the 460 interceptor that i had my 92 fox body was heavy the engine complete was heavy
the aluminum 4.6 just the bare block i can lift it off the ground , the 460 always needed a hand lifting it up
I wasn’t going to keep this nut swinging thing going but this post was so laughable I had to quote it. By saying you could lift a 4.6 aluminum block one handed shows how overinflated your ego really is, whether you’re being facetious or not. You had to one up Jon. Ok I’m done lol, go on and play with your cobra.i could lift a bare aluminum block one handed. a 2v aluminum block would be well under 400lbs. talk about a huge weight difference. people don't realize how much weight superchargers add. even the 4v with its huge heads and all aluminum intake weigh a ton. i'd have zero problems with an all aluminum 2v, move the battery to the back, you might even get a rear biased weight distribution with an IRS and man that sucker would hook and turn like a mofo.
No sir, that weight is pretty close to spot on believe it or not.From what I can find the aluminum blocks weigh 87# which sounds falsely light. My 670 twin sled motor weighs more. Granted it’s a complete motor but it’s the size of a toaster
I have never seen an aluminum 460 beforeHow about an aluminum 460 block. Aluminum 460 block
Fun fact.. the 6.8 V10 weighs a little lesss than a terminator setup.i could lift a bare aluminum block one handed. a 2v aluminum block would be well under 400lbs. talk about a huge weight difference. people don't realize how much weight superchargers add. even the 4v with its huge heads and all aluminum intake weigh a ton. i'd have zero problems with an all aluminum 2v, move the battery to the back, you might even get a rear biased weight distribution with an IRS and man that sucker would hook and turn like a mofo.
It only makes it past the first main journal, its like a cheese wheel!I carry 3. One with each arm and then I just stick my dick in the crank hole for the 3rd. Its a bit of a squeeze so there is a tough game of using just enough lube but not too much....
wap block?This was the first bare block that came with my car. If you can't lift this you should start taking testosterone supplements or something.
It makes sense that you'd be as weak as your posts, though.
wap block?
