Cam install
rabbit2620
Can I install a B303 cam without removing the heads. I have a 94 5.0.
RAU03MACH
NEW MEXICO
You will need to remove push rods
Lifters timing chain
Heads can stay on
The spider fingers that hold lifters in
Will need to be removed also
rabbit2620
rabbit2620
After i install the B303 cam will I need to have the car tuned or will it be ok with the factory tune?
302hobronco
Washington
If I remember right one lifter won't come all the way out without removing the head. Not a big deal just use a magnet to hold it up out the bore a little to remove and install the cam.
rabbit2620
rabbit2620
what kind of heads will best fit the B303 cam and let them play nice together.
302hobronco
Washington
Any head really. The b303 isn't that big. Obviously it would do better in an aftermarket head than the iron e7 heads. But that cam is a good fit from mild to wild.
RAU03MACH
NEW MEXICO
At first I did not tune
Then the heads were changed and intake throttle body
Then I did the tune
If your modifying i would wait till all mods are complete the tune
rabbit2620
rabbit2620
Heads can stay on
Can i install it with the motor in the car or do i need to pull it?
RAU03MACH
NEW MEXICO
you can do it in the car or out
its up to you
i have made changes with engine in the car
peasant99
