Highlighted posts from Saturday, Jul. 10, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
July 10, 2021 * 14 posts * 41 views
Adfalenski said: Most HID systems use only one element that is spring-loaded in an "out" position. When highbeams are selected, the electromagnet retracts the element about 3/8" which changes the ... Read more >>
July 09, 2021 * 19 posts * 146 views
Adfalenski said: I Just installed a Modern Driveline hydraulic clutch kit. First time I installed it, i had the same symptoms as yours. Checked and found spacing of the slave piston needed to be ... Read more >>
July 09, 2021 * 10 posts * 87 views
joe65 said: yeah save yourself some grief. either find a replacement v6 or shop for a gt mustang if that's what you really want. if you look hard enough you can find something at all price ... Read more >>
July 10, 2021 * 9 posts * 46 views
07GtS197 said: Most likely that's an idle issue, I wouldn't be too worried about that one. I guess my point is I wouldn't mess with the transmission until the new motor is in and you can test ... Read more >>
July 09, 2021 * 6 posts * 19 views
Daryl said: A while back I replaced the stock shifter and linkage with the SVE short throw with white cue ball. I'm not as happy with it as I hoped to be, finding it a bit "ratchety" between ... Read more >>
July 09, 2021 * 4 posts * 40 views
Adfalenski said: You might also try glass cleaner. Ammonia and vinegar are not caustic to the surfaces and evaporate without leaving any residue. Wet a rag and scrub for a few seconds and then ... Read more >>
July 09, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Hydraulic Clutch issues July 08, 2021 * 12 posts * 98 views Drivetrain 1998 mustang July 08, 2021 * 7 posts * 60 views Drivetrain ... Read more >>
July 09, 2021 * 38 posts * 516 views
joe65 said: not a bad choice at all. for the money especially. I'm a total fan of the gt40 stuff. Lots of guys like Tmoss, Thumper and others have been preaching that for years. Way to read ... Read more >>
Continue reading...
RevJon
