1997 Ford Mustang GT 4.6L Coolant Leak
Moosetang69
@RAU03MACH , quick question - if it is my water pump that needs to be replaced, would it be recommended that I replace the surrounding parts like the serpentine belt, idler pulley, and tensioner?
RAU03MACH
NEW MEXICO
The tensioner make sure it has good spingback when pushed down has good tension
The idler pulley make sure its not dragging when rotating it
Or noise
The hoses check them mabe the thermostat while your in there
Spin all pulleys by hand make sure no dragging binding noise belt look for cracks fraying glaze
That's a pretty good start to kinda get to know that engine
Moosetang69
Just wanted to give everyone a heads up that I replaced the water pump. Looks like the original one had some corrosion, not sure what caused it.. maybe age?
SnakeBit!
Florida
if leaking from the center, probably the pump or t-stat. leaking on a side, looks at hoses. not sure if that year gt has a oil cooler on it on not. if so, those leak. oil filter screws to it.
RAU03MACH
NEW MEXICO
I just replaced mine with a motorcraft, mine looked ok but it was makeing some noise
I doing the hole cooling system
TGS
Hi, I have a similar problem although the coolant seems to be leaking from further back. Also kinda new to this, so I don't know what part exactly but looks like whatever is between the pump and the engine block.
Was it the water pump in your case?
btw I drive the V6 3.8
RevJon
