96blak54
In the shop
Maybe I have already asked this, but what intake manifold do you plan to use? I ask because ive dabbled a little bit in manifold modifications and I would think 2 edelbrock manifolds hacked together would suit your engine build well and package under the hood.
Snorky
Snorky
Well.. my options are cut up the stock intake and make that work or do the dual Eddie's and a custom elbow. The way it looks to me is the stock intake will probably be significantly cheaper. Since you have 800 between 2 eddies.. then welding them all together/widening them.. and then making an adapter/elbow for a 96-98 cobra throttle body. Not sure what to do.. my gut tells me a v10 modified would probably be a lot foe the fab work.. while the 2 Eddie's starting price is 800 without fab work.. a hard enough pill to swallow. Since it all has a height restriction. The stock intake as is won't fit under a 95R hood. Even with 1/2" k spacers
Snorky
Snorky
You offering to farm out your services?
Snorky
Snorky
That sounds cool
Right?! My issue is the starting cost for a custom eddie is some 800 for 2 eddies.. then the fab work comes into play. And the idiot I am.. I bought a DC multimatic 215.. didn't anticipate custom aluminum intake manifolds.. and well.. here I am. So the cost of fab work is the questionable ticket.. especially since it needs an elbow for a 96-98 cobra throttle body.
Snorky
Snorky
Went up to the paint shop. Car was covered, and the interior is dryyyyy. Anxiety relieved.20240121_081801.jpg
Jump started it and pulled it inside for the full strip. 20240121_083156.jpg20240121_105219.jpg
Cobra bumper crack has been plastic welded.
I guess this means it is now in the Que! Exciting stuff!
Snorky
Snorky
These are the cam specs. Only guy I could find with the v10 cam core game.. already know your thoughts on him lol mine are kinda in those lines as well.
96blak54
In the shop
"These are the cam specs. Only guy I could find with the v10 cam core game.. already know your thoughts on him lol mine are kinda in those lines as well"
I can honestly say the guy is on par with business aspects. He meets demands on a timely manner. Takes care of customers. However, you could have called that company directly and had the cams ground for you....eliminating the middleman and his costs.
Cool nonetheless! I just went thru you entire build thread and man you have laid out some time on it!
I also want to encourage you to take all that detailed info, pics, and process you made with the reupholstering your seats and make a seperate thread for the "exterior and interior" forum section. We see if we can get it to be a sticky thread!
Snorky
Snorky
I will get to the upholstery sticky in due time. Been making some more progress in other areas.
Snorky
Snorky
So I started putting green cars engine back together but I may end up trading the turbo setup for a blower setup if 2 of the possible traders get their shit together. So if that happens I would change cams. So I'm leaving the engine together, timed. Followers in but no covers for now.
Decided I would focus on the real meat and potatoes. I installed and torqued all of the main bearings 30 lb ft +90° and the side bolts 22 lb ft + 90° and checked bearing clearances using my dial bore gage.
set the bore gage to the middle of my crank main journal measurements which was 2.6571" and proceeded to check the mains.
They were for the most part in tolerance. Kind of egg shaped, im used to machining in the millionths so this stuff is crazy how out they are to me lol. But nonetheless they were in spec and I compared them to their respective journals and they were in the green.
Next step on main #4 I swapped the oem bolts for arp studs since I needed the pickup tube stud and tossed in a set of arp side bolts on that one journal. Torqued the mains in 3 easy steps to 60 lb ft. Then the 9mm side bolts to 45 lb ft. Then rechecked main #4 with the bore gage seeing if it would warp requiring a line hone.. it actually made it more in spec and rounder. LoL my coworker and I couldn't believe it. Almost tempted to buy a whole set of v8 2v side bolts and main studs. But that would be $150 for nothing. So I'm running it. Next we flipped the block over and ran a hone through it bathing it in honing oil.20240316_114926.jpg
Next I gave everything a final wipe down and slathered all of the bearings with Lucas assembly lube as well as the crank play shims. Dropped the crank in and did the final assembly and torque to spec. Spins slowly but smoothly by hand grabbing the snout with my bear hand, the slowness is more than likely due to the honey on the bearings. Checked end play which is right at .007", right in spec.
Thar she blows.. the crank is in.
Checked the rod journal sizes and documented those as well.
Next time my coworker and I get time we will start checking the rods bearing clearance. If it checks out then it's on to piston rings and rod/piston installation. :) very... very excited!!
Snorky
Snorky
Another small piece to the puzzle, a guy had these for sale in PA. He was kind enough to sell them to me shipped for $40. I am shocked at how nice they are, theyblook brand new. I hope they work with the convertible flange plates as I do not remember how the convertible ones mount and the car is still at the paint shop.20240320_165538.jpg
Snorky
Snorky
Wow! Engine going together nice!
Coming back apart, decided I liked the results of the arp studs so much that I'm doing arp main studs and side bolts in all of the journals. And will recheck the clearance for roundness, reclean and reassemble.
I am starting to think you just like to fondle the inside of that v10. I don't think anyone can blame ya for going to studs
Snorky
Snorky
Would fondle it more if I dug into my pockets deeper for forged rods and pistons. Hoping the stock big rod ends with the bearings measure out okay. If the whole thing works out and runs well and is a great success I will consider pulling it and doing forged rods/pistons later on.
96blak54
In the shop
Well while youre in there, take a sharp tool steel edge deburring scraper and take off the edges of the bearings ends on the inside. Removing the edge slightly, dont go over board. Just enough to prevent the ends from having a mismatch from either different thicknesses or bearing crush. This will reduce wiping the oil. Purchased race oriented bearings are like this. Same goes for rod bearings
Snorky
Snorky
So you're saying use the deburring wand on the outside circumference of the bearings themselves to bevel the edge to reduce the chances of a highspot at the lip.. or some sort of roll over burr when it was being produced.. Should I lightly smoothe the transition of the bevel with some 800 grit following that?
Snorky
Snorky
Another piece of the bottom end puzzle! Main studs!!!! Waiting on the side cap bolts now.. should be here between now and monday night .
Very exciting :)
