Highlighted posts from Wednesday, Dec. 08, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 07, 2021 * 48 posts * 293 views
ttocs said: I wanted to go with the procharger myself, but after I did the scottrod engine panels I wasn't sure there would be enough room between the supercharger and the panels, and then ... Read more >>
December 07, 2021 * 10 posts * 52 views
Bdenmark73 said: Next thing I have tried is replacing the transceiver underneath the ignition and that didn't work and have tried to hooked up a scan tool to see if it is throwing any codes... ... Read more >>
December 07, 2021 * 14 posts * 115 views
lwarrior1016 said: I know this is going to suck, but the best thing you can do is pull the tank back down and take the float assembly out. It's likely the it got hung up when you were installing ... Read more >>
December 07, 2021 * 4 posts * 22 views
Jason.Silus said: I own a '96 4.6L, and for the last year, it's broken down several times from seemingly the same cause. While driving, it will sputter out and die, and then by the next morning, ... Read more >>
December 07, 2021 * 3 posts * 21 views
itsell said: I have a 94GT that I'm putting together parts for a rebuild with GT40P heads with 1.72 SVO rockers, and cobra GT40 intake. I'm doing a lot of research into cams for my combo. I'd ... Read more >>
December 07, 2021 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Supercharger compression ratio December 06, 2021 * 33 posts * 158 views 94-95 5.0 - Specific Steering U-Joint Proper Name December ... Read more >>
Continue reading...
FHCee
