headlight sticky
det_riot
Dearborn
96 VERT said:
det_riot said:
96 VERT said:
only interested if i can put in my own hids, because i already have them
Yes you can put your own hids in them, they just come with normal bulbs. The Corners are 9.99 Ebay corners
http://www.optionracing.com/images/eBayPhotoNE/HeadTailLights/26-18111.jpg
The headlights were $131 from autolightsbulbs.com
http://www.autolightsbulbs.com/1994-1998-Ford-Mustang-Headlight-Assembly/K1102002.aspx
cool and still 9007 bulb?
Yupp, 9007 bulbs, different bulbs for high and low.
How good do your headlights match your corners? Any difference in shade? Kinda wondering if the chrome ones wouldn't look too cheap
They match really well to be honest. Personally I'd like to open them up and paint the white lining on the corners and the chrome on the headlights, yes I'd lose my high beams but w/ hid's in the near future I won't need them anyways.
thorco3
IN
white98stang said:
im jealous of your lights thorco
I'm guessing your talking about the current set.
haha, I'll let you know if they're ever for sale. I'm sure somebody still makes them, but I haven't been able to find them.
white98stang
That would be awesome. If you find some Ill be the guy here
ProKiller
PA
thorco3 said:
ProKiller said:
ford cobra lights with ultra clears from CJ pony parts. no clue on price. the lights have been on the car now for at least 8 years. the side markers are the second set in that time. http://www.cjponyparts.com/diamond-...nd-clear-side-marker-lights-1994-1998/p/PL12/
interesting. i could have sworn that i saw ford badge on them but i guess not. either way though, they've held up for years.
The lights you have pictured are not OEM cobra headlights.
96 VERT
Marietta, Georgia, United States
well i have hi/lo hids
det_riot
Dearborn
well it should still work i would imagine. they re-use the factory harness so i don't see why it wouldn't work with them.
ivan12
Det_riot, how good are the rubber pieces on the corners holding up for you?
det_riot
Dearborn
Well, they held up good until about2 weeks ago, thats when i noticed the passenger side rubber starting to split. I haven't decided yet what i'm going to do about it, i'll probably just get some weather stripping from like advance or autozone
white95
Apex Junky
Prairieville, LA
identical but different (haha) to the lights in the second post
Here are both clear and black versions of the "Gen2" variety.
yea, I know
8000k HIDs
The fence is about 90-100' away
thorco3
IN
they do look similar though, I had the same set on my old sixxer and they held up pretty well. 8 years is a dang good life span for any headlight regardless.
uh0h50
yea, I know
8000k HIDs
wow that light output puts my aftermarket cobra headlights + 4300k HIDs to shame! I assume those night shots are showing the light output from the "black version" of the gen2 headlights. Is that correct? If so, I'm sold.
white95
Apex Junky
Prairieville, LA
uh0h50 - wow that light output puts my aftermarket cobra headlights + 4300k HIDs to shame! I assume those night shots are showing the light output from the "black version" of the gen2 headlights. Is that correct? If so, I'm sold.
You, sir, have assumed correctly!!
uh0h50
White95, how did you like the chrome versions of those gen2s?
thorco3
IN
DFG I really like your lights as well. I bet those are the newer version of the ones I have. The internals all look the same but your lens's are completely clear and you have the amber reflector in the turn signal as well.
HuskerGT
Nebraska
I still like DFG magic's setup. They have a "stock-ish" appearance with the amber corners & I like the black housing with clear lenses for visibility purposes. But pretty pricey
badass96gt
Does anyone have pics of tinted stock headlights and corners? Mine are perfect and I have a buddy that tints them and tails using clear with a little bit of black, his tails turn out killer, Im just curious on how the fronts migh be and the visibility. I plan HIDs in the near future so I dont think it will be an issue.
RevJon
