Highlighted posts from Friday, Dec. 24, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 23, 2021 * 24 posts * 152 views
ttocs said: sounds like we can officially call you a mechanic. Fuel pump is another thing that you can often "fix" by thumping on the gas tank. If you turn the key on and do not hear it prime ... Read more >>
December 24, 2021 * 3 posts * 27 views
ttocs said: its a good idea to disconnect the battery but it should not be necessary. The bolts for the steering wheel are on the back of the wheel and the pass side bolts are accessed from ... Read more >>
December 24, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts 94 GT starter engages but won't spin motor. December 23, 2021 * 25 posts * 179 views 94-95 5.0 - Specific Battery relocation issues ... Read more >>
December 23, 2021 * 13 posts * 201 views
delling3 said: Can't do pics until spring - I have the car in storage with no access until April. In my case, the were the standard factory belts from a 1996 convertible - with upper and lower ... Read more >>
Continue reading...
FHCee
