Snorky
- Joined
- Feb 10, 2022
- Messages
- 835
- Reaction score
- 703
Well.. I have a thread for red car.. so I decided I should open one up for green car. Green car I bought some 12 years ago, bone stock with 22k miles on it out of Ohio.
The car evolved as most cars do and here we are today. Car blew a head gasket so the engine was pulled and now im in the process of reassembly. This car has been a basket case ever since going turbo 8 years ago.
Anyway. Here's some progress. New Ford oem gaskets on my freshly decked heads. Reinstalled the turbo cams
Even though I'm excited to get it back together, it almost pains me having to put this turbo kit back on again since I no longer race the car. Had the kit up for sale or trade 4 months and didn't get much attention for it. 1 person offered a ported cobra tork tek kit and one person I tried working out a deal for had a vortech v2 TI trim, but that one fell through. Anyway. Here's the mod list on the car
Suspension
UPR tubular K member
Upr tubular A arms
MM coil over kit in front on koni yellows
MM cc plates
MM XD LCAs
MM HD TQ arm
MM Phb
MM TA springs
Eibach rear sway bar
No. Upper lcas, no quad shocks.
Drive train
Mcleod steel flywheel
Mcleod rst clutch
Stock tr 3650 LOL
Mgw shifter with comfort handle
Ford racing aluminum drive shaft
8.8 with welded tubes
Gt500 track lock
31 spline strange axles
3.27 gears (went from 3.27 to 3.73 to 4.10 to 3.55 and now back to 3.27.. full circle)
Brakes
Cobra calipers/rotors front
Gt slotted in rear
Stainless lines all around.
Interior
Mach 1 seats
Simco classic gages,
Triple pillar pod with aem wideband, oil pressure and vacuum boost reverse glow with dimmer box.
Fuel
On3 cobra tank/hat with twin on3 300 lph pumps
Cobra level sender.
10 AN feed to dual 8s
8 an return.
Holley regulator
DivisionX rails
60lb injectors.
Alkycontrol 2.5 gallon trunk mounted meth kit.
Engine
Mmr 4.75 stroker bottom end, Manley rods, mmr by manley pistons 17cc with PI valve reliefs roughly 9.5:1
MHS stage 2 ported heads
Single groove manley +1mm valves
#125 springs
Mhs stage 2 turbo cams.
P51 intake manifold
Professional products throttle body
Summit sfi balancer
J2fab alternator
Battery relocated to trunk
Induction
On3 turbo kit with Vee band flanges replaced. Headers milled
3" ball and sockets for down pipe/mid pip junctions. Whole thing ceramic coated wrapped and sprayed with high temp silicon spray.
Tial 50mm bov
Tial 44mm wastegate
Grimmspeed manual boost controller
Turbonetics 7575 hpc turbo .96 AR
10 an drain
Turbosmart oil pressure regulator 4an feed 4an return to pan.
Oil filter relocation kit 10 an in fender.
Custom Y pipe and bassani catback for the torque arm and panhard bar.
Probably a bunch of other stuff I can't remember
Body
99/01 cobra bumper
Trufiber a42 hood "saleen E hood"
03/04 cobra mirrors
35th anniversary LE side skirts
03/04 mach 1 sail panels
99/01 cobra tail lights
Awaiting install of a 3 piece saleen wing.
Staggered 17x9 17x10 black saleens
255/35/17 federal rs ss tires in front
315/35/17 toyo r888 original in rear
Anyway. I'll post more of this as it goes. Hopefully the project will come to a close soon.
Suspension
Upr tubular A arms
MM cc plates
MM XD LCAs
MM HD TQ arm
MM Phb
MM TA springs
Drive train
Mcleod rst clutch
Stock tr 3650 LOL
Gt500 track lock
Brakes
Gt slotted in rear
Interior
Mach 1 seats
Fuel
Cobra level sender.
8 an return.
Holley regulator
DivisionX rails
60lb injectors.
Engine
#125 springs
P51 intake manifold
Summit sfi balancer
J2fab alternator
Induction
Tial 50mm bov
Tial 44mm wastegate
10 an drain
Body
99/01 cobra bumper
03/04 cobra mirrors
