Highlighted posts from Monday, Dec. 06, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 04, 2021 * 12 posts * 78 views
Jayjayducky2001 said: Well I bought my 94 GT 5 speed about a month ago and I've decided I want to put a stage 2 Intercooled procharger on her. Yes I will be doing forged internals and all of the needed ... Read more >>
December 03, 2021 * 11 posts * 79 views
ttocs said: if the car is starting then they are programmed. I Thought you had to leave the key in the ignition for 5-10 mins for it to program Read more >>
December 02, 2021 * 11 posts * 142 views
Monday said: MLPS or Manual Lever Position Switch a neutral safety switch Read more >>
December 03, 2021 * 6 posts * 73 views
lwarrior1016 said: Up to 97 the tank was like the one pictured with two holes. 98 was still return style but went to a pump in a basket in the middle of the tank. 99 and up was the same style but ... Read more >>
December 02, 2021 * 5 posts * 50 views
ttocs said: I do not have any charging problems but I didn't use much of the stock wiring. I am pretty sure you are thinking of a later model that had the charging issues when the dash was ... Read more >>
December 05, 2021 * 3 posts * 16 views
Bdenmark73 said: Got out of work this morning and vehicle went into anti theft mode and have tried everything on all the forums to get it to reset and still nothing so looking to change out the ... Read more >>
December 03, 2021 * 2 posts * 28 views
ttocs said: they are similar enough that if someone really wanted to they could probably figure a way out to swap them. It takes 5 secs to pull that panel out and see if it looks like they ... Read more >>
December 05, 2021 * 1 post * 22 views
wvmedic99 said: Good Afternoon, first time poster here. Today, working on my son's 98, we replaced the stock steering shaft with a solid shaft from Maximum Motorsports. While we were connecting ... Read more >>
December 04, 2021 * 1 post * 12 views
SN95Newsletter said: Click here to view on the web Highlighted posts Pats key reprogramming December 03, 2021 * 11 posts * 51 views Electrical & Stereo Does anyone know the reason behind the different ... Read more >>
December 04, 2021 * 16 posts * 750 views
Monday said: Cut a new key. They code a new chip 'n everything. I got two. GET THEM CUT AT A LOCKSMITH. It will literally be a hundred and a half or more cheaper - DON"T GET THEM AT DEALERS!!! ... Read more >>
Continue reading...
twisteddalek
