Kyle89
- Joined
- Apr 14, 2024
- Messages
- 20
- Reaction score
- 9
Hey guys and gals I am first time mustang owner (bow tie by heart and blood ) but I been after this 95 (lil Red) is her name mustang for 10 years she has 129k on the body and 96and some change on the motor she sat for 10 years after my brother-in-law pulled the blown 3.8 out and droped this one in after changing the head gaskets (to be safe) he never finished it but it sat after just bolting the motor in and hooking wires up I bought a starter pulled trans and replaced tc seal plugs wires and a oil change and went to do a test fire today and it ran when it was pulled from other car it sat under the hood for 10 years easy un touched I have not found any chewed wires but I can not get fuel pump on (assuming it’s toast) it will not crank over with the key but everything comes on I can however use the starter relay and crank the motor with the key on there is some fuses under the dash gone and I think a maxi fuse under the hood is gone and a circuit breaker fuse also gone under the hood I am not getting ANY spark from the coil I’ve made sure it was in park I’ve tried neutral everything as far as I can tell is plugged in there is no fuses I see that are (key related or spark related ) it has an obd2 port but cars date on the door jam is 1 of 95 so January 95 is when it was rolled out idk if they had obd2 then or not on ford but I plugged a scanner in and got no power from it so I assumed it is nonfunctional being a 95 does anyone have any ideas on this no crank no start ? /no spark
