Mustang5L5
- Joined
- Aug 1, 2023
- Messages
- 605
- Reaction score
- 660
Swapped in a 1999 Cobra cluster.
I did it the not-so-common way and used ForScan to pair the IC module to the ECU and then mate the PATS keys to the cluster. WOrked perfectly. I assume the speedometer will read 100% correct, however the mileage is off.
My car has 70K miles, this cluster has 65K. Yeah it's close but I don't want to much around with mileage issues on a 70K mile car I may sell one day. Unless i can find a solution to this, i'll likely just do the board swap method. This will keep the mileage the same, but the speedo will be off slightly since the GT is a 150MPH speedo ad cobra is 160MPH. It's not a speedo gear calibration issue, it's a display issue. The odometer is right but the board things its sweeping a needle on a 150MPH face.
Just want to verify the speedo is dead on and then i;ll board swap to get my mileage correct.
But I love this look
