Any write ups for valve cover replacement 99 cobra
natedogg316
Looked but haven't really seen any thing, but looks like it's a pain in the ass, any help is appreciated thanks
badass98svt
I did this on my 98 and it was actually far easier than I've heard.
I didn't need to jack up the motor or anything. I was able to just sneak them off without anything in my way
N
natedogg316
Seen one post about using RTV on timing edges at head or something like that
RAU03MACH
NEW MEXICO
Take your time be patient getting them out
There are a few things to remove or just loosen up
To remove them
And putting them back is a trick
Because of the seal gasket
It falls out or it snags on other parts
I put just a dab of silicone on corners
And about in the middle of valve covers
Let it sit for a few hrs to secure to cover then install
TTSaleen
NC
My 2003 Mach 1 was a bear to change the driver side valve cover gasket! I think all 99-04 models are harder to clear.
I had to lower the engine enough so that the valve cover would clear the hydroboost.
You can either remove the bolt from the driver side engine mount and jack up engine or I used my lift and lowered the K-member.
Good luck!
Ryan
RevJon
