Highlighted posts from Friday, Aug. 19, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 18, 2022 * 17 posts * 151 views
tmwsccsh said: I'd recognise that number plate style anywhere - you're in the UK like me! And you have a tin top cousin of my convertible! TMW Read more >>
August 18, 2022 * 10 posts * 63 views
Venompower said: To say I have gone through a range of emotions since Saturday would be an understatement... when doing the first oil change since purchasing my Mustang I found glitter in the oil, ... Read more >>
August 18, 2022 * 12 posts * 79 views
badass98svt said: .075" Or, you could mill down the mounting ears of the calipers the same .075 Either way works. I bought the spacers as a back-up, but planned on milling down the calipers. Read more >>
August 18, 2022 * 7 posts * 72 views
ttocs said: if you pull back the carpet on the drivers side of the console under the radio you can see the harnesses that plug into the amp and disconnect them. If you are playing your music ... Read more >>
August 18, 2022 * 8 posts * 68 views
weendoggy said: I guess it depends on what you intend to do with the car. I just finished my '02 swap and did all the work myself, sans a bit of tig welding, but it can be done. You have a lot ... Read more >>
August 19, 2022 * 4 posts * 21 views
Aaronh007 said: My 94 gt started jerking and hesitating bad under 4k rpm. After I parked it and went to start it, it idled super low up to a little over 1k up and down then back fired. I tried ... Read more >>
August 18, 2022 * 1 post * 12 views
carid said: [image] Introducing the Cipher racing seats - the perfect combination of comfort and style for your sports car. These seats come in standard sizes, with various upholstery and ... Read more >>
August 19, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Hood Badge Removal August 17, 2022 * 14 posts * 91 views Exterior and Interior 1997 Mustang GT misfire August 17, 2022 * 9 posts ... Read more >>
Continue reading...
RevJon
