Highlighted posts from Thursday, Jun. 23, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
June 22, 2022 * 10 posts * 58 views
cobrajeff96 said: Better than adding LEDs on the output wires leading to the fan is to add them to the inputs that trigger the relays in the CCRM (low current draw). You've got a huge inductive ... Read more >>
June 22, 2022 * 18 posts * 310 views
PistolGrip said: I'm following this with interest. I also have a '94 Cobra 5.0 5 speed with about 75,000 miles. I bought it about 20 trouble-free years ago. Mine has sounded/felt like it wanted ... Read more >>
June 22, 2022 * 7 posts * 60 views
bpalmbos said: Last night I found the 8-pin harness that you were referring to, ttocs, and connected that to my speaker outputs from the new head unit. I connected my lower door speakers to the ... Read more >>
June 23, 2022 * 3 posts * 37 views
96blak54 said: Dang....12" is wide! But im running a 345 wide tire on my rear. The equates to 13.5" converted to American language. Id suppose 12" wide would fit Read more >>
June 22, 2022 * 2 posts * 38 views
95opal said: Were you running a pump controller with your external pump? 99 and up tank with triple hat would be the direction to go. Little tweaking of the 99+ filler neck will make it work ... Read more >>
June 23, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts 8.8 rebuild June 21, 2022 * 17 posts * 253 views Drivetrain When hot it sputters & dies, wait, starts and runs great, repeat June ... Read more >>
Continue reading...
RevJon
