HELP!! 2002 Mustang not starting!
Trey Adair
So today my car got stuck at work simply because it would not start. We tried jumpstarting it it cracks for a second then gives out. When starting without the cables it clicks then shuts off. If you have any advice please come my way!! Thanks in advance.
T
Trey Adair
I would tell you if I knew, but i had the battery tested it was fine and charged
RAU03MACH
NEW MEXICO
Check all battery connections terminals free of corrosion and tightness on the terminals grounds also
T
Trey Adair
im iffy on one negative cable there’s wires exposed but seems as ifits under the grounds?
RAU03MACH
NEW MEXICO
Check out all of those connections
Even to the starter
The battery needs at least 12. 60 to 13 volts to start if you don't have that at the battery try another battery
If the battery has that voltage and drops while starting could be a bad battery
T
Trey Adair
i might just end up replacing all ground cables. thank you anyway good sir
RevJon
