1/10 losi desert truck brushless + lipo
330CubeGt
Losi DT w/ 2.4Ghz
Brushless traxxas vxl system
Pro Line dirt hawg tires and rims
Dynamite driver 4 piece set 1/16, 5/64, 3/32, .050
Hardened Steel Idler Gear w/ Kevlar spur gear.
New differential with new o rings and spider gears
Truck has Aluminum Shocks, Steel axles and turnbuckles.
Traxxas high current (dean type) connectors throughout
Still has stock body, its a little beat up but its not due for a new body just yet.
Under side of the truck is in great shape with minor scuffs no major gouge's.
2.4 Controller has brand new batterys and an extra 8 brand new in the package.
Also includes:
Factory LOST motor worked when removed
Factory LOSI speed controller worked when removed
VXL Internal brushless parts/shaft
Factory allen wrench set
Factory Wheels In Great shape with no curb rash just small chips
Factory Tires In Great shape with tons of tread left
Original Owners Manuel for both the Losi Truck and the Traxxas VXL Brushless system.
Storage case with extra parts such as tie rod ends, washer, body clips, pinions, gorilla super glue
Standard flip out allen set from 5/64 up to 1/4
Metric flip out allen setfrom 1.5 up to 8
Truck is currently set up for LIPO but that can be changed if needed by on the speed controller at the touch of a buttom.
Gen Ace Lipo hard case is brand new with only 1 Run on the battery Gave me over 30 mins of tun time, Truck is currently geared 19P/84S But really could use a 24 Pinion to much higher speeds...
Truck is ready to run with everything but the actuall battery charger because its not mine. You can pick up a charger for a lipo pack for around $50 brand new... In short i have well over $500 into this R/C Car and i need the extra cash for other things so im letting it go for much less then what i have in it.
Asking $325...
__________________
330CubeGt
In the Pictures below the Three Batterys and Charger are NOT INCLUDED, will will get (1) Gen Ace Lipo Battery pack not pictured. I can get pics of actuall battery pack if needed its in Mint condition as i stated with 1 run on it.
RevJon
