Tech Article & How-To Directory
How-To/Tech Articles Index & Directory
Here is an index of useful writeups and how-to articles for our cars. This should make it easier to find what you're looking for.
I only posted the most useful and popular how-to's. I left out the older articles which don't have working links or photos anymore.
If you have a writeup you'd like to me add, just post it up and i'll edit the directory.
Interior:
LED Gauge Cluster
LED Gauge Cluster (Beyond Basics)
Backseat Subwoofer Install
How To Relocate Cigarette Lighter To Center Console
How To Replace Interior Door Handles
How To Replace Your Odomoter
How To Remove Center Console
How To Install White Face Gauges
How To Install A B&M Hammer Shifter
Hurst Quarterstick Shifter Install
How To Install A Tachometer
Replacing Shifter Indicator Light
How To Replace Multi-Function Switch
Clock Pod Radar Detector
Heater Core Replacement
HowTo Replace Airbag Clock Spring
How To Install Lower Shift Boot
How To Paint Your Needles
Raptor Shift Light Install
How To Recover Headliner
Double Din Radio Bezel Install
Blue Clock Dock
One Touch Power Down Windows
How To Repair Convertible Top Motor
Gauges:
Electrical Fuel Level Gauge
Vacuum Gauge
Electric Water Temperature & Oil Pressure
Water Temperature & Oil Pressure (4.6)
Exterior:
How To Install Aftermarket Headlights
How To Make A Quick Release Bumper
How To Paint Your Wing/Spoiler
How To Paint Your Calipers
How To Polish Your Calipers
Fog Light Mod
Brake Light Mod
How To Repair Curb Rash
How To Refinish Wheels
How To Change Rear Quarter Scoop
How To Tint Your Taillights
How To Install Hood Pins
How To Install Hidden Hood Pins
Painting Rear Bumper Valence
Swapping Rear View Mirrors
Motor:
How To Diagnose MAF
How To Clean Your MAF
Idle/Maintenance Issues
Pulling Codes Without Scan Tool
How To Sump Your Gas Tank
How To Make IAC Restrictor Plate
How To Make A Ram Air Intake
How To Make A PCV Oil Seperator
How To Remove AC
HCI Swap (5.0)
How To Port Your Intake
Driveline:
How To Pull A Transmission
How To Replace Speedometer Gear
JMOD Shift Kit
Adjusting The Clutch Cable
8.8 Gear Install
Replacing Pinion Seal
Suspension:
Shock/Strut Install
How To Raise Your Rear End
How To Replace Front CA Bushings
Rear Strut Tower Brace
Convertible X-Brace Install
How To Flip Quad Shocks
Swaps:
94/95 To 03/04 Cobra
Coil To COPs
2V To 4V
Tech Articles:
Ford OBDII Codes
Torque Specs
The 4.6L Engine
PCV System
Superchargers 101
Nitrous 101
SRA vs. IRS
Drag Racing 101
Recovering Broken Lug Nuts
Polishing
Data-logging
Fuel Injector Sizes
MustangChris
Aurora, CO
Just so everyone knows, I handed the keys over to F-dog to re-work the how-to section HOWEVER he wants.... ;)
Moosetang69
Thank you OP for putting this together! Looks like I need to log into XenForo to access these links? Is there a way to register?
FHCee
