Snorky
- Joined
- Feb 10, 2022
- Messages
- 840
- Reaction score
- 727
Guessing you
Guessing you added the hydroboost after the install. How did you go about lifting the car? Cherry picker on the radiator core support? Never installed an engine from the bottom. It sounds wayyy better. And the BMR units sound like quality pieces. I am not a fan of the UPR setup on my turbo car. Wish the turbo kit would clear a nicer K member on that. The headers i am leaning heavily towaeds those hedmans. I will probably order them when the heads are finished at the machine shop. As far as i know they havent even looked at them yet. Guys work log is booked solid! I will most likely go with an H pipe like you out of ease of installation. However i guess it comes down to what i find for sale.I installed from the bottom, fully assembled, headers, trans, intake, hpipe all installed before putting it in the car. Wasn't too hard and did it by myself. Im glad i went tubular as the mounting holes in the bmr kmember are slotted left to right so you can offset the front assembly if youre needing clearance, You're gonna be super limited on header options for sure so it's likely gonna be a "buy what's available and cross your fingers" I'd look for whatever exhaust keeps it up tight to the headers the most. Kmember spacers give you all around clearance except the steering shaft which is gonna be a PITA regardless.
