Stock982v
I have a 98 GT , would a 96-97 tank be a direct swap? Or what needs to be modded.
I did this to my car, by the way.
I had a 97 tank but almost sold the car , so I sold everything I had for it. Smh gonna ask if I can buy it back. Lol
http://www.highflowfuel.com/i-20760...d-mustang-1994-1997.html?ref=category:1097310
Let me know if you order it, I have a discount code for it.
Is the 96-97 a better tank than the '98 tank?
It is! The 97 and down tanks are return style with baffles inside the tank and the pump and sending unit are two different parts. The 97 and down uses a single speed pump and not a variable speed like the 98 so your pump options are limitless with that setup. The 98 is return style but has the pump inside a basket like the returnless stuff and uses a variable speed pump. The pump options for the 98 are very limited and if you have to modify the basket by drilling holes in it and fitting a bigger pump in there then you run the risk of starving it for fuel if you are below 1/4 tank or even causing an extended crank issue (like I had) because the basket isnt holding fuel anymore.
Hey, can you provide more info on how you did this swap? This a gonna be a long post…Direct fit, you need the tank (complete with pump and sending unit), the wiring harness that plugs into the pump and sending unit and youll have to unpin the connector and swap it with the 98 connector (we can talk about that if you get it), youll need the filler neck, and the two fuel lines that go from the filter and return line to the pump. Then youll need to wire around the ccrm to get rid of the variable speed crap and then you will repin the relay behind the glove box. Then your pump will work as factory and the fuel pressure regulator will do the regulating at the rail.
I will try to help as much as possible, it’s been a few years since I went down this road though.Hey, can you provide more info on how you did this swap? This a gonna be a long post…
I’m in the process of restoring my 98 gt w/ pi swap and vortech blower, the car hasn’t run in 10 years, but one of the problems I always had was fuel pressure dropping at high rmp. I had 42# injectors, rigged a 97 fuel pump to fit the basket and added a in line trex pump, but still had the issue, always assumed it was because of the pump basket. I was also running 97 rails with a aeromotive regulator, but was thinking about buying the stock rails back on in case my issue was cause by the regulator.
Since I’m restoring the car, I bought the walbro 255 drop in for the 98gt, removing the trex and putting the stock rails/regulator back, just to see if my problems go away.
Since then I found a crack in the filler neck, so been thinking about the swap, which led me to this post. Swapping the tank, filler neck and fuel lines is pretty straight forward.
Do you use 96-97 connectors and repin them to the factory harness or do you keep the factory 98 connector and repin the new pump connector?
What is involved in making the ccrm operate as a normal fuel pressure solenoid and remove the variable voltage crap? By doing this, would I use my aeromotive regulator instead of the fixed 98 one?
I’m not 100% certain. I’ve worked on many 98’s and have never seen one that was returnless. They have all been return style, but the tank and pump assembly changed and looked like the coming up returnless setup.Wasn't 1998 a transition year? Early cars got the return style before changing over?
All the 98 2v are return fuel system, but use variable voltage fuel pumps controlled by the ccrm (located in the front passenger fender).Wasn't 1998 a transition year? Early cars got the return style before changing over?
It not really controlled by the ccrm. There are two relays in the circuit and a resistor. When the relays send voltage through the resistor, it lowers voltage to the pump. Essentially lowering the pump speed. So it’s not variable as much as just high and low speed.All the 98 2v are return fuel system, but use variable voltage fuel pumps controlled by the ccrm (located in the front passenger fender).
