Highlighted posts from Friday, Sep. 23, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
September 22, 2022 * 31 posts * 401 views
joe65 said: yeah i've heard guys say many times that you can get about any header to work on those p heads with the right wire ends. Read more >>
September 23, 2022 * 8 posts * 72 views
Pallgor said: That's a tough one. My car coolant is lower with my ac on. I figured because of the second fan. I also switched to a 180 thermostat. My temp was pretty high before I dropped the ... Read more >>
September 22, 2022 * 5 posts * 70 views
95GTS5L said: I used the black energy ones poly i believe on my T-5 and Stock made in India rubber ones on engine from Rock-Auto. Read more >>
September 22, 2022 * 10 posts * 196 views
That Mustang Guy said: I made more price adjustments on all items. Check it out. The P/S res is pending. Read more >>
September 22, 2022 * 3 posts * 36 views
white95 said: Heat gun and "goo gone" also works well. Just don't stay in on spot for too long. Read more >>
September 22, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Is anyone familiar with this CAI? September 21, 2022 * 8 posts * 64 views 96-04 - 4V Specific Heads question September 22, 2022 ... Read more >>
September 23, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Heads question September 20, 2022 * 27 posts * 314 views 94-95 5.0 - Specific Here's my babies September 20, 2022 * 16 posts * 31 ... Read more >>
September 22, 2022 * 8 posts * 151 views
98GTAZ said: Solved! Turns out it was a bad driver's side ball joint. The ball joints kept passing the tire pull test, but I decided to replace them anyway. Both looked OK from the outside. ... Read more >>
Continue reading...
RevJon
