggie, give me a few months and there wll be 2v specs to make people shit a brick :)
Caboose302
Dayton Oh
252/290
Dished pistons
FoxLake Stage 2 ported heads
Teeny tiny cams
BBK CAI
Pro-m 80mm MAF
30# injectors
70mm TB
Also it's a 10 year old prior track car with Nitrous so she's had a rough life.
1996 mustang gt (NPI)
1996 mustang gt T-45 (OEM)
"power" mods (things that could effect dyno results):
BBK Cold Air Intake + Filter
Ford Racing Shorty headers - ceramic coated
Bassani catted x-pipe
Flowmaster cat-back
Under drive pulleys (3 pulley kit)
OEM Flywheel + Spec Stage 2 Clutch
Ford Racing driveshaft
fully built posi rear end with 4.10s, 31 spline, blah blah blah
Screamin' Deamon Coil Packs
Taylor Wires
NGK Irridium Plugs
MadStang
Escondido, Ca
MMR 600 Shortblock
-1998 Teksid Aluminum Block
-13.7:1 Compression Ratio
-Flat Top Pistons w/ Notches
-MMR Windage Tray
MHS Stage 3 Ported Heads
-Decked .030 Over
MHS Stage 4.5 Bullet Cams
-245/243 Duration
-108 Lobe Seperation Angle
-550/540 Lift
-Ford GT Camshaft Followers
Steeda Underdrive Pullies
FRPP A/C Delete
Accufab Plenum
Roush 75mm Throttle Body
JLT Ram Air Intake
MMR-Moroso Oil/Air Separator
Moroso Coolant Overflow
FRPP 42# Injectors
Lightning MAF
2004 Terminator Tank and Pumps
Mac Longtube Headers
Mac O/R H-Pipe
Dynomax Super Turbo Side Exit Exhaust
Fidanza Aluminum Flywheel
Exedy Mach 500 Clutch
FRPP Aluminum Driveshaft
FRPP 3.73 Gears
Tuned for Ethanol (e85)
MadStang
Escondido, Ca
thanks man. that's all with a stock intake too. With an Eddy I'd be well into the 400whp range, only thing keeping me from doing it is the fact that I'll loose that gob of torque from 3k up.
chris91
Cincinnati, OH
Damn those are some nice numbers. I should have some numbers to post up soon. Just gotta wire up my wideband and Ill have my final tune finished up and ready to rock.
punched281
Colorado
Going to the dyno on saturday, I hope everything works out to where I can post a sheet up. Wish me luck fellas.
punched281
Colorado
no luck, there was a problem with the temp sensor. I got that fixed today and now it just shuts off after about 30-40 seconds of running. It didn't do that before the tuner was messing with it on the dyno. It isn't fuel for sure, so I really think it is ignition.
redriderjf87
Port Byron, IL
Just got back from the local DynoJet to fix my email tune issues, will upload my sheet as I get it scanned.
2002 GT 5-spd
K&N FIPK
70 mm tb and plenum (accufab)
O/R Prochamber and Stingers
265 hp / 312 lb-ft
**Not sure why my post with the dyno sheet got deleted, here it is again though for documentation...
RevJon
